Scratch Build – In Progress GET A LIFE - COMPLETED
Discussion in 'Project Logs' started by The_Gnu, 17 Nov 2010.
  1. jrs77
    jrs77 Modder
    17 Feb 2006
    Will be interesting to see, if you achieve the same temps as I do with a Scythe S-Flex @ 800RPM (this fan is totally inaudible from one meter away of it) blowing on the heatsink.
  2. lakisss
    lakisss I know what a dremel is...
    28 Mar 2010
    Something important: When you post the temp results, tell as and the ambient temp.
  3. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Nice to have some reference material :thumb:
    Yes, I'll be doing that :)
  4. The_Gnu
    12 Sep 2005
    Okay. Finaly got my temp chart done.
    I think the results are pretty decent. It proves that the heatsink is atleast cooling. There is still improvements to be made on the cooling, like ditching that cooking oil on all the heatsink parts and replacing it with real thermal paste. And I also need to add the last heatpipe that will use the rest of the case for cooling.
    I base the CPU temps on the "Core#0" value from CPUID. For a reference, the values of the stock cooler with no fan in idle was Core#0=65°C and GPU core=59°C. I assume that the reason for the start temp being lower than ambient temp is because some kind of "standard value" of the tempcalculations, but maybe some of you guys can confirm this.
    Well here you go, CPU seems to stabilize at around 45°C and GPU at 43°C
    It seems like it takes about 2hours for the temperature to reach peak lvl. I will continue on with my load meassuring tomorrow.
    Btw, anyone know of a program that takes meassures and makes it own graph over a long time? I've tried speedfaan but I can only measure for 12m or something.
  5. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    very... very... impressive. When your finished (with your permission of course) I'l love to post a picture that me and a buddy did with bottle caps that is also a Mario Theme. I think it could compliment your finished project quite nicely :D
    but of course, this is your show and if there is any risk of taking your spot light I don't want to post it. This is just so freaken awesome!
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    Well, my thingy runs at around 35°C (GPU/CPU) with that same ambient of 25°C and rises to some 65°C when under load in a well ventilated case ofc.
    That's about the same as with the standard 60mm-fan @ 3000RPM directly attached to the heatsink.
    45°C isn't too shabby for totally passive cooling in this "unfinished" state tho and if you can keep it under 80°C under laod, then your setup is actually excellent for a passive cooling setup.
    I tried to run the board completely without a fan aswell, and it was still stable under load, allthough temps got up to some 95°C.
    Nicely done at the first glance I'd say :thumb:
  7. KidMod-Southpaw
    28 Sep 2010
    Well done! Sounds good so far, some silver 5 and a 3rd heatpipe will make a world of difference.
  8. stonedsurd
    11 Mar 2009
    Oh man, that's totally sick.
  9. Cosmot
    Cosmot What's a Dremel?
    12 Apr 2010
    thanks. its very great.:thumb:
  10. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This is insane man really really nice job!!!!
  11. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    sell me it!
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
  13. The_Gnu
    12 Sep 2005
    Thanks a lot, bottle caps sounds nice would love to see that :)
    Thanks for showing your temps. I also tried to run the stock cooler without any fan under load in the beginning. I decided to abort when the temps got to 80°C since they were still rising. I guess It might have reached 95 aswell.
    Thanks:thumb:
    Thanks. Yeah I think There will be some improvements once this is done.
    Thanks a lot guys :thumb:
    It's all a matter of figures :naughty:
    HAHA :thumb:
    BTW: Im starting to meassure the load temps at the moment.
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    As far as I know, the CPU does an emergency-shutoff at 105°C core-temperature. These Atom-CPUs are really well made actually and intel specifies them with 85°C TCASE.
    Lot's of people clocking the Atom 330 @ 2GHz as it has alot of headroom there when using the standard-cooling-solution. But hey... it's a chip with 8 Watt TDP to begin with :brrr:
    And for the ION-chip I found this info...
    So yeah. If your cooling-solution keeps the temperatures under 80°C at full load for CPU-cores and GPU/chip-core, then you won't see any troubles there.
  15. The_Gnu
    12 Sep 2005
    Thx a lot for that info jrs77. I will definetly play around with the fsb to se what result I might get. I don't think I need to worry about reaching that 92°C throttel line
    I've done some load testing today. I used prime95 and FurMark to stresstest both CPU and GPU at the same time. The results you can see below, I incorporated yesterdays Idle temp measures in the graph. The setup has been running for almost all day and I think it's safe to say that the temps are stable att 55°C. It took around 2h for the temps to reach the higest lvl, same as in idle mode.
    I had planed to test the setup in a horizontal position aswell but that will be the task for tomorrow. I hope you liked the results as I have to say I'm pretty satisfied.
    Waynio likes this.
  16. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    those temps are amazing! congrats!
  17. jrs77
    jrs77 Modder
    17 Feb 2006
    Awesome temps you got there :thumb:
    I think it's safe to say, that your setup is a winner :rock:
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    Woo hoo so it's gonna look awesome, have character, perform nice & with silence :eeek::jawdrop:, excellent work GNU :rock:. +rep :D
  19. The_Gnu
    12 Sep 2005
    Thanks guys:thumb: I'm more than happy with the temp results so far. I think it's time to play with the fsb a little:D
  20. TimtomNL
    TimtomNL What's a Dremel?
    25 Jan 2011
    Wow this looks very nice and the temps are quite impressive!:thumb:
