Graphics gfx card diagnostics
Discussion in 'Hardware' started by JavaBoy, 6 Jan 2005.
  1. JavaBoy
    JavaBoy What's a Dremel?
    21 Oct 2004
    someone told me that my problem might be a bad gfx card...
    is there any program that can test this !safely!
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Eh what problem some details might help :sigh:
    As for testing your graphics card boot into os > run games > benchmarks (3D Mark, Aquamark etc). If all runs fine then it's not a graphics card issue. But serious need way more details about your problem as what you've written is very vague.
  3. Ben
    Ben What's a Dremel?
    11 Aug 2003
    he mean these 2 threads
    will you stop posting a new thread just as people start to get some were.
    Answer all the questions.
    1. Is it stable and have you looked at the error log?
    2. What happened when you installed and played your game?
    3. Have you updated all your drivers?
    4. Have you tried your old graphics card?
    5. Have you tried resetting your cmos?
    Don’t say you have said as you have just formatted, and have not really said if anything change except.
    are we now playing fill in the blanks.
    ben
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    right will carry on in this one... not read both the threads but hey, here goes!
    Are you using an offboard soundcard (ie PCI) and if so what slot is it in.
    That PSU is probably on the edge of not enough. The 12v rails on them are crap... It'd be worth you looking to a new one considering your system spec tbh...
    Also, the stuff you stick on 1 string of molexes is important, ie dont stick your gfx and all your hdds on 1 and 8 fans on another... thats pointless... Give the power hungry devices the power they need..... get a splitter or summit to run the fans off if you need to to balance things out a bit...
    But as mentioned before it sounds like an IRQ issue, what with thr stuttering with sounds...
    Did you play about with any bios settings before installing windows? This might also be a problem, also did you check for spyware or viruses? What at idle is the windows memory useage and PO?
  5. JavaBoy
    21 Oct 2004
    it isnt a virus, i just remforatted, no i dont mess with the bios. integrated sound chip. the funny thing abuot this is the gfx and the sound chip are on teh same IRQ but everyone tells me its fine
    ummm i am going to jumper cmos later if i see the problem accour on the new isntall, i am test for that now
    can u tell me more about the 12v rails, does this have to do with my psu or my mobo?
  6. JavaBoy
    21 Oct 2004
    ok it does not appear to be the gfx card
    i am running cs:s with aa on 6x and as on 16x (btw what is af???)
    with everything on high and im getting 100fps +
    must eather be
    1. mobo
    2. psu
    3. irq
  7. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    antiscopic (sp???) filtering.
    Makes your textures look pretty.
    where as AA makes your edges look smooth.
  8. JavaBoy
    21 Oct 2004
    ppl talk about af but i only see antiscopic and aa what 1 is af what does it stand for ??????
  9. JavaBoy
    21 Oct 2004
    im not qutie sure if the fromat fixed it or not
    and i allso want to know about these crap 12v so i can take care of this
    edit: sry for replying so much
  10. Highland3r
    25 Jul 2003
    Grab yourself a multi meter and check ALL of the rails for the PSU, the 12 and 5 can be done from a molex, but pick one as close the the psu as you can...
    Stick the black probe on one of the ground pins (or a metal part of the case) and measre the 12 and 5v lines from the yellow and red. To get the 3.3, the easiest way is to again ground to the case and carefully stick the other probe into the ATX connector on one of the ORANGE wires.
    Do this at idle, prime load and again 3d load if you can... This probably wouldnt casuse stuttering, more crashing but its best to eliminate one thing at a time..
    Another quick q (sorry if its been answered before) but does the stuttering occur with ALL games or just some? Have you (or can you please) run 3dmark01,03 and 05 if possible? None of these have sound so if it stutters during those another avenue be eliminated :)
  11. JavaBoy
    21 Oct 2004
    it will never slutter untill the gfx frezzes so far i havnt had any problems, ill look to see if my dad has his meater handy (he and u use 1 the test laptop power where the die)
    if i needed to get a new psu could u help me pick a good 1
  12. Highland3r
    25 Jul 2003
    OK so the gfx stutters then the sound? Can you run 3dmark anways please? and either upload the result the ORB or post a screendump of the individual gametests average fps... also note if its stutters or not...
    PSU wise, depends on your budget, Antec or OCZ would be where i'd look tbh...
  13. JavaBoy
    21 Oct 2004
    well...money likes me...right now i have 100$ laying around...i might get somemore in a few days
  14. JavaBoy
    21 Oct 2004
    i dont have the software like in a box at my house, do u want to try the free version 1st?
  15. Highland3r
    25 Jul 2003
    :confused: :confused:
  16. JavaBoy
    21 Oct 2004
    i havent bought 3dmark, will the free one do?
  17. Dodge
    10 Oct 2003
    yes.
    www.futuremark.com
    I thought 3dmark 03 had some sound tests :/
    I think 99.9% of the people on here dont pay for 3d mark. Several reasons for this but thats another story.
  18. Highland3r
    25 Jul 2003
    yea it does but they can be ignored lol or if it stutters not as the case may be./..
  19. JavaBoy
    21 Oct 2004
    ok i put the gfx card on its own line and every thing else on the others
    edit: 2 gfx molex's on 1 line with nothing else
    cd drives and fan on the other 2
  20. JavaBoy
    21 Oct 2004
    bump??? is this psu set up ok?
    i am downlaoding 3dmark05 rightnow, although for some reason its a little slow.........(slow downloading)
