Scratch Build – Complete GwassGween -FINISHED-Nov13 2013-pics start on page 67
Discussion in 'Project Logs' started by Cheapskate, 25 Jun 2009.
  1. prettynifty
    prettynifty What's a Dremel?
    2 Mar 2010
    I can only say:
    "A dirty mind is a joy forever"
    and
    keep it up:dremel:
  2. Djayness
    Djayness phwupupupup
    7 May 2008
    Lets hope he doesn't have a problem with doing that :p
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Do you remember this one, Cheaps?
  4. Azayles
    Azayles Minimodder
    6 Jan 2008
    Oh good grief :duh:
  5. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    oh no...not again....:eeek:
  6. Cheapskate
    13 May 2007
    :lol: Thanks everyone! (Except YOU, perplekks!:nono:)
    ...^%&#$* trolls... I'll update if you stop with the trolls.
    -OK, I milled out a load of these WonderWoman invisible hockey pucks.
    -The plan is to have the core seated on the tube that runs through the center of the reservoir.
    -Here's the whole batch. Next I needed a guide to glue them with.
    -I made a plug for the center out of delrin. After the solvent dries it just pops out. (Or at least, that was the plan. It took a bit of hammering for the 'pop' part to happen.)
    Bananaman got one of those extreme makeovers while the pucks were milling.
    -Test fit.:D
    -Gluing was tough. I had to let the glued bits sit for at least an hour before I could try to knock the guide plug out.
    -While I was on the back porch gluing, I noticed something just outside the screen door. Around this time of year, these wander away from the waterways, killing everything in their path. Lucky for me I know an Italian plumber who took care of the problem. I still don't know how this guy got through the fence...:eyebrow:
    -I made the mistake of putting this part together without sanding it properly. I decided to try using lapidary grit to sand it out.
    - I figured out I need more grit than my stingy self spooned out. It didn't stick to the felt very well either.
    -Mach was awesome enough to loan me his 1/4"BSPP tapping die. I'm not posting pics of the process because it might incriminate me. Let's just say you shouldn't loan stuff out to anyone named, 'cheap-'.:hehe:
    I tapped less than a foot of 1/2" plexi rod. -Honest!
    -Here's some of the tapped rod ready to be milled even.
    That's it for now
    Thanks again to my sponsors
  7. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Awesome man, nice work on the acrylic mate! Did you estimate how much is going to weigh?
  8. Cheapskate
    13 May 2007
    Thanks. The billet for the core weighs in at 2 pounds right now. I have no clue how much everything will weigh.
  9. skreenname
    skreenname SFF Forever
    11 Jun 2009
    How much is all this acrylic costing you Cheaps?
    If you don't mind me asking, that is.
    I can't help but to be curious.
  10. Bad_cancer
    7 Apr 2009
    Did it involve a spanner? or maybe worse a pair of pliers? Or should I really not ask?
  11. perplekks45
    9 May 2004
    I got him to update so shut up you lot! :p
    I really can't wait to see how this all looks assembled, mate! :thumb:
  12. Azayles
    Azayles Minimodder
    6 Jan 2008
    This is like a "guess the babies weight" competition :p
    My money's on 70 pounds.
  13. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Hey Cheaps, I finally posted something so you can stop being confused.
  14. Djayness
    7 May 2008
    Are you guessing the case weight or with everything including water in it as well?
    I made what I thought was a fairly lightish case turn and had it turn out to be a 39kg monster. Most of it was 6mm thick acrylic but with this case, theres just SOO MUCH plastic all over the shop.
    My money is on 45kgs with everything in it.
  15. skreenname
    11 Jun 2009
    I'm going to go with 80 - 100 pounds.
  16. Azayles
    Azayles Minimodder
    6 Jan 2008
    Sans water. Unless he fills it up and it's 70 pounds on the nose :p
  17. Cheapskate
    13 May 2007
    Thanks, guys.:D
    I'm hoping it's under 60 pounds total.
    Cost? Not including 4 shipping sessions, the plexiglas is running about $430.:jawdrop:
  18. talladega
    talladega I'm Squidward
    18 Aug 2007
    It's gonna be over 9000 lbs!
  19. Azayles
    Azayles Minimodder
    6 Jan 2008
    Over 9000? :eek:!
  20. Djayness
    7 May 2008
    Yeah if Cheaps is using it as a footrest whilst gaming :p
