How big is your...PSU?
Discussion in 'Hardware' started by identikit, 18 Sep 2008.
PSU size?
  1. 0 - 399
    7 vote(s)
    5.1%
  2. 400 - 599
    64 vote(s)
    47.1%
  3. 600 - 799
    47 vote(s)
    34.6%
  4. 800 +
    18 vote(s)
    13.2%
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Not quite. The HX series are designed and built by Seasonic, and no other power supply uses that platform. Channel well builds several specific units, namely the TX 750. That one is an improved 750w platform that is the same as the thermaltake toughpower 750.
  3. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    The HX1000W is also made by channel well technology, as far as I know it's only the HX620W and 520W that are made by seasonic.
    Moriquendi
  4. Jipa
    5 Feb 2004
    Wow guy! You use a power supply with over three times the output required and it works fine lol!
    Seriously a banger like that most likely maxes at around 200-250 watts (AC).
    ALSO about the HX-series; atleast Xigmatek 1200 W uses the same design as HX1000.
  5. ComputerKing
    8 Sep 2006
    LOL Jipa, Fair enough.
  6. atanum141
    22 Jul 2004
    +1 Also they have limited flex on the ATX cable.
    Been thinking to trade for a HX520 just for the better cabling.
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Corsair 550VX powering:
    Asus P5Q-E
    E8400
    Ati 4850
    DVD
    HD *2
    Fans
    2*2 gigs ram
    Eventually will add a WC loop to it.
    Seriously, it's much better to buy the capacity one needs on a quality PSU and spend more on other parts, than to spend more on PSU which provides too much of an excess of power. Some overhead is good, but 1000W for a system that can get buy with 450W is a total waste of (financial) resources.
    Also have a Corsair 450W powering:
    E7200
    Asus P5Q-pro
    Asus 3450 passive
    2*1gig
    Hd
    DVD
    fans
  8. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    530W Tagan
    May have to upgrade it soon, as i must be running it near it's limit when i overlock my CPU, the heat coming from the PSU fan is worryingly hot and it gets a bit loud :lol:
  9. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Hiper 770W Type M
    powering:
    AAM AthlonX2 5000 (AM2)
    DFI NF590sli
    ATI X1900xt
    Audigy 4
    3X500gb hard drives
    2Xoptical drives
    7x120mm fans running at 5v
    and about 30x LED's and lots of usb's
    The psu is a bit longer than most psu's, and it has a quiet 80mm fan in the rear, dont think i have ever heard it make any noise over the rest of the pc.
    Recomended Wattage comes to about 400W on a psu calculator :p
  10. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    So how much does 2x4870's draw, and what about 3 (As in whole system draw)?
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    so many Corsair Hx series.......
    and here's another Hx620w :)
    powering: quad core q6600 at 3.4Ghz, 8GB RAM, 1 7200rpm (soon to be 2) + 1 10k rpm, 8800GTX overclocked to Ultra speed and 6 120mm fans.
    The machine is Folding (for Bittech) whenever possible on both quad and GPU. soon to have gtx280 or 55nm variant put into it.
    so i guess usual power drawn would be around 300, and with gtx280, it'd be about 350?
    Bittech members don't go overboard with PSU, everyone's educated :)
  12. Ninja_182
    Ninja_182 Enginerd!
    2 Apr 2002
    Some non-brand 500W jobbie running:
    Athlon X2 4000 at 2.5Ghz
    ATI 4850 pushed up a bit (cant remember how far)
    Some ram
    MSI K9A2 CF
    2 Hard drives, 1 Optical
    4x 120mm fans and 2x 80mm if you include PSU
    No bashing of my poop power supply, my system is stable and theres cold air coming out the back under load :p
  13. Bbq.of.DooM
    12 Feb 2005
    The HX 1000, VX 550, and TX 750 are CWT. The VX 450, the HX 520, HX 620, and TX 650 are Seasonic.
  14. |I.H|
    |I.H| What's a Dremel?
    4 Dec 2004
    Corsair HX620w :)
  15. Horizon
    Horizon Dremel Worthy
    30 May 2008
    I have a Tt Toughpower 750w, and a PC&Power 750 Quad
  16. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    They draw a true, honest 130 watts each at full load. This isn't a manufacturer specification or suggestion; it's from actual test data. Obviously, two or three of them will be quite thirsty and you'll want to plan your PSU accordingly.
    I wish manufacturers would concentrate a bit less on speed and a bit more on efficiency. My whole system draws barely more than that single card...
  17. Stuey
    20 Jan 2005
    It seems that you're already aware that your PSU is poop and bash-worthy, so we'll leave you alone. For now. =P
  18. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    700 Seasonic M12 powering an E8400 @ 3.6GHz. 2x 9800GTX in SLI, 4 disk RAID5 array + 1 system drive.
  19. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    BFG 650W
    freaking awesome :clap: :hehe:
    Also some of the other reviews are hilarious.
  20. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    PCP&C 750 Quad and OCZ ModXStream 780
