How big is your...PSU?
Discussion in 'Hardware' started by identikit, 18 Sep 2008.
PSU size?
  1. 0 - 399
    7 vote(s)
    5.1%
  2. 400 - 599
    64 vote(s)
    47.1%
  3. 600 - 799
    47 vote(s)
    34.6%
  4. 800 +
    18 vote(s)
    13.2%
  1. identikit
    identikit Minimodder
    5 Jun 2004
    So how big is it really? Plus what does it power? Also is it modular and does it have a 135mm fan or something else?
    Mine was a Silverstone 650W ST65ZF-GM (non-modular) and it powered:
    a dual CPU s771 mobo
    2 Xeon E5320 CPUs
    4 FB-DIMMs 1GB each
    8600GT video card
    2 SATA HDDs
    3 fans (120mm x 2 and 92mm)
    PCI-e soundcard
    Estimated power consumption 300W
    1 fan at the rear and it was LOUD!
    That's it nothing else. Well until it broke and now I use a 500W Nexus PSU (non-modular), very quiet.
    So what powers your computers? If multiple choose the highest rated PSU.
  2. GoodBytes
    20 Jan 2007
    Corsair HX620W is what I have, this thing is so quiet, I thought after the first time I plug-it in, that the PSU fan wasn't turning, but it was.
  3. Krikkit
    21 Jan 2003
    Tagan 480W modular here - brilliant PSU, dead quiet. The only way it could be better would be to have nicer plugs at the PSU-side, they're a little sharp-edged and fiddly to get in and out when they're surrounded with the rest of 'em.
  4. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Coolermaster 620W M-Power, good "budget" PSU, compares to an HX620 the way I run it.
  5. theevilelephant
    theevilelephant Minimodder
    5 Jan 2006
    Hiper Type R 580w modular, a bit loud but a nice product all the same, soon to be replaced with a 620W or 650W corsair
  6. 3dHeli
    3dHeli What's a Dremel?
    25 Jul 2007
    Dell Vostro 410 which came with 350w Delta Electronics DPS-350VB-1B.
    Only just has enough connectors for my needs . . . can put one more SATA HDSC in. Neatly wired in the case as standard - cables just the right length - not modular.
    Power drawn from the wall plug is 14 watts standby, 117w at idle, and 167w at peak load so far.
    That's with Photoshop doing heavy batch processing, ProShow Gold rendering, a virus scan running, DVD movie playing, and me doing some surfing . . . can't think how to load it any more (other than games which I don't use PC for) . . . . even with all that going on it was surprisingly responsive.
    Guess - in very simple terms - until I get to about 260 watts at the wall plug, I probably won't need anything bigger for a PSU.
    The PSU looks after;
    Q9300, 4gb RAM, 2 x 1tb Seagate 7200.11, 1 x 500gb WD Cavier SE16, NVIDIA 8800GT 512mb
    2 x DVD Writers, Card Reader, On board Sound & Ethernet
    1 x 120mm Fan, 1 x 92mm Fan, 1 x CPU fan
  7. UrbanMarine
    UrbanMarine Government Prostitute
    7 Aug 2008
    Antec TruePower Quattro 1000W PSU
  8. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Enermax Infiniti 720W, an upgrade from the 500w Liberty that I had during the brief SFF phase.
  9. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    1200 watt NZXT and a 600 Watt Meanwell auxiliary... :thumb:
  10. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Talk about overkill. I bet you don't even use more than 500W.
    Enermax 600W PSU. More than enough power, infact complete overkill for the load I'm putting on it.
  11. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    I wanted to make sure that my psu would never be an issue when adding future bits so I went for an Enermax Galaxy 1000w DXX, awesome bit of kit.
  12. specofdust
    specofdust Banned
    26 Feb 2005
    I bet he doesn't use more than 300W at full load.
    I run a 500W seasonic in my main gaming rig, and a 330W rig in my server, which has up to 9 HDD's in it depending on the config of my RAID (which changes every 6-8 months). You don't need a high rated PSU to power your rig. You just need a quality one.
  13. samkiller42
    25 Apr 2006
    Corsair 1000w HX (Modular)
    780i SLI Motherboad
    Q6600G0
    BFG8800GTX OC
    2 WD Raptors 74gb
    WD 640gb
    WD 400gb
    4GB Ram
    DVD Drive
    4 120mm Fans
    2 92mm Fans
    Aquaero
    Soon to be powering:
    Dual 280 GTX H20C
    Pump
    Cold Cathods of some sort.
    Sam
  14. hodgy100
    hodgy100 Minimodder
    2 Jun 2008
    I have a Corsair 550W-VX but i havent used it yet so i cant comment on how well it works
  15. craigbru
    28 Feb 2008
    The 1200 watts is most definitely overkill. However, when Johnny at NZXT offered me one for my project, it was a little hard not to want the biggest they had... :D
    I'm sure I'm utilizing most of the Meanwell PSU however. It's a 24 volt unit dedicated to powering the TEC cooler. (subzero temps don't come without using a little power :rock:)
  16. wolfticket
    19 Apr 2008
    1935 Cubic Centimetres (ish)
  17. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
  18. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    A mid end tagen ~500w i think, my machine doesn't draw more than 200w from the wall though. Although my day to day machine has a 60w psu.
  19. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Corsair HX620W driving
    Supermicro X7-DWA dual s711 mobo
    Two X xeon e5420, quadcore at 3GHz
    Four 2GB Fbdimms @ 800MHz
    Geforce 8800 GTX @ 630MHz x 1000MHz mem
    Quadro FX1500
    Three SATA hdds.
    Maximum recorded power consumption... 400w, consider that the next time you're shopping for a PSU.
    Moriquendi
  20. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Antec 850W, didn't want all that power but its got what i needed, 6+2 PCI-E cables. So if i have some spare cash then SLI GTX280 on a X58 wont be such a problem...
