How !!! Windows !! Bit !!!
Discussion in 'Tech Support' started by ComputerKing, 4 Jan 2007.
  1. ComputerKing
    8 Sep 2006
    Thanks :D GOOD LUCK . CK
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Yeah, forgot they kept the zero in there. Sorry about that.
  3. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Don't bother going Vista x64, I tried it and it's basically the same as x86 apart from it has not support for my tv card.
    No difference in speed.
    So unless you have 4GiB+ of RAM do not even bother.
  4. ComputerKing
    8 Sep 2006
    ohhhhhhhhhh YEAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
    WHOOOOOOOOOOOOOOO THE KINGGGGGGGGGGGGGG
    IM DAMM HAPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPYY
    I JUST GET MY VISTA COPY AND INSTALL IT !!!! NO DRIVER INSTALLED !!!
    CHECK I LOVE IT 64-BIT !!! WHOOOOOOOOOOOOOOOO THE KING
    COMPUTERKING
  5. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    i wish i could get as excited over an operating system.. oh wait.. no i don't!
  6. ComputerKing
    8 Sep 2006
    man what you mean !!!
    man wtf ,, My vga drive dont want to setup !!!!
    thanks !!
  7. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Your vga drive??
  8. ComputerKing
    8 Sep 2006
    yeah my ati card dont want to install !!! it say not support drive !!!!
    thanks > CK
  9. overdosedelusion
    29 Oct 2006
    you need the 64 bit drivers, the 32 bit ones (the ones on the CD) will not work. head over to ATi's site and get the x64 vista drivers
  10. ComputerKing
    8 Sep 2006
    oh yeah I just get all my 64-bit drivers !! still the hp they not out yet lol :D
    Thanks guys to make me buy this windows :D thanks
    Good luck and keep going and take care , bye , CK
  11. drag
    drag Banned
    19 Dec 2006
    please more info !
  12. ComputerKing
    8 Sep 2006
    OH, Mr.Ramble , Vista 64-bit With my hardware Work Perfect !!! dam speed and smooth !!! so why you say this !!! I don't know what you think , Tell me if I said some thing wrong !!! Correct me :idea: Thanks , Keep going , CK
    Edit : my hardware on my Sig...
  13. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    I had the same problem with my BLT drive going AWOL. The solution ended up being to reinstall windows with a version that's not pirated and has been released to consumers
  14. overdosedelusion
    29 Oct 2006
  15. ComputerKing
    8 Sep 2006
    Who care , This windows Rocks , The best ever !!
    BTW : I will install my xp and the vista better :D
    Because XPSP2 32-bit and the Vista 64-bit :D
    Thanks and , Good luck for all who will get vista , It cost but it worth :D
    Bye , CK
  16. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    You actually bought Vista? Lol... it works now but don't expect to get anything new that works until 6 months from now when x64 is at least slightly covered...
    Right now, it's like Linux, it's covered but only with special stuff and the product was made for x86 then ported over with special drivers...
  17. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    How does it show 2047MB Ram?
  18. DeX
    DeX Mube Codder
    22 Jul 2002
    It's 2GB. Why shouldn't it?
    I was suprised to find out that Core 2 Duos were 64bit as well. I haven't heard anything about that since it was released. Surely 64bit is the way to go though. It may not run things faster at the moment but in theory you can do a lot more with 64bits than 32bits. 64bit games should become faster. Plus we're likely to be using more than 4gb RAM in a couple of years time. Why is 64bit seemingly so unpopular?
  19. ComputerKing
    8 Sep 2006
    Yeah I bought it < It's Run Very good , But Not all Programs and drivers Available for it now :D But I will Wait !!
    I'm using Vista 64-bit and XP 32-bit on the same computer to have both 32-bit and 64-bit :D :hip:
    Lola You Are right Awesome !!!!!
    Core 2 Duos Are The Best Of the best !!! I bought The 6600 With No Idea About it ! SO By The time We will Learn , Right :D
    OK I hope Every Guy here get copy From Vista It's Dam COOL
    Good luck Guys . Take Care , BYE < CK
  20. crazydeep74
    25 Jul 2005
    1024 + 1024 = 2048
