Education I didn't invent this miracle fix but I still need to share it
Discussion in 'General' started by knuck, 9 Nov 2011.
  1. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Fixed that for you. :thumb:
  2. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I thought your name was PowerGlove Boy? Well done for having the balls to do this though.
  3. knuck
    knuck Hate your face
    25 Jan 2002
    awesome :rock:
    meh, it was either this or try-nothing-and-get-nothing
  4. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I've got a dead HD4870, I wonder if it's worth giving this a try. I'm only going to throw it out otherwise...
  5. knuck
    25 Jan 2002
    What's the problem ? If you have "fixed" artifacts (memory glitches) then it won't help.
  6. Lord Xeb
    Lord Xeb Derka Derpa Derka Derp
    7 Jan 2010
    I baked a few graphics cards back to life, same with Xbox 360s (except the final revision before the slims)
  7. boiled_elephant
    14 Jul 2004
    Mine never artifacted, it just went way too hot one day due to a badly arranged case (crossfire troubles) and then refused to boot after that. It got to about 95 degrees, which is far hotter than it's ever gotten before. I can't see that it would have damaged the GPU at those temps, though, so baking might be in order.
  8. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    You guys need to find your way to this place: The oven trick. We have hundreds of success stories of "Baked" GPUs, motherboards, etc.
    :D
  9. Unicorn
    25 Jul 2006
    Ah, gotcha :thumb: Sorry, I took your comment quite literally ;)
    Hah, well that's true. I have used the heat gun on several consoles for a quick fix. Sometimes it's very effective but I still feel much more comfortable using the Heller!
    It's not difficult if you have the required equipment. It's extremely fiddly, so you need to have the patience for focussing on a 10cm square on a bench for about half an hour at a time. There are several tutorials online, but it's an expensive process. The templates, the solder balls, the flux and the small hand tools are not that expensive. The reflow stations for removing and reflowing BGAs though, run into the thousands of pounds. I don't have one, again I use a station at the electronics plant up the road for it, or just put it into the Heller oven and reflow the whole board. That's not preferable though, you really want the reflow station so that you can concentrate the heat on the particular BGA that you are working on.
    Basically what you need is the following:
    Liquid/paste flux
    Spludger, tweezers, small brush
    Solder balls of the right diameter
    BGA template to suit your chip
    Solder mop braid
    Rework station/temp controlled soldering station
    Reflow station
    Holy crap, you're back! Haven't seen you around in ages :eek:
  10. Tribble
    Tribble Steals Avatars
    14 Oct 2011
    i might try this with an old 8800 gts i have sitting around, it died after being stored for a few months.
  11. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Did something similar with a Samsung 30" monitor a few weeks back, used the heat gun to do it thu. Has been working fine for a month+ since :D
  12. Xir
    Xir Modder
    26 Apr 2006
    sooo, what temp-times did you use?
  13. knuck
    25 Jan 2002
    8 minutes @330F (pre-heated)
  14. boiled_elephant
    14 Jul 2004
    Is that the same for fan-assisted ovens? :lol:
    (Seriously, though, my oven is fan-assisted and I don't want to melt my graphics card into a hideous acrid blob.)
  15. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Whenever I use the oven my sister automatically assumes i'm cooking cards.
    Please post pics if it does end up like this.
  16. boiled_elephant
    14 Jul 2004
    Oh, I will.
    I'm waiting for my mum to be out of the house, so I don't have the dual shame of (literally) frying a graphics card AND having my own mother realise she's now surpassed me in computer wisdom.
  17. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Did this with my Xbox 360 and it fixed the rrod for about a month.
  18. knuck
    25 Jan 2002
    By the way, you'll need some febreeze because there is a chance it'll smell like hell. There was glue on the board from several stickers that were indicating which port was what (ddr2, wlan etc) and the smell from the molten glue was quite strong in the house
