Hardware Ikonik RA X10 SIM
Discussion in 'Article Discussion' started by Tim S, 11 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Cadillac Ferd
    Cadillac Ferd What's a Dremel?
    11 Oct 2005
    I'm all for supporting new companies trying to make their way in a tough market but honestly... you want me to pay $350 for a case AND YOU'RE STILL GOING TO PUT CHEESY PLASTIC CRAP ON IT?
    What the hell guys, better luck next time.
  3. stonedsurd
    11 Mar 2009
    QFT
    And what's with the SHINY aluminum interior? Even a brushed finish woulda done the job.
    Although that means very little in present company :p
  4. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    90mm fans all around. why not 120mm with room for quad water cooling? 90mm spacing is useless in cases, also bring de PSU to the bottom, ditch the whole topsection and replace with a roof that has about 60mm space above motherboard to fit rads+fans.
    Its just a Epic fail in my book. And knights armor helmet thingy as a door? Doors are so ninetees. come on think of something better. Gimme a call I have hundreds of ideas to make a case better, infact you can contact anyone in the casemod section on BT, yeah thats right we actually make a expensive case look more expensive when we are done! Damn what the hell are the so called case designers thinking about when designing a PC case... Probably "space1999" reruns....
  5. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    doors..... fail. but thats just my personal taste.
    and that many fans means that many possibilities of failing hardware and replacement, not to mention the power it uses...
  6. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    For that price the case should have a lot more features:
    * Large beverage holder
    * Tail fins
    * bubble domes
    * installed shag carpet
    * PC speaker that plays "La Cucaracha" on startup
  7. The Bodger
    The Bodger What's a Dremel?
    26 Dec 2003
    Lol... love it!! (Starts rummaging in drawer for dremel and cutting slab of carpet out from under the wardrobe in the spare bedroom) :dremel:
  8. JonDixon
    12 Mar 2002
    Well if its good enough for Homers' car then its good enough for my PC
  9. fathazza
    fathazza Freed on Probation
    20 May 2002
    finally! A case uglier than my HAF932
  10. naokaji
    naokaji whatever
    8 Dec 2006
    285 for a case that still has so much plastic? are they nuts?
    Also, if they would have used 4x120 fans at the bottom instead of 4x80 at bottom and top it would be far more appealing for WC.
  11. wolfticket
    19 Apr 2008
    Am I the only one that thinks the 6/10 score may be a little *ahem* generous :eyebrow:
    But hey, it's not like I have looked at the case personally and in the end it is a subjective decision :worried: :thumb:
  12. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    Wow. I looked at the case first thinking it was another £60 wannabe high end case then noticed the retail price. I think they're aiming a tad too high, it looks ugly and cheap, the layout isn't that great and whats with all the fans.
    You can't polish a turd, but you can try and sell one for £285 :rolleyes:
  13. The boy 4rm oz
    10 Apr 2008
    Well the fan controller software seemed to work pretty well, they should sell the unit as a seperate product, they'd make some cash outa that.
  14. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Well, Ikonik doesn't have a clue about the current case market do they?..Maybe they need to hire somebody who does.
    or focus on making cooling fans instead..lol
  15. Guest-16
    Guest-16 Guest
    Well their design team is ex-Gigabyte and others, so they should, although Gigabyte cases have never really been desirable tbh...
    Shame really, so much potential.
  16. Bluefan
    Bluefan test 123
    25 Feb 2005
    I think the GPU stress test doesn't really represent the cooling capablilities. The airflow directions are probably designed for the average gpu cooler. This asus card neerds airflow from a complete different directions (front to back), as the cooler is in the cpu area instead of the expansion slot area, which may just be very good cooled by this case.
  17. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    sorry for the lateness, are you going to review the watercooled version?
  18. Felstriker
    Felstriker What's a Dremel?
    10 Nov 2012
    Found this review today. Sad to see you write that the top is made of plastic when it is sandblasted aluminium in a very elaborate shape. Even if the review is old you need to revise it.
Tags: Add Tags
