Scratch Build – In Progress INVERTED by ToB1
Discussion in 'Project Logs' started by ToB1, 19 May 2010.
What color should I have on the plexi I'm going to use for the feet?
  1. Clear
    8 vote(s)
    15.1%
  2. Smoked gay/black
    23 vote(s)
    43.4%
  3. Red
    21 vote(s)
    39.6%
  4. Other (Specify!)
    1 vote(s)
    1.9%
  1. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Cool. Nice work
  2. Remmes
    Remmes Be One With Your Mod
    24 May 2010
    lol at the poll.. smoked gay/black .. smoked gay XD.. lmao
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    yay for round feet & ghetto lathe!
  4. ToB1
    ToB1 What's a Dremel?
    18 May 2010
    Thanks for the feedback! :)
  5. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Looks good i like the wood.
  6. ToB1
    18 May 2010
    New sponsor: Phenoptix
    Phenoptix have agreed to sponsor the project with red 3mm LEDs!
    Thank you very much for your contribution! :D
  7. ToB1
    18 May 2010
    The package from Phenoptix has arrived!
    Phenoptix is sponsoring with 32 red 3mm LEDs that will be used to light up the feet and the back of the motherboard.
  8. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Looking forward to seeing them in the feet, I see the smoked gay is in the lead, wonder if the typo has anything to do with that!
  9. ToB1
    18 May 2010
    I exclude smoked gay, so I'm pretty sure I'll go for the red plexi ;)
  10. ToB1
    18 May 2010
  11. ToB1
    18 May 2010
  12. ToB1
    18 May 2010
    Because the old feet came out a bit smal, i decided to make a set of new ones.
    This update wont be that interesting since you've seen this part before.
    This time I used a 57mm hole saw, which means that the diameter of the feet got about 1cm longer than last time.
  13. ToB1
    18 May 2010
  14. ToB1
    18 May 2010
    I got wires, tips for det soldering iron, experiment card and 3mm LED-holders from Clas Ohlson yesterday, and I've done some work on the frontpanels.
    The guy I'm planning to order plexi from is om vacation, but I think you get the idea of what the feet will look like...
    The inner frontpanel...
    The outer frontpanel...
    I've cut the motherboard tray so it looks a bit better, and dont use to much of the space at the rear end of the case.
    And here's a test to show you how the LEDs will be mounted on the motherboard tray...
    I've also made a test on how the fan controller will be mounted on the front panel, and I hope to post som pictures of that soon.
    What do you think about the project som far?
  15. ToB1
    18 May 2010
    A few weeks ago I got some new hardware, but unfortunately I've had a lot of things to do lately.
    But anyway, here's some pictures of my new motherboard, CPU and RAM-modules :)
    I've got a pair og WD Caviar Black 1TB 64MB as well, and pictures of does might come later.
    - CPU: AMD Phenom X6 1090T
    - RAM: Corsair Dominator GT 2x2GB 1600MHz
    - Motherboard: Asus Crosshair IV Formula
  16. ToB1
    18 May 2010
    Sorry for taking so long, but here's a new update!
    Testing the LEDs for the feet:
    Mounting and testing of the LEDs on the motherboard tray. Unfortunately 2 of the diodes seems to me a bit defect, and on of them doesn't work at all :(
    Mouting hinges on the to sidedoors:
    Testing the holes i made for the locks:
    Milled/Routered an edge so the motherboard tray will be mounted tighter:
    76mm-hole for the rear 80mm fan:
    The content of the package from performance-pcs.com. Unfortunately I got a 3mm thick panel of acryl instead for 5mm thick as I ordered. Therefor I ended up buying 6mm thick clear plexi for Clas Ohlson.
    Hope you like the update, and I promise to post a new one soon!:)
  17. Arnakke
    Arnakke What's a Dremel?
    6 Jun 2007
    ToB1,
    Is there any chance of you taking and showing more complete pictures of the wooden case?
  18. shadow19935
    shadow19935 Whats overclocking? :D
    17 May 2010
    That would look kick ass!!
  19. shadow19935
    17 May 2010
    iwe seen lots of MDF projects lately, but this looks something extra cool
  20. ToB1
    18 May 2010
    Yes, I think I'll be able to take some pictures of that, but it might take a few weeks :(
    Thanks! I'll upload another update during the day, and then you'll se more pictures of the feet! ;)
    Thanks! :)
