Blogs Is it a monitor, or is it a TV?
Discussion in 'Article Discussion' started by Sifter3000, 10 May 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Instagib
    Instagib Minimodder
    12 Mar 2010
    Can i have free stuff?
  3. wyx087
    wyx087 Multimodder
    15 Aug 2007
    1080p on a 27inch monitor?
    agree with Bindi, we need more Dell U2711 or iMac 27inch kind of resolution monitors, 2560 x 1440 for 27inch sounds about right for a desktop monitor.
  4. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Most likely this is aimed at the bedroom HTPC crowd?
  5. scrimple3D
    scrimple3D What's a Dremel?
    29 Apr 2009
    I agree with wuyanxu.
    After having a look at one of the those iMac 27" models, I'd like a 27" screen of that sort of resolution, but the prices out there are a bit crazy.
  6. Xir
    Xir Modder
    26 Apr 2006
    ...you have a 24" and had to "beg" for a secondary one? :D
    On secondary note, why do you accept a monitor that Bit-Tech wouln't review?
    Or better said...review more cheap large monitors!
  7. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    hmm they need to do a 22/24 inch version!
  8. phuzz
    phuzz This is a title
    28 May 2004
    Our sony TV has great built in speakers, but that's because it's one of the last of the old school MASSIVE CRT screens, so there's plenty of spare room for decent sized speakers.
    My mate has a 40" Sony LCD which has pretty nice sound, but it just lacks any kind of bass. That's the trouble with these fancy newfangled flat screens, no room for decent speakers :(
  9. shadeygrey
    shadeygrey What's a Dremel?
    19 Jan 2008
    Its not a TV unless it has a remote!
    i used to have an asus "confused" monitor, with speakers and more inputs than i ever needed like: component, composite, vga and dvi
    So i had sky and the xbox hooked up when the misses was watching girly crap on tv.. but with no remote meant little ol me had to keep getting up to adjust the volume etc.. so i sold it and bought another TV ;) (oh and a 30inch dell muha)
  10. wawa
    wawa Addicted to Cube2
    21 Feb 2010
    i still have an older samsung t220HD which has every connector under the sun, a remote, and works with everything. great as a bed tv/monitor mounted on the wall.
    btw, for the asus^^ there are right-angle hdmi cables out there, just like s-ata
  11. ripmax
    ripmax Minimodder
    8 Apr 2010
    Yeah TV's need a remote, so this is just a monitor with some extra pointless inputs.
  12. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I rather have a 240hz HD 42" rear LED TV without thick bezels, speakers and useless other stuff. Just a power and HDMI connector on the bottom (not the rear) to connect to my surround setup.
  13. dec
    dec [blank space]
    10 Jan 2009
    Careful, they might have sent you a GTX 480 tri-SLI PSU instead.
    Asus should just go all the way and put the RF input and TV tuner in it then sell it for $200
  14. Gonzalo-Gonads
    Gonzalo-Gonads What's a Dremel?
    14 Dec 2009
    This is a TV
  15. rickysio
    6 Jun 2009
    He's going to put it on a desk.
    Desk.
    Try gaming with a 42" in front of your face.
  16. mighty_pirate
    mighty_pirate What's a Dremel?
    23 Apr 2010
  17. saspro
    saspro IT monkey
    23 Apr 2009
    Is it a monitor, is it a TV or is it a slow news day?
  18. Azayles
    Azayles Minimodder
    6 Jan 2008
    To answer the title of this post: It's not a TV as it lacks a TV tuner. While it has a composite video input, and you could easily hook up a freeview box or whatnot to this, the monitor itself has no means of picking up a TV signal.
    So it's just a fancy shmancy monitor :)
  19. Arj12
    Arj12 What's a Dremel?
    6 May 2010
    To my mind what makes a TV is not just the TV tuner and a remote but the inclusion of scart (I wonder when Scart will start to be fazed out. Anyone know?)! I might just move to Taiwan from the sounds of things! Quiet a few people on this site seem to get free stuff; be it for journalists or sponsorship for modders!
  20. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Hang on.. Wat?
Tags: Add Tags
