Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. David
    7 Apr 2009
  2. Goatee
    Goatee Multimodder
    19 Apr 2015
    Both are HJ 17mm radiators: https://www.aliexpress.com/item/1005001355750857.html
    I think they aren't as good as something like a TX but the thicker 25mm fans allow much more air flow into the case, so better non-watercooled board / SSD component temps.
    David and Arboreal like this.
  3. Vault-Tec
    30 Aug 2015
    They look like Watercool's Heat Transformers. Glorious !
  4. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Apparently they're doing a black version relatively soon. Although a copper one would go with my mono-block nicely.
    Also, great too for the double-rad setup, but then I've heard it doesn't make that much difference to cooling.
    N.B: Apparently the T1 does much better with the rad at the top. May be worth flipping the orientation.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Rad on the top is marginally better cooling, but shitty for loop bleeding.
    More importantly for me it also means the space I’m currently using for the RES is under the pump in the flipped layout, so is Really really shitty for loop flow!
  6. Ending Credits
    4 Jan 2008
    In case anyone is interested, the fans I ordered arrived today. They are indeed Fanner fas, but are 15mm unlike the 12mm advertised. Very similar to my akasa slim fans, but translucent blades, black cable, and very slightly thicker shroud.
  7. jinq-sea
    15 Oct 2012
    Bah. nCase no longer shipping to the UK by the looks of their website. Thanks, Brexit. Thexit.
  8. David
    7 Apr 2009
    Wow, that sucks the big one.
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Due to Covid rather than Brexit, according to them.
  10. jinq-sea
    15 Oct 2012
    It was all OK up until the end of Dec, but yes - I concede it could be COVID.
  11. Arboreal
    21 Jan 2011
    Dammit, that is a BIG disappointment.
    'Luckily' someone on ebay UK has a new v6 for only £325...
    /Leans across desk and hugs battle scarred custom M1 V5.
  12. David
    7 Apr 2009
    /leans across desk and strokes M1 v5 and asks, "what do you want to wear today, my dear - black or silver?" :lol:
    BeauchN likes this.
  13. jinq-sea
    15 Oct 2012
    Ah well. It'll come right in the end and I'll get another!
    Arboreal likes this.
  14. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    They say themselves: "Due to reduced flights worldwide as a result of COVID-19 it's not possible to ship air mail to many countries from Taiwan. In addition, shipping and customs processing may be significantly delayed to the countries we can ship to."
    Either way, it's a big shame. I'm very happy with my (third-hand) v2 but you never know when temptation will strike!
  15. enbydee
    enbydee Minimodder
    10 Jul 2014
    Wonder if that's why the thermaltake case I ordered in November still isn't in stock. I cancelled it in the end.
  16. Arboreal
    21 Jan 2011
    Sounds like a bit of an inappropriate relationship there, David :naughty:. Part of me is regretting not getting new panels as a couple of mine have noticeable wear from previous owners.
    I decided not to in the end as it was being card to LAN night weekly, those were the days...
    As the frame paint was worn and flaking I had it resprayed and clear coated by a guy respraying a VW T5 the colour I was looking for - metallic graphite.
    I'm sure it will; a bit of patience and world sorting will make it all the sweeter when it arrives at Jinqs Towers.
    @bawjaws, my v5 is also third hand AFAIK. I got it from @Goatee, and he didn't have it from new from what he said.
  17. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    The only slight worry I have with my case is that it's fairly easy to strip threads - fortunately I don't tinker with my case much at all these days, but if I did then there are a couple of threads that aren't far off being totally stripped. Would be sad times if that happens.
  18. Arboreal
    21 Jan 2011
    True, one of the GPU support screw threads is feeling iffy, but I'm not changing anything regularly. I guess I could tap a larger hole with a new screw, or glue a nut on the back. if it comes to that.
  19. David
    7 Apr 2009
    just drill em out and re-tap to a bigger size - slight PITA but it's worthwhile - I've done that with a couple of rads in the dim and distant.
    [edit] Scrap tapping them out to a larger size - I forgot about Rivnuts.
  20. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    I bought a V6.1 in November. It's still upstairs in the box as i was waiting for AMD and Nvidia to sort supplies. May just be worth waiting for the next generation at this rate.
