Modding Keypad to enter code and start PC
Discussion in 'Modding' started by WizardLock, 16 Nov 2003.
  1. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    yay, cumes link is what i've been looking for
    one question tho, anyone know why you have to do it a diff way for windows? is it just cuz windows has the thing where you have to hold down the power for a few secs to turn it off. if thats all, you can just turn that off so it shuts down w/ one press :confused:
  2. MrDT
    MrDT fapfap
    14 Jun 2002
    start : keycode
    shutdown: start>turn off computer>shutdown
    :rolleyes:
  3. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    For windows you want the switch in case it crashes(and when doesnt it!) to hold in.
    If nothing else you can try to find a reg hack or something to force shut down immediatly.
  4. MrDT
    MrDT fapfap
    14 Jun 2002
    if you program a pic you could have one code as momentary, one to hold for a few secs.
  5. diskreet
    1 Oct 2003
    i wonder if you can hold enter for a few seconds? im assuming no from the article, but maybe he didnt even try. who knows?
    maybe not though, cause it might ruin a garage door opener?
    answers anyone?
  6. Fatboy
    Fatboy Bored
    8 Oct 2001
  7. MrDT
    MrDT fapfap
    14 Jun 2002
    from a quick look, one is a ready made product that will do power on. one of the two pads on their own combined with a pic would be a lot better ;)
  8. TekMonkey
    6 Dec 2002
    you would need to program a pic for those maplin ones, wouldn't you?
    i don't know how so thats out of the option
  9. MrDT
    MrDT fapfap
    14 Jun 2002
    the second link seems to be a pre-made product
  10. diskreet
    1 Oct 2003
    Well, if you are an electronics bum like me who can barely figure out how to calculate the right ohm resistor to use with an LED then get something that is ready to go out of the box.
  11. TekMonkey
    6 Dec 2002
    I'm still a little confused. What would happen if you wired it up the "linux way" and ran Windows. I don't care about proper shutdown and stuff, I just want to type the code to turn it on and then I don't care how I turn it off, because I just want nobobdy to be able to turn my computer on, I don't care so much about off.
  12. diskreet
    1 Oct 2003
    you can shut down normal in windows, Ctrl+Alt+Delete shut down, or pull the power plug.
    The only reason he kept a switch for windows is in case he neded to hold it down to force power off.
    Otherwise, its no different, just a safeguard over pulling the power out while on.
  13. Mightybob
    Mightybob What's a Dremel?
    5 Sep 2003
    any keypad would be easy as to bypass to anyone that knows anything about an ATX computer. All you have to do is short out the pins connecting the keypad to the motherboard.
    It would still look :eeek: at lans and things like that. "Oh just hold on a sec, ill turn my computer on... *beep* *beep* *beep* *beep*"
  14. MrDT
    MrDT fapfap
    14 Jun 2002
    That's kinda obvious mightybob, but not that many people would dare open up your case and short the mobo pins just to switch it on would they?
    As mentioned earlier, installing a keyswitch was deterrent enough for my rig when i lived with my parents...
  15. ben184
    ben184 What's a Dremel?
    10 Nov 2003
    That keypad idea from Extension Tech is cool.
    I was going to follow this guide at GideonTech for a key card security feature:
    http://www.gideontech.com/guides/electronic_lock/
    but now I may just do the keypad.
    What's cooler:
    Not having to carry a keycard around, and just remembering a code?
    Or carrying keycards around? (Doom/Quake style; "You do not have the keycard to open this door" D'oh!)
  16. diskreet
    1 Oct 2003
    Losing the keycard!
  17. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Erm.... BIOS Password...
  18. diskreet
    1 Oct 2003
    If you mean to set a bios password, then you can still power on and get into the pc, just not the bios. PLUS if you are using it as a security option, the jumper for the bios password is always clearly labeled, and easiy to remove to gain access.
  19. WizardLock
    WizardLock What's a Dremel?
    15 Nov 2003
    But see, to use the BIOS password, you would need to start the computer. I don't want that to happen. I don't want the power going to computer until the right code is entered. Once the code is entered, the the ENTER key is pressed, the computer starts up.
    Can't use the BIOS password if there is no power.
  20. diskreet
    1 Oct 2003
    Exactly, very good point.
