  1. legoman
    legoman breaker of things
    28 Feb 2010
    Pair of Velohooks from Feedback sports
    Foam tiles to make it a bit more comfortable in the garage when I'm working, sticky stuffs crap i have something for it instead.
  2. Guest-44638
    Guest-44638 Guest
    Just me... or is that not a bit too much stress for those rims?
  3. Gareth Halfacree
    4 Dec 2007
    I believe the idea is you mount it so the other wheel remains on the ground and takes the weight.
  4. Guest-44638
    Guest-44638 Guest
    No; you're NOT chopped liver (I hate that f***in' expression, already), but weigh the straps first...
  5. Guest-44638
    Guest-44638 Guest
    I'd turn 'em 90° & have one at each end of the top tube, but...
  6. Vault-Tec
    30 Aug 2015
    Rims have a lot of strength like that. It's lateral pressure that will screw them. It's like breaking eggs. Have you ever tried to break one from the top to bottom? it's very hard unless you come at it sideways... I would also surmise that the bike hanging from that rim weighs about the same as an air sandwich.
  7. Guest-44638
    Guest-44638 Guest
    I love that you quoted the wrong post... :D Not sure Id wanna hang any bike by a single wheel, pro-spec. weight or not.
  8. Gareth Halfacree
    4 Dec 2007
    That's... that's not how you use that expression.
    I doubt the scales are accurate enough for the weight of the strap to matter. Guess I'll find out when it arrives - see if it can actually register just the strap hanging off!
  9. Vault-Tec
    30 Aug 2015
    I've done it for 30 years in the same sort of fashion and no bikes were ever harmed.
    legoman likes this.
  10. Guest-44638
    Guest-44638 Guest
    So; it's a "Yiddish" rhetorical dismissive (which is a put-down, however it's sliced)...? To my Asperger's thinking, a pre-emptive strike was still 'required', as no suggestions I make are intended sarcastically, however 'thick' they may sound.
  11. adidan
    25 Mar 2009
    TIL.
    Those scales look a value buy tbh.
    There are also rainbow straps in our house somewhere, super useful for spotting your bags at the airport in amongst all the bags with rainbow straps...
  12. Gareth Halfacree
    4 Dec 2007
    ... What?
    Weekly_Estimate likes this.
  13. legoman
    28 Feb 2010
    Indeed, and as Vaultec mentioned its fine, one will be sat on the ground the other a bit higher up. they fold better with the bikes attached, not that i'm expecting much in the way of being able to fold but it all helps. Rated to take 22.5kg my heaviest bike is only 13.5kg so this should be ample.
  14. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    What for experimenting with rib recipes on my smoker over the long weekend;
    The_Crapman likes this.
  15. Guest-44638
    Guest-44638 Guest
    Put simpler; a response of "What am I, chopped liver?" is, to me, the same as STFU/keep your input to yourself, so I chose to defuse its' use with a "not required to a rhetorical reply" reply; it's how my brain works, so "sue me".
    My options from here on in are to NOT offer answers to your requests for advice, for fear that I'm too lowly for any advice I may have to be worthy of your consideration.
  16. Gareth Halfacree
    4 Dec 2007
    ...What?
    The idiom "what am I, chopped liver?" is "a semi-serious expression of frustration, anger, or indignation at having been overlooked and/or regarded as inferior." For example, when I write an article saying "X has happened" then someone comments "X has happened," I'll likely respond using said idiom to light-heartedly point out that they'd ignored my earlier contribution - thus (but not really, because again it's intended in a joking manner) making me feel "overlooked and/or regarded as inferior."
    It has absolutely nothing to do with being given advice, or ignoring said advice, nor does it tell the recipient to shut up: it, as the definition makes extremely clear, conveys the message of "hey, you've overlooked me or treated me or my contribution as inferior and that kinda hurts my feelings." I've never used it in response to being given advice (because that's not how the idiom is used), though I may very well have used it when someone has asked for advice, I've said "hey, you should do X" then someone else says exactly the same thing - because, again, ignoring what I've written and just repeating it as though it's your own suggestion would make me feel "overlooked and/or regarded as inferior."
    Not too sure what your problem is, here, but you've clearly got the wrong end of the stick. The wrong end of an entirely different stick, in fact. It's possible it's not even a stick; I think you might have the wrong end of a teapot.
    For the avoidance of doubt: according to the search function, I've used the phrase exactly four times: once in reply to you when you repeated advice I had already given in the article to which you were replying, which is, I'm assuming, what has had your goat for four months; once in reply to @adidan for having said "I'd not heard of" a topic I'd written about earlier (again, in a joking manner, 'cos I don't expect everyone to read everything that's ever posted to the site); here I linked you to the definition I've again linked you to because you apparently still don't get it; and literally in this thread. Well, I guess when I hit "Post Reply" there'll be a fifth result, too.
    Does that help make things clearer?
  17. adidan
    25 Mar 2009
    Dude, it doesn't mean any of that, don't worry.
    Take a look at @Gareth Halfacree 's link to my post - it's a phrase that can be used to highlight if somebody has been overlooked, like i posted about something I thought was new that Gareth had already written about some time ago.
  18. Guest-44638
    Guest-44638 Guest
    Even in retrospect - as the link was in the article - I took the reply as vitriolic (even personal); my problem, no-one else's but your dislike of my input is irredeemably cemented in my thinking.
    Like I said - my problem & my options in respect of your content remain the same.
    Supplemental: I live my life not needing to be liked; if I am, it's a bonus... but at the same time I don't intend to be objectionable.
  19. Gareth Halfacree
    4 Dec 2007
    I have absolutely no dislike of your input whatsoever.
    Well, I'm not a massive fan of this particular input right now, but generally speaking I have absolutely no dislike of your input whatsoever. The reply was in no way personal, nor was any vitriol intended: the phrase, as I keep attempting to explain, is used to indicate that the recipient has made the utterer feel overlooked and/or insignificant - but, typically, in a light-hearted fashion. I don't think I've ever heard anyone say it with malice aforethought.
    As for my dislike of your input, which is wholly imagined, being irredeemably cemented in your thinking: doesn't sound like there's much I can do about that. If my posts offend, might I suggest the Ignore option? Just head to my profile page, and hit the Ignore option at the top-right:
    Easy as that. To assist, I'll do the same for you: that way I will literally never reply to any of your posts again, because I'll never see 'em. Not what I would call an ideal solution, but certainly an effective one.
  20. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Jeezo, this is all a bit unnecessarily dramatic. Everyone just go and have a nice cup of tea and just chill.
    DK63 likes this.
