  1. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    You posted this message on a “smart device”. Whether it’s a laptop, a desktop, a tablet, or a phone, and regardless of what OS you choose, they all have some kind of login and/or remote server requirements. My day job is inherently tied to “the cloud”. I rely on multiple “cloud-based” services every day in my personal life: Steam, YouTube, Apple account, Microsoft account, Google account, AWS, Azure… and god only knows what else.
    Life is too damn short to make every day a constant battle.
  2. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    Pro Elec PEL01208 IEC C14 Plug to 4-Gang mains Extension Lead
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    2022 Hyundai Tuscon Premium, 11,315 miles, pick it up from the stealer in 10 days because one of their numpties nudged a pole whilst parking it when it arrived and dented the bonnet, metallic paint means it is cheaper to replace the bonnet completely.
    Be a good replacement for a 16 year old, non ULEZ compliant diesel MPV. Shame as it has only done 81k miles so barely run in for a diesel. Owes me nothing, awesome car, be sad to see it go for scrappage, just feels like a waste of a perfectly good car.
  4. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    20 bitspower 10/8 compression fittings, direct from bitspower. Because trying to get some from my usual place (wcuk) I was told they've gone end of life, and are being discontinued as a legacy size.
    Other brands have too deep a thread and don't look as nice.
  5. Gareth Halfacree
    4 Dec 2007
    The *third* dehumidifier...
    First one was faulty. Second one was entirely ill-suited to domestic use: loud fan, stupid control panel that switches to clothes-drying full-blast mode when all you want to do is switch the fan from really loud to merely very loud, doubly stupid control panel that defaults it to clothes-drying full-blast mode every time it's turned on (so to put it in minimum-fan 50%-target-RH mode you have to press Power, Fan, Fan, Mode, Mode... EVERY TIME YOU SWITCH IT ON), and the stupidly loud fan runs even when it's *reached* target humidity - just blasting away all the time. Ridiculous.
    This thing's a compressor type again, which I'd hoped to avoid, but the really lovely dessicant type I've got in the office and the conservatory seems to have been discontinued. This is Quiet Mark approved, turns the fan off when it reaches target humidity, lets you *set* target humidity in five-percentage-point intervals instead of "One Drip, Two Drips and a Thumbs Up, Three Drips, Clothing," and was also £55 cheaper.
    Now I just hope I can get a refund out of Meaco (and the first lot, for that matter!)
  6. Byron C
    12 Apr 2002
    So what I’m getting from all this is: do not buy Meaco dehumidifiers! :grin:
    Shame it’s been such a crap experience, their fans are great.
  7. GeorgeStorm
    16 Dec 2008
    I mean I've personally not had any issues with mine so far :D It is annoying it resets to laundry mode each time you turn it on but we don't turn it on and off much unless we're moving it around in the house (which happened at Christmas for example), guessing that's a difference between the junior version and normal as ours is silent when it reaches whatever the recommended humidity value. Haven't actually used it in the garage yet which was the reason we went for the dessicant model but I'm sure I will at some point.
  8. Mr_Mistoffelees
    26 Aug 2014
    Our Meaco has been great so far, no problems at all. We mainly use it for washing drying, when it can't be done outside and, even in laundry-full-blast mode, it's quiet enough not to disturb overnight.
  9. VictorianBloke
    31 Oct 2007
    Another satisfied Meaco user here too. Don't even use laundry mode, standard gets the washing dry quickly enough. Just needs the filter cleaning every so often to keep it quiet.
  10. adidan
    25 Mar 2009
    Yeah got a couple of Meacos but they're desiccant rather than compressor types.
  11. Gareth Halfacree
    4 Dec 2007
    This one was dessicant (DD8L Junior), and terribad. At least, for use in a room anyone spends time in. The one I'm trying to replace was also Meaco, though a compressor type (MeacoDry ABC 12l) and worked fine - proper humidity setting, remembered the last mode it was on, quiet, fan goes off when it doesn't need to be running - but died in a worrying way: the compressor was running while the thing was supposed to be switched off, and 'cos the fan wasn't going it got very very hot indeed.
    The two other dessicant types I've got are from Pro Breeze, and fantastic. But, yeah, discontinued, it seems. I've also got another, newer MeacoDry ABC 12l in the living room, but I'm giving that the side-eye after the last one failed...
    adidan likes this.
  12. adidan
    25 Mar 2009
    Huh, that surprises me.
    My junior in the loft where my pcs are doesn't break a sweat set at 50% if I'm in the room and the one I have downstairs barely runs as I've set it for 60. Both just the single fan setting.
    Well unless there's laundry in there and I bump it up of course.
    Yeah if a compressor dies but doesn't die is worrying in a don't-burn-my-house-down-please kind of way.
    Tis the way of tech, one brand people swear by others will have a nightmare time with. I've always had that with Corsair RAM, always been a pain for me.
  13. Gareth Halfacree
    4 Dec 2007
    Do you mean that it turns the fan off when it's reached its target humidity? Because mine wasn't doing that - and the manual says that's to be expected, and that the fan will continue to run at all times. Maybe they've changed the design between you getting yours and me getting mine?
  14. adidan
    25 Mar 2009
    Ah, I see.
    Yeah I got a Junior in 22 for the loft and it does that. Spins up to see if it's needed every 15-30(?) minutes and switches off when the target is reached.
    Picked up a DD8L non-Junior in November (Ish? Maybe October) and that works in the exact same way.
    The fan definitely doesn't run at all times.
  15. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Couple more I didn't get to last year, but visited in 2016:-
    • La Brea Tar Pits - Live archaeology. Eat at "The Counter" just east of the park - you design your own burger.
    • Petersen Auto Museum - Just up the road from the Tar Pits, home of "Hot Rod" magazine. Pay the uplift for the "Vault" tour in the basement. They had the DeTomaso Pantera that Elvis shot when I went.
    kenco_uk likes this.
  16. Gareth Halfacree
    4 Dec 2007
    I just... what?
    Remember I said the fan turns off when it reaches target humidity, like every other dehumidifier I've ever owned until recently? Well, that was based on this snippet from the product listing:
    "The built-in humidity sensor allows you to set your desired room humidity between 30%-80%. Once this level is reached, the unit will turn off to conserve energy."
    Yeah... that's a lie. The compressor turns off, but the fan remains active so long as the unit's switched on.
    I'm not buying a fourth, though. It's got a power button to shut it up, that'll have to do. I'm still waiting on my refunds for the first two!
  17. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    My new (to me) network bits have started to arrive:
    Going to be my first time playing around with PoE which I shall be using to add a wireless access point (thinking of grabbing a Ruckus R600 for that - need something beefy as our house is reinforced concrete, rf signals have real trouble here, plus the Ruckus system can control itself and I can easily add another AP if needed). The Fujitsu will be running something like OpnSense or PFsense, or, or or....
    Just need to get some Cat6 cable and the associated bits and pieces. Exciting times...
    Byron C likes this.
  18. Yaka
    Yaka Multimodder
    26 Jun 2005
    brand new off gumtree, way cheaper than retail geezer i got it off must have got a pallet deal on tools and stuff missed out and a few miter saws :( should work with my dinky old ctl sys vac and save me a expensive bags
    ElThomsono likes this.
  19. kenco_uk
    28 Nov 2003
    One of these to have Android Auto in my car. Looks to have really good support just in case and is also an easy install compared to others, which I'm all for.
    SuperHans123 likes this.
  20. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Garmin Instinct Crossover.
    Arrives today.
    Gareth Halfacree likes this.
