Scratch Build – In Progress Lean and Green - 15-12-14 - as complete as it's going to get
Discussion in 'Project Logs' started by Waynio, 28 Jan 2012.
  1. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I haven't been on here as much as in the recent past as my modding has pretty much come to a halt thanks to my car wreck earlier this year. Hopefully I'll be able to get back at it in the near future. I wasn't aware of the issue with people using the star ratings to try to assassinate threads/logs. Some people are just so petty and stupid. I personally never did pay the star ratings any attention myself. Wayne, you're doing awesome work on this build. Just keep it coming.
    I've never modded for competitions myself. I just mod because I enjoy doing so. Getting a few accolades along the way is very nice to be sure, but in my case, if I got myself wrapped up in trying to compete, I'd fail anyway since my kind of mods will never be uber-popular anyway.
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
    +1 never did see forum ratings as anything more than a popularity contest. I dont think popularity is indicative of ability or design vision. Personally love your mod and the fact your could even design it let alone hand cut and file or the parts with such presicion still astounds me :eek:
    Sent from my Nexus 7 using Tapatalk 2
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    I'm not meaning to be rude but I'm 2 pages off topic now so need to get this back on track, I'll reply to further comments. :)
    I lost the plot a bit back there also, :blush: had to be quite wired to get it done ready for the deadline, no chance now but that's not a bad thing, lets me get it done a lot better now. :)
    Good to see you though voigts & look forward to you getting your mod on when you can & let me tell you I think you really underrate your project, Quintessence is gorgeous inside & out, can't imagine anyone not liking it. :hip::dremel:
    Where it was since last session but now with the 3rd revision of the HDD covers & they fit in there nicely, I also had to drill the 3mm holes a bit closer to the edge so the rods could fit in.
    The 5mm & 10mm rods with grub screws in for the tapped rods above.
    View from underneath where they are countersunk screwed in & the 3mm holes I drilled straight through & extended them more outwards so they'll fit in.
    How it is now with all the rods in place, this all needs a heck of a cleaning up by light filing & sanding to make it look a lot nicer, it'll get there.
    Right here I noticed how the light caught the dual layer side panels creating a sweet contrast so thought I'd take a shot, bit like a preview of the intended look of what the contrasts will look like when everything gets anodised but not this colour. :)
    I'm still wishing I put all the mounting points in on the design phase before I got on with making this but once I'm past this HTPC & stand everything else should be far more straight forward.
    Some more shots.
    Other news.
    Been wanting to make my dad a nice xbmc for quite a while & was browsing around fleabay for a cheap mini-ITX mobo & seen an Asus E35M1-I Deluxe same as the one I'm using on mine but 2nd hand for £68, owner had it since August, took the memory out of my current rig & put it in, tested & it's all good, then I finally installed the Samsung memory I bought a bit ago into my current rig, it's 10mm lower than normal low profile memory, low voltage & highly overclockable, no heat sink & a black PCB, got it running at 2133mhz 10,10,10,28 @1.45v, really nice memory & will be nicer still when I take the stickers off. :)
  4. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Aw, I wanted to see you polishing your fingers to the bone on all those parts :D
    I've never taken any notice of the star system here and my build is not even on the same planet as yours but already it's been demoted and it only reached 4 stars, I for one voted to remove the star system :clap:
    I got less stars than you, na, na, na, na na :rolleyes:
  5. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Nice! Looks great Waynio. Good to see you back on track :thumb:
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Sandblast 'n anodize. Getting it over with quickly and painless.
    Just saying.
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    I just can´t get enough of that fan Waynio, it´s one hell of an eye catcher! I really like the raw alu aswell. But I guess anodizing it will look just as good...
  8. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Sweet build man! I'm really glad you're back! Now, keep coming with updates!!!!:D
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D I'll be polishing some parts. ;)
    I never used to neither but it's something I only recently started taking notice of & probably because of thinking BS about low rated awesomeness.
    Personally if someone is having a good go at making something & they don't ignore comments & generally just a good contributor I give 5 but never anything less, if it's someone being a bleep I just ignore or try to anyway, modding forums to me are possibly the best of the interwebs so it sucks to have a tiny minority trying to put a crapper on it so I get defensive about it, bit-tech has been, is & will be an international modding mecca & trolls or frustrated modders should be enlightened instead of pouring napalm on them. :hehe:
    But I do dislike stupid petty flame wars, so childish, I like creation, not destruction.
    Would be for best I think if they ditched the rating system especially after seeing project get 1 star as soon as they post, very clear sign of hating that.
    Good to see you posting some awesomeness too beta, impressive :D I want gas struts now. :hehe:
    Thanks Mosquito the Hercules vid you posted made me LMAO. :D:clap:
    I might think serious about getting a sand blaster, would save a lot of work but I'll be sure to test first like the warning AngelOD said about a while ago about it potentially warping panels. :)
    :D Thanks Quizz, the actual fan blades will be left as they are, it's just everything else except for some bits I'll be polishing, some bits with extreme difficulty I imagine. :lol:
    Thanks phinix, :thumb: leaving here would be daft just because of a tiny minority :) I'll get onto making some progress now. :D
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Made a hiccup when extending the holes for the 3mm rods on my last session, I simply drilled too close so left the outer edge is a bit knackered on the top & bottom panels, I'll re make the affected panels moving them further in by 0.5mm so might need to get more 3mm aluminium, not sure yet.
    Showing the 3rd revision of the hdd cover pieces a bit clearer, still unsure about filing the 2 layers above to be the same or to bevel to the 3rd layer.
    Marked & drilled the first 2 mount points on the stand cover which makes the whole look more together.
    Then held the cover in place & poked a sharpie marker through onto the acrylic.
    Drilled & bunged brass inserts in.
    Testing & getting more marker points added.
    Decided to use the top mount points to share the way it mounts to the stand so it's screwed in on both sides, had to shorten 3 screws by about 3mm.
    To get the accurate marking of the upper mounts I just squeezed the assembly together & drilled through the brass insert on the drill press with a 2mm bit & then took apart & used a 3mm bit.
    Put it together & it was nice & solid piece ready to install.
    One tiny problem though, the custom fan pass through hole on the cover is I'd say about 1mm too low so it won't let me slide the HTPC in/out so it needs some careful filing so it will allow it to slide in/out, going to be difficult making sure it doesn't produce a significant gap spoiling the look.
    I think it looks so much better with the covers, enjoy the shots. :)
    I'll fix any of the mentioned issues in this update on my next session. :)
  11. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    Looking damn fine, and im sure you will be able to fix the little issue with the rods!! That top faceplate really came out nice! me likey!!
  12. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Unreal. Great work.
    How much does it weigh in at right now?
  13. bluc
    4 Apr 2012
    Sorry but omfg :eek::eek::eek::D
  14. ShinyAli
    14 Sep 2012
    If you have enough space for struts and want to try them I bought my struts on ebay only £8.00, I found the 50Newton strut was powerful enough to lift the top panel on my case but I needed the 80N for the side panel, also be aware that these struts don't damp over their full travel, initially they push/spring for about 60-70% of their travel and only damp over the last part of their travel, so a door/panel initially springs open and then slows as it reaches max opening.
    There's also "Struts Direct" they have a much bigger selection but are more expensive.
    Thanks for your comments Waynio, appreciated :cooldude:
  15. Sarakon
    Sarakon The German
    11 Feb 2011
    That looks so awesome. Splendid work as always :thumb:
    Lets hope those other parts are a quick fix...
  16. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    I pay no attention to the star ratings in project logs, I have no skills as far as stuff like this goes, but I do appreciate a nice piece of art such as this.
    It looks cool
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks Squigly :)
    Thanks KrunchR :) I really don't know what it weighs, it is getting heavier though, good thing it separates into 4 pieces, the HTPC, the stand, the gaming rig, the pedestal, & with haviung no deadline to contend with now maybe a test bench too. :D
    :hehe: Cheers bluc :D
    Thanks for the info Shiny, :) think I'll stick with plugs though, I know I'll will be able to do that without worrying about space. :D
    Thanks Sarakon :) it's actually just 1 panel after re examining it, I'll just trace around it, should be a quick part to make. :D
    I need to re tune my thinking into ignoring the ratings on here else it will always wind me up. :lol:
    Would be perfect if ratings were only available once a project is completed, couldn't demotivate at all then. :)
    Thanks Rich. :)
    Changed my avatar to a crazy Kermit freaking out in the snow. :D:p
  18. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    I think i'd freak out every now and then if my girlfriend was a fat pig who was always all over our guests and was forever physically abusing me.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol: Was looking for a christmassy avatar, couldn't be bothered making one this year, seen this one & thought, yep that's good & crazy. :D
    But I found another I quite like.
  20. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    i have to admit; when i first started reading this log i stopped for a while due to my admitted prejudice against non form-factor cases, then i started agian and fell in love with it when i saw all that brushed aluminum gorgeousness... and it looks better IRL... much better.
