Modding Lian li o11 XL
Discussion in 'Modding' started by numanoid, 1 Aug 2023.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hello guys
    Im thinking of buying a Lian li dynamic o11 XL and have it powder coated all white, just need to know if its all metal ie the front where the on off button and usb connections are and also the edges where the glass slides in, thanks
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Not sure about the XL, but they already do the regular O11D in white from the factory.
    numanoid likes this.
  3. The_Crapman
    5 Dec 2011
    The case feet are plastic. The strip down the right with the front I/o is either thin alu on a plastic backing, or alu-effect plastic.
    adidan and numanoid like this.
  4. numanoid
    numanoid Modder
    26 Apr 2009
    Thank you buddy ive decided on the Phanteks NV7 D-RGB instead thanks
  5. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks matey ive gone for Phanteks NV7 D-RGB instead
    The_Crapman likes this.
  6. The_Crapman
    5 Dec 2011
    Noice. some slanty shanty action.
  7. numanoid
    numanoid Modder
    26 Apr 2009
    Oh yes haha
