Modding Macro Black
Discussion in 'Article Discussion' started by macroman, 1 Jan 2002.
  1. Hi-TEK
    Hi-TEK What's a Dremel?
    7 Sep 2001
    Part 3 looks great Macro and I like what you did in terms of redesigning the front bezel and using makeup containers for the feet. I'm wondering if the EL your using suffers from the annoying humm generated by most 12v interters? Its the reason why I have only used EL in one of my mods.
  2. Boggy
    Boggy What's a Dremel?
    3 Jan 2002
    Sweeeeeet!
    i need to try those feet they look so sweet!
    <reaches for Avon catalogue>
    just think of all the other mods possible with these cases.
    we dont just want a load of macro-black case look-a-likes use your heads people.
    Inspiration! (that case is so sweet though i understand why people would copy it)
    :D
  3. Deebens
    Deebens What's a Dremel?
    27 Jan 2002
    Allrighty then....
    my first plan for a semi-mod. i like this one cos if i screw up, it dont matter, and if i dont screw up, its pointless anyway!
    i will admit first that this is Macroblack inspired, but after seeing that, its hard to come up with anything original. the idea comes from the biohazard on the side of the case, and does involve some originality.
    Project Isotope:
    -Spray my case gloss black, and if possible, the trim (dunno if itll spray) matt black.
    -Print out a "Radioactive" symbol, and use it as a mask, get a friend of mine with a dremel & jigsaw to hack it out, smooth it off.
    -Respray around edges
    -Fit EL-Sheet to back of side-panel, over the logo
    -Wire up appropriate EL junk
    -Fit a tinted filter over ELSheet if too bright
    -Wire up so comes on with PC.
    -Turn off lights, sit and stare for a while
    i am considering having some of that "only seethru when lights behind it" stuff over it too, could look good but i dont want to push it.
    criticise away. macroman i could really use your opinion on this. PS i have an identical case to replace it if i screw up.
  4. macroman
    macroman The One
    3 Sep 2001
    Sounds good to me but I would suggest doing all the cutting before spraying. That way you only do it once and will get a perfect finish.
  5. Deebens
    27 Jan 2002
    Oops
    For some reason i just didnt see that one.
    <notices brain cell dying of lonliness>
    hmmm. thx for pointing that out. i probably would have gone straight on and done it that way otherwise! :rolleyes:
    just a few requests:
    • Paint recommendations for just a bog-standard biege case
    • should i sand it down first (get all the old paint off)
    • cutting the logo: dremel or jigsaw?
    • info on the light-filter stuff you used
    • anythin else i might wanna kno
    thx
    Project Isotope
    It WILL Hurt
  6. ramtech
    ramtech What's a Dremel?
    23 Jan 2002
  7. BoilermakerFan
    BoilermakerFan What's a Dremel?
    23 Jan 2002
    Makeup compacts for the feet! Looks like my wife will be getting some new makeup whether she needs it or not!
  8. Tim S
    Tim S OG
    8 Nov 2001
    lol, now thats dedication :D ;)
  9. macroman
    macroman The One
    3 Sep 2001
    Hi-Tek - the inverter I used is silent in use although I have come across some noisey ones.
  10. Guest-16
    Guest-16 Guest
    just 1 question m8 - how did u do this?
    im sorry if uve answered it before but 8 pages are ALOT to sift thru :(
  11. macroman
    macroman The One
    3 Sep 2001
    Covered in the next installment.
    If 8 pages is a lot to wade through imagine writing it ;)
  12. Guest-16
    Guest-16 Guest
    i meant of this thread.. and its 13 pages sorry :rolleyes:
    When's the next one due then???
  13. macroman
    macroman The One
    3 Sep 2001
    workload permitting - by mid next week, before if poss. :D
  14. Guest-16
    Guest-16 Guest
    cool, as long as its not a month away :eek: hehe
  15. kastman
    kastman What's a Dremel?
    31 Jan 2002
    yo absolutly wounderful case i give it a 11 of 10 possible :) got some small questions for you:
    1. were can i get neon string on the web?
    2. how thick is the plexi on the case(mm)?
    3. is it coming up how you did the mirror thing with the lcd?
    Thanks // Kastman
  16. JaKeN
    JaKeN What's a Dremel?
    29 Jan 2002
    Rheobus
    I just gotta know how you did that Rheobus with the leds indicating the different Levels, cant anyone put up a schematic for that kind of rheobus
  17. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    :eek: two words : OMFG OMFG!
    I love it, the mirror finish, the fibre optic lights, the.. well everything, I am so jealous and I bow to your modding skill.
    I joined here just to say that!
    After seeing this I now want to throw my new shiny black windowed athlon 1.4 into the trash and start something else.
    Iv'e always like the Mac G4 cube idea, and am thinking of doing that type of thing, now I know how I could do it but being out of cash it will have to wait.
    Again great job, an I am certain I will steal some of your Ideas.
  18. JaKeN
    29 Jan 2002
    Rheobus
    Well did you have a schematics for that Extremly Cool looking rheobus
  19. Boggy
    3 Jan 2002
    so when is this article gonna be out?
    i am so impatient!!
  20. Wyzzord
    Wyzzord What's a Dremel?
    15 Nov 2001
    When is the next installment of the article sagga gunna be posted!! & about how much more is left??
Tags: Add Tags
