Modding Macro Black
Discussion in 'Article Discussion' started by macroman, 1 Jan 2002.
  1. kastman
    kastman What's a Dremel?
    31 Jan 2002
    LCD?
    Yo Macroman
    i have read your article about 100 times now i think and got the most of my idees to my project from it. It is an exellent article and very very very nice case mod. So my little question is a new update coming soon for it want to know more about how you mounted the lcd.
  2. ChenZen
    ChenZen Minimodder
    5 Mar 2002
    macroman, im trying to do the "tint" thing .... im testing on cuts of acrylic i got, but i keep getting streaks between the film and the window ... its soo annoying. i've been trying for 2 days now to get it "streakless" .... so i thought i might ask u for sum tips.. or tell me wht im doing wrong.
    1. spray soapy water on window
    2. spray soapy water on adhesive side of film
    3. place film on window
    4. spray soapy water on the film
    5. use squeegy to finish off.
    wht me doing wrong.. or any tips on the above...
  3. macroman
    macroman The One
    3 Sep 2001
    I'm not sure what you mean be streaks. If you mean streaky stains or marks then you are using too strong a soapy solution. Use only a couple of drops of washing up liquid per pint of water.
    If you mean air bubble marks then you aren't squeegeeing (!) evenly as you peel the film backing off. Work from the center outwards. Keep squeegeeing until ALL the water is gone.
    Ensure the Acrylic is spotlessly clean before applying the film. Spray and squeegee it first.
    The main thing is follow the film manufacturers instructions. Different brands may be slightly different.
    Hope that helps.
  4. ChenZen
    ChenZen Minimodder
    5 Mar 2002
    cheers. i thinks i added too much soap..
    the acrylic has been spotless clean each time i tried it .... i peel off protective film just b4 i do it.
    thanx for feedback.
  5. ChenZen
    ChenZen Minimodder
    5 Mar 2002
    all that hard work for sumfing i dont even like, the tint i used makes my blooo CCFL look green, ... went to shop to see if i cud get really light tint... but they didnt have any ...
  6. Slayer
    Slayer What's a Dremel?
    27 Feb 2002
    So Macroman.......got them pics? Pretty please???:D
  7. ChenZen
    ChenZen Minimodder
    5 Mar 2002
    macroman ... how do u get the big clock on ure LCD ??
    i got the nk204 ... will it work on mine ? and how ?
    thanx alot
  8. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
  9. macroman
    macroman The One
    3 Sep 2001
  10. Ace_03
    Ace_03 What's a Dremel?
    23 Apr 2002
    I only wish I had the thought and imagination to build a beauty like that one there...
    Swwwweeeeeeeeeeetttttttttt!!! :eeek:
  11. nico
    nico What's a Dremel?
    9 Mar 2002
    wow
    This is the most awesome mod Ive ever seen. And i have looked through the whole virtual hideout cool case gallery which is like 300 pages x 10.
    Ive never seen anything like this. It's brilliant. So.. that is why I have decided to do something similar for my new case.
    I have a couple of questions though.
    - how did you make the LCD display?, the writing on the case effect is cool.
    - is there room for 120mm infront and back? As far as i can see youre using 92mm fans.. is that correct?
    - and how did you make that schweet rheobus?
    awesome work. keep it up.
  12. macroman
    macroman The One
    3 Sep 2001
    nico - Hi and welcome to the forums.
    The display is an MO VFD, not and LCD. That and the fanbus articles are in preperation and should be appearing soon.
    A 120mm fan can be fitted but you will lose some drive bay space. I used 80mm fans.
  13. nico
    9 Mar 2002
    thank you.
    how expensive are such VFDs then?
    and how many drive bays do i loose by fitting in an 120mm fan? will i require to make any modifications to the inside to make it fit at all? its kinda hard to tell by the pictures...
    maybe ill even stick with a 80mm fan.. but its gonna host a bad ass overclocked p4 system (1,6@2,5) so airflow is pretty important.
    and i dont wanna run any high output noisy delta 80mm fans. do you think a low output panaflo would be enough airflow?
  14. nico
    9 Mar 2002
    oh and by the way... this site seems to have all the info i need on making that type of rheobus.
  15. nico
    9 Mar 2002
    heh, i keep coming with the questions dont i. I was just wondering if the mobo tray can be used with a p4 without drilling omre screwholes into the tray?
  16. nico
    9 Mar 2002
    macroman answer this f**cking thread for f**ks sake.
    ... ok, dont take that personal.
    ill say no more.
    BUMP.
  17. macroman
    macroman The One
    3 Sep 2001
    Chill, I have been very busy. :D
    A VFD similar to the one used will cost about $120-150.
    Fitting a 120mm fan shouldn't be too hard. Just make the hole bigger and if you use a slim fan then you should retain all the drive bays intact. The HDDs will mount behing the fan keeping them cool. If you don't use a slim fan then the drives may need to be moved back slightly. To do that just drill new mounting holes in the mounting frame.
    The clear PC is not the beat for running a heavily overclocked CPU since it tends to hold the heat so 120mm fans may well be the way to go. Although you are using a P4 which has better self cooling than the AMD chips.
    I haven't tried a P4 mobo in the case but if it follows the ATX standard then it should be fine. There is no mobo tray as such, the mobo is bolted to the case body using supplied stand offs.
    I have an update to the article due this week and followed by the fan bus controller a bit after.
  18. nico
    9 Mar 2002
    :D
    my plan worked. you posted like 30 minutes after i did.
    ok, then i have another question for you. I dont wanna mod a fan with lights as it would most certainly make more noise (and i dont like noise). So.. would it be possible to get one of them Enermax clear fans and put a couple of blue leds behind it and achieve the same effect?
  19. Kruzen
    Kruzen What's a Dremel?
    9 May 2002
    Ok, i totally dont get somethign..
    In the first section of your mod, when your doing the painting etc..
    what exactly was the ordered process of doign thigns, i have read and read and rearead everything...
    I dont get how you are using teh seperate masks etc,,
    by what im reading it looks like your spray painting it then putting on the tint stuff but wouldnt that make it so you cant see through anyway, becuase one side is spray painted?
    mayebbe you could email me or IM me or something,
    ionmorph@integrity.com
    please expllain i totally am not undetsanding.
  20. Randland
    Randland What's a Dremel?
    5 Feb 2002
    Ok, the way I understood it is that you make a mask of all the stuff you do not want semitransparent, and spray the case. Then take off the mask and put on your chrome wherever you want it, and then put the window tint over everything. Where the mask was you will be able to see through the window tint.
    Hope that helps.
Tags: Add Tags
