Other Maple's Questions: Current Question; Upgrade motherboard
Discussion in 'Hardware' started by maple, 2 Jul 2012.
  1. maple
    maple Minimodder
    23 Feb 2012
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Yes to all questions :)
  3. maple
    maple Minimodder
    23 Feb 2012
    thank you sir but why is there such a big difference in price between this and other boards when this can get the job done i originally wanted all the features of this but with usb 3 and sata 6gbs but its like £30 more
  4. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Why is a BMW more expensive than a Vauxhall?
    Apophis54 likes this.
  5. noizdaemon666
    15 Jun 2010
    More advanced chipset means more money has to be spent to get those features.
    Good analogy by Zinfandel :)
  6. Shirty
    18 Apr 1982
    Uh-oh, Zinfandel's caught the analogy bug off Nexxo :p
    More expensive boards will usually offer more USB ports/PCIe slots/SATA headers as well as using more complex, costly and feature rich chipsets and often higher grade capacitors/MOSFETs etc.
    To your average maple joe both boards do the job equally well, but to an enthusiast missing certain features will be painful in the long run.
  7. maple
    maple Minimodder
    23 Feb 2012
    and zinfandel thats not true since the countries speed limit is the same sso you dont get the extra speed
  8. Teelzebub
    27 Nov 2009
    hamza_tm and Apophis54 like this.
  9. maple
    maple Minimodder
    23 Feb 2012
  10. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Yes but the speed of your PC is governed by the physical limits of the parts it is built with, not legislation.
    You're also assuming that only only measure of quality is speed, which it isn't. But even if it was, you could always take your car to the track.
    Dammit, this analogy crap has gone TOO FAR! It's all Nexxo's fault :(.
  11. Teelzebub
    27 Nov 2009
    I bought it on the MP never got round to using it though, Was RMA so should be new, Cant remember what I paid I'll check later and you can a bit less if you want it.
    I reckon about £30inc though
  12. maple
    maple Minimodder
    23 Feb 2012
    Its mini itx so wont fit so cant buy it sorry
  13. maple
    maple Minimodder
    23 Feb 2012
    *New Tangent*
    So I bought an e6400 is it faster than my G530?
    So how do i go about overclocking it, what temperatures are safe for it, ut thing is though i want it too last i dont want it too break in 6 months time and stop working
  14. Shirty
    18 Apr 1982
    BMWs are generally nicer to drive, look at and live with than Vauxhalls. They are also reputedly more reliable and easier to tune. Although I'd still give my right bollock for a low-mileage Lotus Carlton fitted with a flammenwerfer to keep those pesky chavs at bay :lol:
    aNuclearPidgeon and Apophis54 like this.
  15. noizdaemon666
    15 Jun 2010
    You can't overclock a G530. You can overclock an E6400 but it's from before I got into computers so no idea on how to overclock it sorry lol
  16. Shirty
    18 Apr 1982
    ITX will fit in any modern case. It might be a bit small for your needs but it'll fit.
    No, it's not faster than your G530. Clock for clock I'd say the Celeron probably just has the edge due to improved architecture.
    Overclock it to 2.4GHz with a FSB bump up to 300MHz and a little extra voltage, try to keep it under 60 degrees and it'll serve you well.
  17. maple
    maple Minimodder
    23 Feb 2012
    the guy i got it from said he had it at 3.1 so how dould he have managed that, i bought a freezer so i can overclock this thing, i want to atleast get it faster than my G530
  18. Teelzebub
    27 Nov 2009
    I've got a Raspberry pi lol
  19. noizdaemon666
    15 Jun 2010
    2.13 to 3.1? On a 65nm 775 CPU? Not on air cooling he didn't lol
  20. maple
    maple Minimodder
    23 Feb 2012
    how did you manage to fit it in there?
