Graphics Monitor stutter issue
Discussion in 'Hardware' started by Harty, 9 Oct 2012.
  1. Harty
    Harty What's a Dremel?
    6 Sep 2012
    So I have recently build my first rig, woohoo, and I am reusing my old monitor.
    It's an AOC 24", and it only has a VGA input (despite being 1920x1080, which I find peculiar).
    I'm connecting my monitor to my Radeon 7850, using a DVI to VGA adapter, and it seems to work fine.
    However, there seems to be a constant stutter on the monitor. At least, I believe it is stutter - it's similar to the lines you have on a camera when you try record something from a TV screen. It is less noticeable while browsing the web, but it is still there - it is definitely noticeable in games.
    Now, before I weep since I can't afford a new monitor, is there a fix for this?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Refresh rate settings perhaps?
  3. Harty
    6 Sep 2012
    They're at 60Hz.
    Teelzebub likes this.
  4. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Have you checked your cables are secure?
    Can you check your pc with a different monitor or your monitor with a different pc?
    This should help to narrow down the problem.
    N17 dizzi, adidan and Teelzebub like this.
  5. Harty
    6 Sep 2012
    The VGA port wasn't securely fastened in at the back of the monitor, doh. I'll test out a game, see if the stutter is still there.
  6. Harty
    6 Sep 2012
    Nope, it's still there. I can't test my computer out on another monitor, all I have is this and a HDTV.
  7. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    the vertical sync in catalist is on or off ?
  8. Harty
    6 Sep 2012
    Is vertical sync the same as vertical refresh? If it is, it's off until application specifies it.
  9. GuilleAcoustic
    26 Nov 2010
    try to switch it to "always on". I think you are experiencing image "tearing".
  10. Harty
    6 Sep 2012
    Nope, still there. Could it be the DVI to VGA adapter? I've had it for quite a while...
  11. GoodBytes
    20 Jan 2007
    The problem is your adapter. Because of the metal visible plugs, it catches interferences.
    You can try a better VGA cable which could help, by having less interference received from the wire. Or a different adataper.. maybe with gold plated connectors, but the problem will still persist.
    The real solution is to either:
    1- Lower your screen resolution as 1920x1080 is pushing the VGA abilities, as you are seeing.
    2- Move to a location with less interference.
    3- Or the best, get a monitor with digital input. VGA only on LCD should not exist since day 1. I am even surprised you purchased this mockery. LCD is digital. What you did before was convert digital signal to analogue via the graphic card, using analogues to send the high bandwidth signal to the VGA wire which catches all sort of interferences, and at the monitor, convert the analogue signal back to digital to be processed.
    It was fine for CRT monitors, as the resolution at the time was low, and if you had a high resolution monitor it usually came with a super shielded and thick VGA cable. And CRT is full analogue. So you only convert the signal once, which mean higher quality than converting it twice.
  12. Harty
    6 Sep 2012
    Thanks for the advice.
    I got the 24" because it was a measly £40, and a massive upgrade from my old 17" 1024x768.
    At some point I'll invest in a DVI monitor, but that won;t be until around next year...
  13. GoodBytes
    20 Jan 2007
    Ah, that explains it!
  14. GuilleAcoustic
    26 Nov 2010
    I was using this 5x BNC connector on my IIyama A702HT to avoid interference :
  15. GoodBytes
    20 Jan 2007
    Yup, that was a better connector than VGA. Mainly because the wires where more separated than VGA, and you have that each wire is well shielded.
    However this connector was not wide spread for the consumer market, and video card with it, was rare, unless you used a VGA to BNC based VGA converter.
  16. Harty
    6 Sep 2012
    Could it be a GPU issue? The monitor worked on my laptop - though there was no adapter involved, and the resolution was much lower - 1366x768.
  17. GoodBytes
    20 Jan 2007
    No...well ok it COULD BE, but you solved the problem mentioned above.
    #1 - you lowered the screen resolution
    #2 - you don't use an adapter, so less metal part are visible (not shielded) so it doesn't catch a high amount of interference.
    #3- Your VGA cable is now away from other electric wires behind the desk, which drops further the interference level.
    So while it could be your graphic card, we won't know for sure because of the above points.
