Hardware MSI 870A Fuzion Power Edition: First Look
Discussion in 'Article Discussion' started by Sifter3000, 25 Aug 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. retrogamer1990
    retrogamer1990 What does 'Stock' Mean?
    12 Jan 2009
    Suthbridge?
  3. Sifter3000
    11 Jul 2006
    Aye, Suthbridge.
  4. memeroot
    memeroot aged and experianced
    31 Oct 2009
    want hydra on a graphics card
  5. steve30x
    steve30x What's a Dremel?
    31 Aug 2008
    I think a hydra addin card would be good. If thats any way possible.
  6. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    The problem with this is, that all the information from the graphic cards have to pass through the Hydra chip, and an add-on card would severely limit bandwidth. The same goes for the onboard chip.
  7. capnPedro
    11 Apr 2007
    Those white SATA cables are pretty pimp, but who wants a big blue rectangle on the front of their case? And a single USB3.0 port!? Would a second one have broke the budget?
  8. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    SLI? Or using two nVidia cards throught Hydra's driver? That's a world of difference once you start troubleshooting!
  9. Hustler
    Hustler Minimodder
    8 Aug 2005
    AMD SLI.................'bout bloody time.
    Not everyone who goes AMD wants to go Xfire......
    SLI is a far more robust dual card solution than ATI's ,at times, shambolic Xfire drivers........
  10. frontline
    frontline Punish Your Machine
    24 Jun 2007
    I was thinking the other day that if i had a motherboard that supported SLI i might have been tempted to try 2 x GTX460's... But i think that 1 high end card is the way forward from now on for me.
  11. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    SLI isn't significantly better solution and still carries all the same problems inherent to a multi-GPU system. Considering the awesome card performance of the current gen cards SLI/xfire are pretty redundant. You'd need to be running a massive resolution or multi-monitor setup to justify it. ATi does better multi-monitor as well even if you do want to go that route.
    I'm not saying that xfire is better, far from it, I just don't see why anyone would want to build a new system with multi-GPU.
    Note: This doesn't account for benchmarking and folding because Intel is better in both cases.
  12. m0ngy
    m0ngy What's a Dremel?
    3 Mar 2010
    Back in the day MSI were known as a relatively dodgy brand, more prone to failure than other, more reputable brands. Like naming a mobo 870 when it really has an older, redundant chipset... I'm sure they've come a long way, but I still wouldn't go MSI over Asus, not for my mobo, no way.
  13. Xir
    Xir Modder
    26 Apr 2006
    Meh, BMW sells motorbikes branded as 650 that have a 800 displacement.
    Marketing BS, that's what the name is.
    You're right off course, naming should be clear
  14. Guest-16
    Guest-16 Guest
    The more expensive boards are a lot better, but unlike Gbt UD2/3s and Asus LEs, we've had a hit and miss relationship with the budget stuff. Their 770-C45 was excellent and we continue to recommend it, but 785Gs were terrible.
  15. Xir
    Xir Modder
    26 Apr 2006
    How is the budget LGA 1366 stuff, like Asus P6T SE or Asrock x58 Extreme?
  16. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    Does anyone know the tdp of this motherboard?
Tags: Add Tags
