hi i everyone i am new here so dont be to hard on me. i just started with casemodding so. here is a pic of my case now. its not so mutch but i am going to work on it. My case
Welcome to bit-tech btw.. What's the part sticking out of the floppy bay? What are your plans for the case? Mike
Welcome...Don't worry ppl around here are not too hard. Gl with the modding and enjoy your time here. Looks like a switch for the CC in the floppy myke.
first i am going to go and get a dvd for my comp. then i am going to paint the case black. and then i am going to try to hide the switch for the neon. but i am thinking for more idea's. so if someone has a idea let me know .
FIX the Window edging apart from that its looking good so far mod on dude-- and PLEASE!!! mod that switch and by the way lose the beige
The front of the case looks quite flat, so actually you could mod away that neon switch very easily. Besides that, you need to paint the case black as soon as possible Are you planning on getting your cables done as well?
Fill the small vent holes on the side panel before painting it black, fix the window rubber(the bit where the ends meet) and stealth the cathode switch. That should give you a pretty nic looking case.
You could use car body filler, lots of stuff. How does this look. My interpretation of your case done in black
