Scratch Build – In Progress My Now finished mean Computer Numerical Control machine build
Discussion in 'Project Logs' started by Teelzebub, 21 Jul 2014.
What colour should it be painted?
  1. Red
    10 vote(s)
    34.5%
  2. Blue
    5 vote(s)
    17.2%
  3. Silver
    3 vote(s)
    10.3%
  4. Black
    7 vote(s)
    24.1%
  5. Mixed
    8 vote(s)
    27.6%
Multiple votes are allowed.
  1. Teelzebub
    27 Nov 2009
    Z axis update
    Right from the plate to mounting the parts on it I put the rails and the bearing blocks on and the motor mount and realized that the leadscrew nut was sitting far to high :( I could have added spacers on top of the the bearing blocks but not my preferred method so I machined the plate so the motor mount could sit lower.
    Even though the plate was 8mm thick it wasn't enough even after taking a couple of mm off the motor mount as well.
    Still no where near enough So I had to weld a plate on the back so I could machine even deeper.
    That seems to have done the job after going completely through and a couple of mm in to the next piece :thumb:
  2. Nexxo
    23 Oct 2001
  3. Teelzebub
    27 Nov 2009
    Hmmm yes :worried: lol
  4. Teelzebub
    27 Nov 2009
    Anyway next was to fit the Z axis plate to the X axis bearing blocks that means drilling 17 hole's in the right places if you don't then it's not going run smoothly so a template is called for, I use clear Perspex I cut a oblong of it and place it over the area that way I can mark the holes in the correct places like below.
    then clamp it in position on the piece and mark the holes out.
    Really makes it easy to get it spot on :thumb:
    Next countersink the holes and screw it to the X axis.
  5. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Oh my word Teel, why you have a big...X-axis there. :p
  6. Teelzebub
    27 Nov 2009
    I bet you say that to all the CNC builders :naughty:
    Not seen you post in here for a while hope alls good with you
  7. Noob?
    18 Oct 2009
    Of all the CNC builders, Only You, Only You have that special place in my heart. :hehe:
    No, I haven't mate, last was around page 10 (sorry), got a fair bit of catching up to do in your thread and others, lifes - ups and downs mate, thanks, likewise, hope all is well for you too. :)
  8. David
    7 Apr 2009
    Any idea on what the finished size/weight will be, Tel?
    I'm thinking something like...
  9. Teelzebub
    27 Nov 2009
    lol that's my next project :D
    with just a quick measure up it's going to be 870mm L x 870mm W x 430mm H and going to weigh in around 140kg.
    I'm going to have to make the bench another 4" longer to take it the new motors that is still to get are around twice the length of the old ones so there's nothing from the original one in this one now
  10. David
    7 Apr 2009
    LOL, you did change the steppers in the end.
    Throw the original up on the MP :D
  11. Kerroin
    Kerroin What's a Dremel?
    7 Jul 2014
    Wowo, this will be a big personal cnc!
    what are you going to do with the little one? now that you don't use any of the original pieces...
    The axis rods do they come with distance per turn measurement? (like 1mm/turn)
  12. Teelzebub
    27 Nov 2009
    This one needs stronger motors, although I said there's nothing from the original one which there isn't I'll be using the bed from the upgraded version of the original.
    If you remember the original was smaller and had two pieces of MDF for the bed and the spindle was that dremmel .
  13. Teelzebub
    27 Nov 2009
    If you're interested PM me, the site I bought the stuff from will have the information you need, if I remember right the leadscrew is a acme leadscrew 8x8.
    You say little one but in it's upgraded state it's 750mm x 750mm
    Edit just looked it up for you, The lead screw is 8x8 4 start moves at 8mm per revolution
  14. Teelzebub
    27 Nov 2009
    HELP HELP I need a name for this monster nothing too long but catchy and reflects the mean power
  15. Teelzebub
    27 Nov 2009
    Next is the Z axis plate for the spindle I picked up a 15mm thick plate of aluminium for this as I wanted to mill it flat on both side to give me a flat level plate.
    Just to complicate things it needed to be as wide as the mills bed so I made it longer so I could clamp it either end.
    And as luck would have it the powerfeed had packed up after only nine days ffs so it was time to improvise lol so I got an extra long 8mm nut and lathed half of it round and replaced the hand crank nut with it
    and used my rechargeable drill as the motor lol
    did one side with a end mill
    Then other with a fly cutter then cut the piece out
    Nice and flat and fits perfect
    Another 22 holes and some countersinking and we have the spindle plate/mount done :D
  16. David
    7 Apr 2009
    The first thing that came to mind:
  17. Teelzebub
    27 Nov 2009
    Lol very good too many words but a good one, I was thinking Millzebub lol
  18. Nexxo
    23 Oct 2001
    Hephaestus is the Greek god of blacksmiths, craftsmen, artisans, sculptors, metals, metallurgy, fire and volcanoes. Hephaestus' Roman equivalent is Vulcan. As a smithing god, Hephaestus made all the weapons of the gods in Olympus. He served as the blacksmith of the gods, and was worshipped in the manufacturing and industrial centers of Greece. Although his workshop was generally considered to reside on Olympus, some stories refer to him having a forge in the underworld.
  19. Kerroin
    7 Jul 2014
    Hi!
    Thanks for the information about the lead screws.
    My very little cnc (250x200x100) currently has normal screws, I want to change that so I can use it more often. (and maybe make it bigger :D)
  20. Teelzebub
    27 Nov 2009
    I'm guessing yours are 8mm threaded rod I have loads bits and bobs left over including two types of linear bearings for these ten of each so check me first if you need any bits.
    Oh the one I'm building has 16x4 lead screws :D
    Edit 250x200 is tiny what do you use that for?
