Scratch Build – In Progress My Now finished mean Computer Numerical Control machine build
Discussion in 'Project Logs' started by Teelzebub, 21 Jul 2014.
What colour should it be painted?
  1. Red
    10 vote(s)
    34.5%
  2. Blue
    5 vote(s)
    17.2%
  3. Silver
    3 vote(s)
    10.3%
  4. Black
    7 vote(s)
    24.1%
  5. Mixed
    8 vote(s)
    27.6%
Multiple votes are allowed.
  1. Teelzebub
    27 Nov 2009
    X axis
    Next is the X axis so I dismantled the machine so it would be easier to work on the X axis.
    I mounted the motor mount on the angle iron to find that it was making the lead screw / lead nut far to high the top of the lead nut needed to be level with the bearing blocks and it was 7 mm too high :(
    couldn't make the lead nut that much smaller so the only thing to do was to take 5mm off the 10mm angle iron with the mill
    Brilliant machine :thumb:
    next I removed 2mm from the lead screw nut and milled the opposite corners and drilled and threaded them
    put it all back together and it fitted perfect
  2. Nexxo
    23 Oct 2001
    You need a flycutter. They're brilliant for that kind of work.
  3. Teelzebub
    27 Nov 2009
    True certainly something I should get tbh I wasn't expecting to have to do that but needs must :)
    This build is now at the stage of making it up as I go, pretty much all the parts I have will need to be modded to work
    Wasn't you getting mill ?
    Edit just ordered a set of flycutters
  4. Teelzebub
    27 Nov 2009
    Christmas eve the power feed I had ordered with the mill finally arrived so xmas day I fitted it
    Seriously good bit of kit :D
    Right so back to the X axis next was the support bearing for the leadscrew at the opposite end from the motor only way was to weld a bracket to the end of the angle iron
    then lathed the leadscrew to 10mm and put a circlip groove in and installed it to the X axis
    That pretty much completes the X axis next will be the Z axis :worried:
  5. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    And to think this started out as a Shapeoko.... :lol:
  6. Cheapskate
    13 May 2007
    A year from now it will be a Haas.
  7. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    A year from now, this thing will go Skynet, become self aware, and either destroy us all or start cranking out it's own awesome PC mods / cases / everything else!
    Nexxo likes this.
  8. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    Nice man!! Coming along great, well I see you got the bf25 clone mill! My RF45 clone the grizzly G0755 just shipped today! Im super excited to use it to beef up my cnc router. Im eventually going to CNC kit the 0755 for my metal working needs and beef up the cncrouter enough to do aluminum easily. Also going to be picking up a lathe next month which im super excited for! Im probably scrapping my new cnc design for this year and collecting and cncing other machines and coming back with a new cnc router like next year maybe. Keep it up man!Looking good!
  9. Nexxo
    23 Oct 2001
    "I need your tools, your metals and your PC hardware"
  10. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Lemme know when it starts self replicating, I'll take one off your hands.
  11. David
    7 Apr 2009
    Well, the Troll dolls have started replicating already, so why not the mill? :lol:
  12. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    This thing on it's own is becoming a piece of art
  13. Teelzebub
    27 Nov 2009
    lol yeah it all started from a small Shapeoko :hehe: bh there's nothing wrong with the shapeoko design it's just not designed for thicker materials
    Although with the upgrades I did and I have some other bits it could certainly do 3mm aluminium
  14. Teelzebub
    27 Nov 2009
    The next one will be lol
    once it's done I'll start using it to make rockets to get it in space :thumb:
  15. Teelzebub
    27 Nov 2009
    Nice sounds like you're going to have a great workshop I was talking to a mate about what is the most useful machine out of them, the more I think about it you really need them all, with a mill and a lathe and a welder and of course a decent angle grinder you can build practically anything.
    Hope you plan to do a log would be good to have a few CNC build logs I reckon it would be a great help to others planning to build their own :thumb:
  16. Teelzebub
    27 Nov 2009
    I'll put them in the post for you lol
    Key ring size CNC machines :eeek:
    well he is a little devil :worried:
  17. Teelzebub
    27 Nov 2009
    Strange you say that the Tate gallery phoned me the other day :hehe:
  18. Teelzebub
    27 Nov 2009
    Z axis
    Z axis next after looking at the different metals like flat plate and angle iron I noticed the cast shapes was far better then the flat plate and bent and welded types it was truer and much more consistent, so I decided to buy some channel opposed to flat.
    by machining most of the sides off leaving about 15mm there it would retain the rigidness of the channel
    as you can see the mill was the neatest way of doing it, the problem was that once one side was gone it would be almost impossible to clamp it down for the other side.
    So I milled one side down leaving about 3mm still to go and then turned it around and milled the next side off completely then I put it in a vice and cut the rest of the other side with the angle grinder :D
    Just needs a clean up and will be far superior to the flat plate :thumb:
  19. Nexxo
    23 Oct 2001
    Mills are awesome.
    I was, but I keep spending money on more bits and pieces for the lathe (Glance cutting tools: pricey but SO worth it!) --and it's not just the cost of the mill... it's clamping tool sets, several vices, rotary table with chuck and tailstock, fly cutter... it all adds up.
  20. Teelzebub
    27 Nov 2009
    True and since I've got the powerfeed on it it's so much easier on the arms :clap:
    Yea the mill was almost double the price of the lathe :eeek: the clamp set was pretty expensive too mind the flycutters was cheap though had to buy a collet for them :waah: the powerfeed was £270 :sigh:
    I'm sure you will get one eventually mate
