Build Advice New build ~£1000
Discussion in 'Hardware' started by samozamo, 22 Dec 2014.
  1. samozamo
    samozamo What's a Dremel?
    19 Jul 2010
    Budget: £1000
    Main uses of intended build: Gaming, general internet usage.
    Parts required: Everything inside the case, including case, excluding HDD.
    Monitor resolution: two monitors 1920-1080.
    will you be overclocking: Maybe in the future.
    I've been looking at building a new computer, got around a grand to spend on it and I've got these components so far
    http://www.scan.co.uk/savedbasket/5201ee9d30384196a674253e6e076047
    any final tweaks any one would suggest?
  2. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Will you need Scansure? It's on your basket adding £26.32 to the total.
    Also you have more than 20 posts so you're entitled to free delivery which also frees up £9.58 off your total. - http://forums.bit-tech.net/showthread.php?t=186923
    Are you a student? Or know anybody that is ;), Windows 8.1 Pro x64 is £49.99 if you're a student/know somebody that will get you one.
    All this money saved could be put towards a better cooler/PSU.
    RAM - I always advise against larger heat sink ram especially when using air coolers to maximise compatibility, if you get an AIO hyrdo cooler then you will have no issues with larger heat sink ram.
    Rest of it looks ok, great graphics card, excellent cpu, good motherboard, dvd-rw's are mostly the same, Samsung SSD - can't go wrong with that, corsair Case - I'm a fan of corsair cases.
  3. samozamo
    19 Jul 2010
    Oh thanks for the tips, I'd totally forgotten about the free delivery! I'll look into the AIO hydro cooler, since in my last computer my CPU fan did actually make atleast one of the RAM slots unusable :/
    New basket http://www.scan.co.uk/savedbasket/4df36c16029646b9a9d4fdca8eebd63d
    Minus the scansure, not sure how to remove that from the saved basket.
    Plus windows for £49.99 makes its a few pennies from £1000.
  4. Cei
    Cei pew pew pew
    22 Mar 2008
    Where's the student deal from?
  5. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    I agree with modd1uk about the savings. Grab a student 8.1 if you can! Anyone with a college or university email is all that is needed.
    The DVD drive, really? Is it only going to be used for the 8.1 install? If so a USB stick is all that is needed you can download the bootable ISO directly from Microsoft with the product key.
    I would get the EVO 850 over an 840 if it is available at the time of purchase, the nand is much improved.
    The rest looks solid. A better PSU and cpu cooler could be had with the savings :)
    Microsoft
  6. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    This is the student deal - www.microsoftstore.com/store/msuk/en_GB/pdp/Windows-8.1-Pro-Student/productID.288533400
    It's not a cut down/modified version its proper Windows 8.1 Pro :).
    Dizzi speaks sense, if the 850 is in stock at the time of purchase then order it, if not the 840 is still a great SSD.
    The money saved on delivery, windows, scan sure could/should be put towards a better cooler :).
    Regarding the RAM, it's a common thing a lot of people overlook, but if the case can fit a decent AIO cooler in then get one with the money saved :p
  7. samozamo
    19 Jul 2010
  8. N17 dizzi
    23 Mar 2011
    A damn fine build. Hope those 850s ship soon, particularly if you have an itchy trigger finger!
  9. samozamo
    19 Jul 2010
    yeah I know what you mean! But scan says the 29th, so not too long to wait :D
  10. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    You competent building it? Should be a beast.
  11. samozamo
    19 Jul 2010
    Yeah, well I put together the one I'm using about 4 and half years ago, so should be okay :D And I've had to replace my mobo 2 years ago and my cpu fan a year ago, so I'm too rusty!
  12. Impatience
    Impatience Minimodder
    6 Apr 2014
    Erm.. Correction, it's free! xD You get 2x Free copy of Win7, 8 and 8.1.. Also 10 when it comes out.
    Source: I'm at University of Portsmouth
  13. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Even better if you can source a free legit copy, if not £49.99 for an OS isn't expensive at all.
  14. Impatience
    6 Apr 2014
    Yeah, unfortunately my copies are all tied down in little projects. (And family members PC's.. For a small donation to my student funds :p )
  15. samozamo
    19 Jul 2010
    How do you get it free? I'm currently a student at UEA.
  16. Impatience
    6 Apr 2014
    On the IT page of the UoP student webpage, it has a link for purchasing software (as students have ridiculous discounts on software nowadays..). I'd look about, or ask your Uni's IT people about it.. Each student at UoP gets a login for it!
  17. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
  18. loftie
    loftie Multimodder
    14 Feb 2009
    Does Devils Canyon take 1.65v ram OK, I thought you weren't supposed to run anything past 1.5v?
  19. javaman
    javaman May irritate Eyes
    10 May 2009
    If your a student check if the educating body is part of MSDNAA. You might be able to get windows for free plus a whole other host of MS software on top of that.
    https://www.dreamspark.com/ is where you can check and download from
  20. samozamo
    19 Jul 2010
    How can I check this for sure?
