Hardware Noctua NH-C12P CPU Cooler Review
Discussion in 'Article Discussion' started by Tim S, 1 Jul 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    God I can't even bring myself to look at CPU HSF reviews anymore because they're all so pricey.
    We need someone to invent one made of cheap material or something that costs £1.50 and still cools pretty well, then I'd be happy. Unless you are seriously overclocking who can afford these intricate lumps of metal for £50+ for the sole purpose of keeping your CPU cool? That's half the price of an average graphics card.
  3. p3n
    p3n What's a Dremel?
    31 Jan 2002
    90 degrees? (then 180?)
  4. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
    Why does it have those gaping holes? Looks like they ran out of metal.
    "copper is good at conducting and holding heat but not as optimal as aluminium at expending it into the air". That's not right. Aluminium is used because copper is very expensive and heavy. With aluminium, since you can afford more of it you can make a nice, big heatsink. It would perform better than the equivalent cost in copper.
    Also, the nickel plating will stop the copper turning into copper oxide from just being in contact with the air. I suppose you could lap the heatsink to get it back to the pure copper layer. It would perform better but I doubt it's really worth it.
  5. Guest-16
    Guest-16 Guest
    Copper holds (specific heat capacity) and conducts heat better, but it doesn't give it up as well as aluminium - that's why heatsinks with copper cores and alu fins work as a great combination. (Anyone else remember the copper cored Taisol?)
  6. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    Its shape looks like one of those thermalright xp-90 coolers.
  7. Ransoman
    Ransoman What's a Dremel?
    18 Jul 2008
    Is this Cooler new? I am sure i have been using this cooler in my machine for a year now. Surprised to see such a late review.
  8. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ya you guys are about a year to late on the review front for this cpu, still one of the better choices for low profile cases and HTPC machines but still a bit late.
  9. The boy 4rm oz
    10 Apr 2008
    Looks like a pretty good cooler for the AMD systems, Noctua have superb build quality so if Iwas going AMD I would not think twice about considering this cooler.
  10. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Why do they keep using the flesh and dried blood outside a Weatherspoons colour scheme. Its nasty.
  11. Ransoman
    18 Jul 2008
    I don't think so, it is HUGE.
  12. HourBeforeDawn
    26 Oct 2006
    I do think so, its in three of my HTPC Cases, a Thermaltake Lanbox, Thermaltake Digital Home Series, and a Aerocool M80.
  13. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    I'm afraid you're wrong there - it's an old myth that aluminium is better at 'giving up' heat than copper, and copper better at taking up heat. That myth is like saying "a pipe or wire has a certain resistance in one direction, but a different resistance in the other".
    The reason they used copper cores and aluminium fins was/is a compromise between using the more expensive, heavier and less easily machinable copper (with its better heat conductance), and the light, cheap and easy to form aluminium.
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    what I learned welding tig.. aluminum heats evenly unlike copper- the heat will spread across the entire piece faster than copper which makes it perfect for cooling fins
  15. gdawg304
    gdawg304 What's a Dremel?
    25 Oct 2008
    Erm...I've had one of these for just over a year now, on an overclocked Core 2 Quad 9450 (running at 3GHz up from 2.66)
    Be interesting to know your ambient temperatures because even when gaming my processor rarely breaks 50C, and only breaks 60 when running an overclocking stress test.
    But according to your tests on the Intel processor you get a delta-T of 54C? so even in a chilly room at 10C you're easily getting hotter than my processor does in quite a warm room!
    Not sure about the test CPU's maximum safe temperature but if mine hit 70+ degrees C under load I'd be concerned!
    will admit the Noctua was very nicely machined with no sharp edges - when removing my old Zalman cooler i did a nice job of slicing my knuckles on the copper fins!
  16. mattmacdonald
    mattmacdonald What's a Dremel?
    1 Apr 2010
    How did you get it to fit in the lanbox? I'm presuming you removed the fan?
    Or did you find some sort of low-profile power supply?
    I have a lanbox and would LOVE to put one of these things in it, but am worried it won't fit...
Tags: Add Tags
