Modding Noritake 128x64 VFD NON-technical thread
Discussion in 'Modding' started by RAM Z, 13 Jan 2003.
  1. Morphine
    Morphine weeee!
    23 Feb 2002
    yeah looks like it
    so do the displays light up for everyone when powered on? did mine blow for absolutely no reason
  2. Hindaine
    Hindaine What's a Dremel?
    23 Oct 2001
    I just get reddish-orange lines and a few pixels light up, but mine still wont run
  3. Morphine
    Morphine weeee!
    23 Feb 2002
    we killed ours i think
  4. Hindaine
    23 Oct 2001
    Naw, The dude who got his working on the [H] forum told me that thats normal, and his does the same thing
  5. SleeperDC
    SleeperDC What's a Dremel?
    29 Oct 2002
    um...you mean he does the same thing and called it working??:confused: :confused: ;)
  6. SleeperDC
    29 Oct 2002
    yeah, just paid for a clear double bay cover
    i will place my VFD on top of my DVDrom when it arrives.
    it's only $2.25USD from the clearpc.ca
    compair to £4.00 at theoverclockingstore
  7. Morphine
    Morphine weeee!
    23 Feb 2002
    looks like ive gotta rethink my wiring then, cuz it seems to me like i killed mine (they lit up and now they dont) but now they do what everyone elses does. weird
  8. linear
    linear Minimodder
    5 Oct 2001
    okay, after seeing the dismal success rate on [H], I decided a relatively foolproof wiring tutorial would be in order:
    http://forums.bit-tech.net/showthread.php?s=&postid=247414#post247414
    I haven't tested this yet, mainly cause it's aimed at software I don't yet have. If you want, you can substitute FLECOM's table of connections for mine, and it ought to work with that Markuszehnder plugin. I'd only mess with that if you want some instant gratification. I wrote the tutorial mainly to show you all an easy/cheap way to keep the connection numbers straight.
  9. Hindaine
    23 Oct 2001
    FLECOM's wiring worked for me, once i got it right :p
  10. linear
    linear Minimodder
    5 Oct 2001
    Okay, but there's not "one true wiring." The software is coded to assume certain signals on certain pins, and that can differ among software. That wiring works with the MarkusZehnder plugin.
    And where's your pics?
  11. linear
    linear Minimodder
    5 Oct 2001
    Well, lads, the auction is over, how'd you all do?
    I got me 3 more, one is going to cheesie.
    Check out Chrix's pics of the thing in action:
    :rock: :rock: :rock: :rock: :rock: :rock: :rock: :jawdrop:
  12. bmph8ter
    bmph8ter What's a Dremel?
    12 Jun 2002
    I completely forgot to check it the last couple days (I bid the first day it was relisted), and the @#$%^^ price went up. No VFD for me. :wallbash:
  13. RAM Z
    RAM Z What's a Dremel?
    8 Jul 2002
    Mine is working and looks just like his. Thanks Chris you rock!
  14. dakar
    dakar What's a Dremel?
    6 Mar 2002
    Got 2 on thier way... now the hardest part of all... awaiting thier arrival before trying to let the smoke out or keeping it in depends on my luck.
  15. Morphine
    Morphine weeee!
    23 Feb 2002
    me sighs and looks at my two borken (i think) displays. Hmmm ill try redoing the wiring and see if that helps. I'm thinking i either fried them (reversed +5v/ground) or the IDE connector thingy isnt piercing the wires and makin good contacts
  16. RAM Z
    8 Jul 2002
    I used your connector idea for my display. Mine was connected correctly the whole time, My problem was that I didn't have the correct version of LiQuid MP3. If that is what you're trying to use than check to see if you have 9.3 not the 9.2 from the website.
    Thanks to chrix walking me through it I got mine working.
  17. mod-ern man
    mod-ern man What's a Dremel?
    12 Nov 2002
    Thanks for the lead guys, I got me one too.
    I'm still high from getting my 4x20 usb port powered lcd going. Don't dispair those of you having trouble getting them to work, it took me 2 months of on & off wiring & testing to get there. Check, check, & check those connections.
  18. linear
    linear Minimodder
    5 Oct 2001
    So we should mark Liquid-MP3 as supporting this display?
    RAM Z, what wiring did you use?
  19. RAM Z
    8 Jul 2002
    Same one you listed. But it didn't work at first. So I had to use the newest version of Liquid MP3 9.3 released Jan 19th. That will make it work.
    Liquid MP3 9.3 fully supports this display. Chrix has already made new skins for these also.
  20. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    I'm still waiting on my displays from his FIRST selling.. I'm wondering if they got lost or something. How did you guys recieve them? UPS, FedEx, USPS, what?
