News Nvidia study links FPS to kill-death ratio
Discussion in 'Article Discussion' started by bit-tech, 8 Mar 2019.
  1. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Seems a little convenient the 20 series was left off that scatter graph yet included in all of the other slides. I feel like a more accurate study would have been 60Hz vs 90Hz vs 120Hz vs 144Hz vs 240Hz. As that's realistically what they're checking. As people with a better GPU are more likely to own a better monitor.
  2. Mister_Tad
    27 Dec 2002
    I feel like a more accurate study doesn't try to imply causation through correlation at all.
    Take a sufficiently large test group or varying abilities, set them on a slow system, medium system, fast system and then talk about results. Anything else is just making it up.
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    And given the extreme influence luck has... who spots the opponent first, does a third player turn up and try to score some cheap shot while you are dueling, how long it takes you to find shield after landing etc a sufficiently large sample size would need to be utterly absurd in size.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I don't get why something that's been know since the early days of competitive FPS' is still debatable almost a generation later. :confused:
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    so TLDR is, turn off all Antialiasing, set graphics options to minimum and buy the fastest monitor you can afford. Don't bother with a new GPU because you'll be turning off the shineys anyway, they're just a distracion.
    jb0 and MLyons like this.
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Where is their methodology? How many participants were in the study? What extraneous variables did they control for and how? I.e. maps used, player experience, other demographics. How reliable and valid is their testing? What is the possibility of bias and conflicted interest in this "research"?
    Every part of that little study reeks of bias and general scientific hokum.
    jb0 likes this.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Bingo, with the exception that faster GPUs continue to shave off render time even once you hit the FPS cap.
  8. loftie
    loftie Multimodder
    14 Feb 2009
    Lies lies lies lies lies. You need the maximum FPSs, so you need a 2080Ti to unlock your full potential. It's the weapon of choice. Just do it......:worried:
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Because games are a lot more complex than in the old days.
    In a game with extremely simplistic mechanics like UT99 it may be 92% git gud and 8% technical stuff like framerate, ping etc while in more complex games like Fortnite it may be 98% git gud and 2% technical stuff like framerate, ping etc.
    MLyons likes this.
  10. The_Crapman
    5 Dec 2011
    There are SOOOOOO many unknown variables it might as well have included donkeys playing on a speak and spell.
  11. edzieba
    14 Jan 2009
    Because Ngreedia said it, so it must be wrong!
  12. jb0
    jb0 Minimodder
    8 Apr 2012
    It might, if that Speak & Spell runs nVidia spyware.
  13. Corky42
    30 Oct 2012
    The complexity of the game doesn't change the maths though, the sooner you perceive 'an' event the sooner you can react.
  14. jb0
    jb0 Minimodder
    8 Apr 2012
    I like how the blue line for the 1070 starts curving DOWN at 35 hours a week.
    If gaming is a full-time job, get literally any other card.
  15. Anfield
    Anfield Multimodder
    15 Jan 2010
    All else being equal and the difference in framerate being big enough to make a statistically significant difference? Sure.
    But since steps 1 - 1000 of git gud scrub are "be the attacker with a carefully laid out plan of attack rather than the reacting victim" especially when combined with the extreme prevalence of one shots in Fortnite... you'd need a crazy difference in fps (say 30 vs 144) to reach statistically significant territory.
    Also lets not ignore the issue that nvidia used K/D data from BR games like Fortnite and Pubg in the first place, because killing fools isn't even the goal in them (sit around until the fools kill each other and picking your fights carefully to have the balance tilted heavily in your favour is the easiest way to an umbrella / chicken dinner, as a consequence the K/D data isn't actually a valid measure of success in BR games to begin with).
  16. Corky42
    30 Oct 2012
    You don't need to be in statistically significant territory or a carefully laid out plan of attack rather than the reacting victim, yes the former would useful if you were collating statistics and the former useful no matter what, but none of that changes the maths.
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    No one is trying to change the math.
    But common sense makes it obvious that nvidia used massively flawed data to exaggerate a small impact into a big one.
  18. Brett89
    Brett89 Minimodder
    15 Dec 2005
    This study reminds me of studies that monitor companies have funded to show that more monitors increases productivity. That being said, I have three monitors (nothing fancy just happens to be 3) and nvidia graphics in all my computers. I'm really rebelling against these studies.
    And I still very much suck at FPS games.
    For the record, the monitors aren't new or anything fancy, most were purchased used.
    The graphics cards are not the bees knees either, one is an advanced card, the other is an older card that is also Nvidia.
  19. Gareth Halfacree
    4 Dec 2007
    I have one monitor - well, I have a spare that isn't hooked up as well, an old 1280x1024 thing - and no discrete graphics in any of my systems. Guess there'll be no chicken dinner for me...
  20. Mr_Mistoffelees
    26 Aug 2014
    There we have it, if you have a big, fast sausage, you're going to win...
    The_Crapman likes this.
Tags: Add Tags
