Ode to Silence - Updated September 18
Discussion in 'Project Logs' started by fyes, 14 Apr 2005.
  1. Avner
    Avner What's a Dremel?
    19 Sep 2003
    WOw that's great !
    I envy you all USA people, It's nothing for you to get all these tools and materials :waah:
    Can you please take a picture of the bit used for drilling it ?
    Thanks !
    Av
  2. fyes
    fyes What's a Dremel?
    25 Mar 2005
    Here you are:
    That's a 1/2-inch titanium coated bit that I used to drill the large holes for the fittings. The end-mill is a 3-flute from Attitude Cutting Tools, 1/4-inch. This is used for cutting the channels and removing a lot of the excess, before I get down to filing.
  3. Avner
    19 Sep 2003
    wow these are nice !
    are they expensive ?
    or about ~20$ ?
    I wish I find some typed of them....
    and what about the drilling machine ?
    just a standing drill ? or...?
    sorry for asking so much, but I'm on my way to making an Evaporator CPU Block, so I need to explore a bit :idea:
    Thank you so much ! :thumb:
  4. fyes
    25 Mar 2005
    Drill bit was $16. End mill was dirt-cheap: bought them off ebay at $8 for a set of 4 of them.
    Drilling machine is my trusty old drill press, which you can see in one of my first posts in this thread. The precision is terrible, but it seems to be sufficient for what I'm doing.
  5. Avner
    19 Sep 2003
    OK Thanks,
    I have to say again that it is very well done ! :thumb:
    I will follow ! :)
    Av
  6. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Very Nice, I'm going to subscribe to this. Im not much of a fan of waercooling stuff but I like to see people making homemade stuff.
    I also see your from Atlanta, I used to live there, well kinda near there, I lived in woodstock.
    Cheers Mate and good luck.
  7. fyes
    25 Mar 2005
    Update June 28
    The CPU is now watercooled! Wahoo!!
    So, of course it starts with soldering the top onto the base of the CPU block. Here you can see my hi-tech gravitation press device:
    After cooling down a bit, it looks nice and messy:
    The the handy end mill and drill press are used to remove the excess from the top:
    The lots and lots of filing. :duh: Followed by lots and lots of sanding. :duh: And still it's not perfect. :sigh: Ah well, maybe I'll come back to this later. Or not.
    So, then I had to do even more filing to modify the hold-down so it would fit around the fittings. Lesson -- figure out which hold down you're going to use before you start drilling the copper.
    But it looks good anyway:
    Leak test:
    Other nifty views of the setup:
    The astute reader will have noticed that I've mentioned nothing about the radiator yet. Uh, well, it's not actually been built yet. However, here's the secret cooling mechanism:
    Yep! Submerse the resevoir in a pot full of ice-water. Hehe.
    Anyway.... CPU idles at 27 C and goes to blistering hot temp of 33 C under CPUBurn. I'd say it's working.
    As far as the radiator goes, I've got a few ideas. Here's a teaser:
    Those are 1-inch copper pipes, 2.5 feet tall. I want to make it into an art-deco looking piece of machinery. Any design gods out there want to make some suggestions for me?
    Cheers.
  8. phuzz
    phuzz This is a title
    28 May 2004
    ooo, nice ideas for the rad...I'm not much of a designer, but my first thought is, clockwork? Kinda retro steampunk sort of thing maybe, see if you can find some of those big hand valves and see how they look on it.
  9. CaPs_On
    CaPs_On What's a Dremel?
    3 May 2005
    Thats nice. looks good and works good aparently.
    Off-topic: What program do you use for that render of yours. seen many use a 3d program! an i was wondering witch one.
  10. Avner
    19 Sep 2003
    it doesnt have enough surface...
    if you dont want to use fins, like in a normal radiator, i would do that:
    Code:
    one in the middle with 8 around it,
    that would be much more efficient.
    and not much more expensive to do
    Avner
  11. fyes
    25 Mar 2005
    Thanks!
    Sofware is Alibre (www.alibre.com ). Relatively inexpensive, but lots of capability for solid modelling.
  12. fyes
    25 Mar 2005
    Right. I need to design the fins, but I want it to have the art-deco look, that's why I was asking for suggestions. That model is just the base idea.
  13. Avner
    19 Sep 2003
    OKay,
    I think you can reffer to my idea with 8 tubes
    which, as i said - shouldn't be much more expensive...
    Av
  14. fyes
    25 Mar 2005
    Musings June 30
    Here's what I'm thinking about for the GPU block. It maybe a little too intricate for my clumsy drill press, but I'll take a crack at it anyway.
    Cheers.
  15. Firehed
    15 Feb 2004
    looks tough to pull off, but a good design. Not too restrictive but a lot of surface area so it should cool well, without some crazy impossible design.
  16. psynapse
    psynapse What's a Dremel?
    29 Jun 2005
    If you can't fit all 5 channels in the GPU block, you might want to consider 4 with the 3 "divider" pieces on an angle to increase surface contact with the flowing water.
    So instead of ( |||| )
    You'd get ( \\\ )
    Just an idea.
    Bound to be easier to machine too :)
    Awesome stuff man, i'm watching this project :dremel:
  17. barbz
    barbz What's a Dremel?
    31 Jan 2004
    looks nice, good job on finishing off that CPU block, looks good, any performace information as yet? anyway, that gpu block looks promising if you can pull it off. Any more teasers for the radiator, that looked nice, whatever it was, please, its eating away at me. good job, keep up the good work.
  18. yellowbomb
    yellowbomb Minimodder
    12 May 2005
    I like what you've done. You give hope to the most mechanicaly challanged of us...
  19. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    how about something like this
  20. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Kinda reminds me of the Reserator by Zalman. :p
