P_R_I_M_E -- Completed.. 12/24
Discussion in 'Project Logs' started by scopEDog, 29 May 2003.
  1. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Good to see the ideas flowin' :) Now someone that posted today already got really really close to the correct answer..........:naughty:
  2. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Oh I was just waiting for this contest to end (since I only had one extra set of this "mystery piece") :)
  3. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Is that thing some kind of hooking device to hold on a hinged part? Mobo tray perhaps? :rolleyes:
  4. dallas
    dallas What's a Dremel?
    19 Aug 2003
    Are they then Heat sink clips?
    Cool case by the way :D
  5. dallas
    19 Aug 2003
    Are they the clips that hold the Heat sink / water block on the motherboard?
  6. rodaniel
    rodaniel What's a Dremel?
    7 Sep 2003
    I get the impression that the mystery parts are a pair, not just a single item. At any rate, I still think this is a bracket for holding a resevior or perhaps an optical drive.
    Really looking forward to your next pictoral update scopEDog!!
  7. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Man some of you guys are sooo close to the answer you can taste it :)
    and Hwulex...whats up with that avatar :lol:
  8. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    hehe ive just spent 20 mins brousing the log again and i cant figure it out! I really want to know now too you tease :p
    I was thinking however they look like 2 fairly heafty lumps of metal and would probably cost a fortune for any of us UK moders to get delivered! :D I just want to know what they are now :duh:
  9. NiHiLiST
    18 Aug 2001
    Are they just CNC'd lumps of pure leet?
  10. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    They are 1/4" pieces of aluminum CNC'ed...oops did I say too much?
  11. andyunder
    andyunder What's a Dremel?
    22 Mar 2003
    are they the things which split the water from the pump up? cant remember what they are called
    edit: Manifolds
  12. Sid
    Sid Banned
    13 Mar 2002
    Looking very good. It must be solid as a rock with that thickness of aluminium, which is a good thing. I like the whole solid feel to it with the dual power supplies etc. It makes people think, "now this is a serious machine" and it certainly will be with a dual Xeon. :)
    To be honest, I wouldn't like to see this professional looking case spoiled by multi-coloured lights etc. I think it'd be best to keep it quite subtle looking.
    I can't say I'm that keen on the PSU windows, but apart from that. Good work. :dremel:
  13. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    Are they holes in the items? If so, would you be fixing rods between the two, to create a sort of 'rail' system. To slide things along / hold things?
    Hmmm....
  14. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Yes there are 7 holes on each one...the plot thickens :naughty:
  15. olv
    olv he's so bright
    23 Sep 2002
    Are they brackets to support some sort of mechanism so you can slide out some internal stuff like watercooling bits, pump, resevoir etc.. or something else in a slidey and efficient manor?
  16. scopEDog
    scopEDog Minimodder
    5 Mar 2002
  17. olv
    olv he's so bright
    23 Sep 2002
    thats a yes then ;) lol :lol:
  18. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    I think that they are mounting brackets for a water cooled harddrive. Yes thats what I think they are :D
  19. NiHiLiST
    18 Aug 2001
    Slide out reservoir for filling?
  20. Atomic
    Atomic Gerwaff
    6 May 2002
    Uh. How big are these things it's hard to guess withyout a scale.
