Other Photos of your computer
Discussion in 'Hardware' started by [KNIGHT], 9 Jan 2010.
  1. typewriter
    typewriter What's a Dremel?
    18 Sep 2009
    Solo with Orochi cooler and a GTX 275 card...
  2. Whitesky
    Whitesky Minimodder
    8 Jul 2009
    I'll post internal pics in my own build log thread eventually..
    As for seen here,
    Zalman GS1000 case
    2x HP L2465w 24" displays :rock:
    Logitech G19 color LCD keyboard
    Logitech G5 mouse
  3. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    wtf is that massive thing eating ur cpu!!
  4. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
  5. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    ^You've just made me want to strip down my Stacker and paint it mat black. That looks fricken awesome. You do it yourself?
  6. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    yer not properly though. would have loved to get it powder coated but just cant afford it so £10 black matt car spray is what i used which worked fine.
    Ditching the fans soon for some sharkoon silent eagle ones. Also the cables need some more tidying up and tucked behind motherboard tray but haven't got round to doing that yet.
  7. matty4467
    matty4467 ...
    21 Aug 2009
    Hello,
    Here is my PC, nothing fancy or modded :(, but it does the job,
    Really need to take my last christmas dec's down, :wallbash:
    Sorry about the last pic, tad blury.
    Specs are in my sig, and the case is a Coolermaster Elite 360 - Cable management is horrid in this case,
    Matty
  8. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    After a little tidy up
  9. Pookeyhead
    30 Jan 2004
    http://www.frostytech.com/articleview.cfm?articleID=2258
    Also pretty rubbish apparently.
    Why did you mount the Fenrir the wrong way around? I'm pretty damned certain it would perform better facing the rear fan.
  10. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    i cant mount it the other way on my board, the bracket is the wrong size. and my temps are fine as is. Idle i get 25c and load i get 48c with fan on low
  11. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Thats the prob with some AMD mobo's the AM2 mount is not mounted to allow you to orientate the Fenrir so the fan blows into the exhaust, instead it sucks air off the back of the gpu and throws it into the top of the case which is fine if you have a roof fan. (Which I don't).
    Thats the reason I swapped mine out for the Scythe Mugen 2 which is doing a much better job and allows me to use the first 16x pci-e slot thus hedropping my gpu temps as it has much more room to breathe.
    Lankuzo's temps seem good so it's not an issue for his setup.
  12. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
  13. mrbungle
    20 Sep 2004
    Well I have sorted my rig and cooling just need to save pennies for a decent case....
  14. Teelzebub
    27 Nov 2009
    The kitchen computer used for about everything by everybody
    TT saprano case / Hiper 425 psu / P5Q PRO mobo / arctic freezer pro cooler / E6850 cpu / gainward 8800gt gpu / 2x2g corsair dominator 1066 ram / 750g samsung F1 / Vista ultimate 64
  15. joco2_uk
    joco2_uk What's a Dremel?
    1 Sep 2009
  16. Pookeyhead
    30 Jan 2004
    My current set up.
    Inside
    Lian Li PC-A6010
    File server that lives under the desk
    NAS box... basically a mirror of the server... soon to be moved to the garage when weather permits the laying of ethernet cable.
    All lit up at night
    Nice Win7 Theme
  17. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    link to theme pooky!
  18. Pookeyhead
    30 Jan 2004
  19. Jipa
    5 Feb 2004
    Woah how can you use the screen so high up :I
  20. Pookeyhead
    30 Jan 2004
    It's at eye level. Just a low angle shot makes it look higher. My eyeline is dead in the middle of the screen.
