Scratch Build – In Progress Project: Aluminum Water Cooling Case
Discussion in 'Project Logs' started by Spotswood, 17 Apr 2011.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Every time I look at the side panel mounting method I want to do that :D reminds me of how nice & easy they mount on/off, could do it 1 handed on my old Lian-Li, my favorite panel mount method when done right like this. :D
    And cheaps fix is so true, original version & fixed version. :D
  2. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Another router template was made to cutout the areas for the PSUs out of the back sheet. A guide was clamped to the bottom of the template to keep the cutouts perfectly aligned along the bottom.
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nicely done :) & all these jigs you make, do you keep them aside labelled for future use to make things quicker?.
  4. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Its amazing the n00bs who cant figure out that this is not his case lol.
  5. Spotswood
    30 Jul 2007
    Yes, usually I will save and re-use templates. But in this situation I could make the opening larger (because of the extra room) to avoid having to square-off the corners.
    :thumb:
  6. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    I'm quite glad to see this going again :)
    Can I ask what speed you use with the router? I have two routers, one variable speed, and one non, and I was thinking about using the non-variable speed one for this.
    And if I could also ask what bits you use? (You said 3/16" and 1/4" down cut spiral, but I was wondering about brand)
  7. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Awesome stuff amazing craftsmanship and great work with the router. I have not been brave enough yet to run a router through aluminium.
  8. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    and do you use any lubrication? :D
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
  10. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Aaaaaawww yeaahhh.
    Superb work to now man, keep it up, you got a sub!
  11. Spotswood
    30 Jul 2007
    Turned out that I needed to cut one more slot out of the bottom shelf. But the last time I used my wooden "small slot" router template, I somehow managed to crush one edge, so I quickly cobbled together a new out of some left over t-slot extrusion. I'm really loving using these t-slot extrusions to make router templates - fast and accurate!
    Here's a teeth-shattering video of me cutting out the slot:
  12. matt...
    matt... Slacker
    18 Nov 2009
    This looks like it will be awesome!
    But seriously, 3 x 140x4 radiators and 1 140x3 radiator - are you trying to cool Africa??!? :jawdrop:
  13. SpleenBeGone
    SpleenBeGone What's a Dremel?
    20 Jul 2005
    I love how elegantly simple your construction methods are.
  14. Spotswood
    30 Jul 2007
    Wow! That's one of the nicest compliments I've ever received. Thanks!
    One of my motivations for publishing a build log is to convey how relatively easy it is to craft a case out of aluminum. Seriously, all you need to invest in are a drill press, a router, and some hand tools. :thumb: (Unless your Attila, in which case, all you need is a hand file).
  15. SpleenBeGone
    20 Jul 2005
    I've actually been considering making a case for a while, but for some reason it never occurred to me that I could cut the aluminum with my router. The way to get nice clean cuts like that was always the biggest drawback for me, as I never had access to a CNC, and dremel and nibbler cuts look bad IMO. When I build a new rig, I'll be making a custom case as well using your method, and will be following your threads for more tips.
    Edit - Also, where did you get that self centering vice? I could get so much use out of one of those for all my projects.
  16. Spotswood
    30 Jul 2007
    I got the vice from Grizzly. And is of better quality than most other tools from that site.
    Yeah, you'd have to kill me in order to take away my vice. :D
  17. SpleenBeGone
    20 Jul 2005
    Thanks for the link, I'll be ordering one of those.
  18. Spotswood
    30 Jul 2007
    Performed the mind-numbing task of fastening the bottom and top sheets to the case frame via flat head socket cap screws. Through and countersink holes were drilled into the sheet and transferred to the case frame via a self-centering counterbore drill bit.
    Bottom sheet all fastened:
    And top sheet all drilled out:
  19. FatPandas
    FatPandas What's a Dremel?
    4 Sep 2012
    Ah - that's what they're called. Cheers man, you saved me a lotta headache :thumb:
  20. Spotswood
    30 Jul 2007
    Drilled out the holes for the vandal resistant switches and fastened the front sheeting to the case.
