Scratch Build – In Progress Project: Aluminum Water Cooling Case
Discussion in 'Project Logs' started by Spotswood, 17 Apr 2011.
  1. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Another requirement for this case is a hidden door latching mechanism.
    Look Ma! No latches!
    A length of .125x.75-inch flat bar was bolted to the bottom of the door to act as a lip that will hook into the u-channel along the bottom of the case, for example:
    Along the top of the door, there is a piece of angle with three "hooks", which were routed out using a cobbled together router template.
    A thick piece of flat bar was filed down to where it'll slide easily inside the u-channel along the top of the case. To that three "posts" were bolted to it. When slid forward, the posts will engage the hooks.
    motorsportcfd and Waynio like this.
  2. peteski
    peteski long live the pc
    8 Jun 2011
    nice work mate :rock: :rock: :rock:
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Beautifully done panel mounting methods. :clap::rock: rep:D
    Very Lian-Li style but done in a dudes shed instead of a nice factory, awesome work Rich. :D:rock:
  4. motorsportcfd
    motorsportcfd What's a Dremel?
    25 Jan 2012
    Awesome build! Great craftsmanship!
  5. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    wow spots... great work!
    your build thread has been quite informative as well!
    btw, how did you install the self clinching nuts? (PEM nuts)
  6. Spotswood
    30 Jul 2007
    Thanks.
    I simply drilled the appropriate size hole and squeezed it home using my bench vise.
    A large area of the right side panel was cutout for a 16x15-inch acrylic window.
  7. Spotswood
    30 Jul 2007
    I made a mistake, placing the false back too far into the case, which required having to re-fabricate the back sheet. But I figured I could take advantage of the situation by improving the mounting of the motherboard tray, by fastening the tray to the false back with a 7/8-inch long spacer.
    I don't remember if I already offered this tip before, but I try to reduce the wear and tear on my 1/2-inch flush cutting router bit by first rough cutting with a 3/16-inch spiral downward cutting bit.
  8. Spotswood
    30 Jul 2007
    A PSU mounting plate was routed out of a piece .10-inch thick aluminum sheet with the help of a custom template.
    In order to accurately transfer the locations of the PSU mounting holes, threaded hole transfer punches (mcmaster.com part # 3385A31) were threaded into a PSU.
    And then the PSU was carefully centered and pressed into the sheeting, with the end result being a perfect squarely mounted PSU.
    [​IMG] :rock:
    Cheapskate likes this.
  9. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    great, nice punches !
  10. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Awesome work man, good details on that case.
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice to see this still rolling on Rich, looking excellent. :)
  12. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Holy molly man thats SICK!!!! Excellent job !!!
  13. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Great work. Love the rounded corners :)
  14. yoishiro
    yoishiro What's a Dremel?
    8 Nov 2010
    jejej nice actual build of the mick64 design (thats how i calll this 3 thermal area design)
    i got some questions
    1. how much does it weights
    2. how much it cost to make and how much u are willing to sell ?
  15. Spotswood
    30 Jul 2007
    #1: It weighs around 50 pounds.
    #2: Unless you think the SilverStone TJ11 is inexpensive, you can't afford this case. :hehe:
  16. yoishiro
    8 Nov 2010
    wait wat?
    the TJ11 inexpensive , your case cant be afforded ? what? dont get it lol
    #2: Unless you think the Silverstone TJ11 is expensive, you cant afford this case.
    there , i think i've fixed it
  17. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    spotswood has it worded correctly.
    the tj11 is a $500-600 case. unless you think $600 is cheap (inexpensive), you cannot afford his case.
    BTW nice work spot!
  18. yoishiro
    8 Nov 2010
    Que? lol
    ok i got it now lol
  19. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    There's this saying in the jewelry world: If you have to ask how much that ring is; you can't afford it. ;)
    Same applies for stuff like this case.
    One of + entirely custom fabricated +made to the client's own specifications = expensive.
  20. Cheapskate
    13 May 2007
    IFixedThatForYou.:D
    Loving the heavy-duty-fied OEM features. Those punches are a sweet find too.
