VENTS - well it wouldn't be the same without vents but this time around they go in over rather than sticking out. I figured the ATCs chassis was wide enough without sticky out vents so went for these which will eventually be stuck in place then filler to smooth the rim so they are seamless but before that, both panels will be powder coated and wet sanded to give a good base for primer and paint. I also have a new sponsor by the name of OCZ which i'm over the moon with tbh and are supplying 6GB of PC3-10666 triple-channel memory and couple of 60GB 2.5 Solid State Drives so a massive thanks to OCZ
Congrats on the sponsor. The vent looks great so far @Coldon Check out this guys other mods and say whether or not the filler job is messy and uneven.
Wow, those vents are going to look great. So much classier on a CM case, than any OEM version on a SilverStone case...
If you'd also READ the update rather than look at the cool pictures then you'd notice he said all that stuff earlier Vents in + side panels repainted. Looks great, can't wait to see how it turns out.
Aye, i got to admit, its hard looking at the pictures whether the vents go in or stick out but it should become more clear once they are painted........i hope This picture might show it better, plus you can see the windo a bit better.......
Naa mate, without the vent there is about 40mm clearance and with the vent there is still at least 20mm
Always with the vents lol, they do look awesome I have to admit haha. Congratz on your sponsor mate. Damn I wish I had a couple of SSDs lol.
You kept the clean simple lines of the 840 in mind you made those windows and vents, and it looks superb.
