Project: BGAIOC 2T Monster : 19th MAY Log :"SCRAP TIME"
Discussion in 'Project Logs' started by CrazyModder, 14 Jun 2006.
  1. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    Sorry to disappoint you, but I never claimed to be great at any of this. That I will try to do better every day of course, would it be enough to please everybody definitely no. Don't worry, I had seen and know all the flaws in this case, no need to point them out; and yes they do bother me. Would I give you and excuse why they are flaws on it, no.
    " When you change the way you look at things, the things that you look at change".... Dr. Wayne Dyer.
  2. Slakker
    Slakker What's a Dremel?
    27 Sep 2006
    Don't sweat the paint flaws...the workmanship of the rest of the case speaks more than loud enough for your abilities to make up for them :)
    Heck, I'm impressed by your wiring alone...I'm scared simply to change out switches :)
  3. nightmare03
    nightmare03 What's a Dremel?
    5 Jun 2006
    What he said :rock:
    Case looks good!
  4. elliod
    elliod What's a Dremel?
    1 Oct 2006
    i just read this thread in one sitting :sigh: this toke some time but credit do to this project becouse it is simply :jawdrop: what more to be said .
    please keep this modding going it is simple briliant
    :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
  5. CrazyModder
    13 Jun 2006
    So here I start building the water cooling loop for the case
    This are the RADs, already mounted in the RADs bracket
    here they are mounted inside the case, the flash made the top Rad look copperish in color
    this is a closer look, remember all the RADs are going to be cover, by the cover plates
    the pump goes between the lower RAD and the lower intake fan, this will keep it cool
    made this mounting plate for the pump
    this way is easier to mount inside the case
    the pump is secure with three screws to the bottom of the case
    the MOB has the WC blooks already in place
    I tried to do a simple and clean loop, this is what I came out with
    a view from the top, the cable wrap helps with the kinks and looks better
    this is how the loop looks at the pump, it won't be visible from outside
    I drilled a big hole at the top of the case, for the fill port
    a view from inside the case
    now another picture with the fill port in place, the screws don't come all the way thru the case
    a top picture of the fill port
    and here you got another one from a different angle
    this is the top part of the case, WC loop conections at the fill port
    need to connect the drain valve, it goes to that hose in the right side
    drilled a hole for the drain valve
    this is the drain valve, it has a barb at the end; forgot to take a picture of it
    the drain hose has been attached to the drain valve
    the upper two hoses, had to be connected to the RES ( haven't made it yet )
    a picture of the pump showing thru the lower cover plate
    a picture of the right top section of the case with the cover plates back in place
    Well now I had to figure out and start building the RES, that should be the next update.
    See you guys at the next post......CrazyModder ....out
  6. pinny666
    pinny666 What's a Dremel?
    9 Oct 2006
    youre going strong dude modding man keep it up :rock: :rock: :thumb:
  7. THEkorean
    THEkorean 42
    10 Jun 2005
    omg >< that thing is monstrous. NOw that your adding watercooling, al lthat extea copper and liquid is gonna mke it even heavier. soon your not only gonn have trouble picking it up on your own, youll need a forklift just to move it. Good job thought, i love the black wrap around your tubing, what is it called? is it just black spiral wire sleve?
  8. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    :jawdrop: holy crap, that looks amazing! excelent workmanship, great ideas. :jawdrop: keep it up
  9. Evil-Inc-UK
    Evil-Inc-UK What's a Dremel?
    22 Sep 2006
    Very well planned out and great quality outcome so far
    Extremely impressed will be watching for more updates
  10. CrazyModder
    13 Jun 2006
    This is it guys the Reservoir build, enjoy.
    $10 pasta cooker, 4"x12" and 3/16" thick at local department store
    I need a cap for the open end and it will hold the fittings
    little jiggy thing to finish the cap to the proper size
    it fits like a glove
    glue the cap to a green plexi disc
    drill and treated the fitting holes
    fittings in place at the bottom of the disc
    added a clear divider that will go inside the RES to half it size tall
    glue the RES body to the lower plate
    The RES is finish, now to add some stuff to it
    this is just the begining, will continue at the next post
  11. CrazyModder
    13 Jun 2006
    This is where CrazyModder, start working
    I wanted a different looking RES, to be the center piece of the case. Some how I found this at a Pet Shop a Hamster Wheel.
    It comes apart at the middle, so I got a top and a bottom
    I screw one half to the top of the RES and the other will go at the bottom
    this leave me with a gap that has to be fill, some more plexi was added
    painted the wheel to match the color scheme, the green parts are the wheel original color.
    painted the cover plate for the inside too.
    this is how it looks from the top, it will be the same at the bottom side
    build this little bars and sleeve them like the wires
    attach them to the cover plates
    Now you see the RES, almost finish
    I'm not finish yet, some more details are added in the next post..
  12. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    woah man, that's pretty RADical.
    do you have the model name of that hamster wheel?
  13. CrazyModder
    13 Jun 2006
    last details to the RES, at least for now
    I added some LEDs holders to both cover plates
    wired the UV LEDs
    tested them
    now I cover the RES with a black mesh, should look good with the green water
    put all together and is finish for now
    my friend seems to like it
    It end up at 13" height and 7" width, it has UV LEDs at the bottom plate and white LEDs at the top plate, I plan in power them indenpently. I still have to figure out how to attach it to the case, forgot to think about it while building this Mounstrosity.
    Thanks to all of you that comment and voted in this log.....
    P.S. You guys can HATE IT or LIKE IT, but please don't BASH IT.
  14. CrazyModder
    13 Jun 2006
    Sorry I had threw the box away months ago, they do have different colors and sizes to choose from, thanks for the comment.
  15. haggisathome
    haggisathome What's a Dremel?
    1 Oct 2003
    wow :eeek: , thats looking sweet :clap:
  16. Muon
    Muon What's a Dremel?
    1 Dec 2004
    awesome, purely awesome res, i've been inspired.
  17. elliod
    1 Oct 2006
    WOW :eeek: that looks sick :eeek: :rock:
    congrats :clap: :clap:
  18. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    wow the watercooling will be so sweet...your work on the loop, the fillport, the drain and of course the res is really awesome....I give you two :thumb: :thumb:
  19. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Nice RES!
  20. CrazyModder
    13 Jun 2006
    This is the building log of the support bracket for the RES
    its compose of three parts, very simple yet strong
    the parts after painting
    now is assembled, I used glue and screws
    a top picture of the bracket and RES together
    and another shot from the side
    Now the RES is mounted in the case
    a picture from another angle
    and another one
    and last a couple of pictures of the WC loop
    I think is a very clean loop
    WC loop is finished, tested and no leaks.
