Case Mod - In Progress Project: Blue Flames - Case Finish
Discussion in 'Project Logs' started by Nolimited, 24 May 2008.
  1. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Hi my name is nolimited and this is the first time that i start a project :D.
    This is also my first mod i hope you will enjoy.
    The name of this mode is Blue flames why because i will let it paint by airbrush with real blue flames and some special effect.
    But first my case I think every body already heart about the CM stacker STC-T01 my case is 3 year old but is a good case and big.
    Here other pictures.
    [​IMG][​IMG]
    But first step 1 remove all and transfers to the new mini tower.
    The old
    The new
    Now i can start the mod.:D
  2. Nolimited
    12 May 2008
    After all remove i have a clean case where i can start modding
    [​IMG][​IMG]
    [​IMG][​IMG]
    Remove the cover with the coolmaster logo
    The front view without this cover
    next update soon stay tune :D
  3. Darkened
    Darkened Minimodder
    28 Feb 2004
    Let me be the first to welcome you to the forums and wish you a good luck with your mod.
    You know, it's a Stacker, go crazy with it! :hehe:
    Darkened
  4. Nolimited
    12 May 2008
    Thanks i will try
    NoLimited
  5. Nolimited
    12 May 2008
    I have removed the grill from the left panel and i cut the center. I install a round plexi and fix them with the grill.
    Before
    After
    I need to finish the edge
    I receive the blue and wit plexi I can start cut into several pieces one for the top side and one for bottom side of the case.
    [​IMG][​IMG]
    Two parts are ready
    Start with the bottom side.
    First remove the wheels and start cuts and drilling to fit the plexi on the bottom.
    After 1 hour the piece is ready and fit on the bottom.
    Now i need to clean the edge and the bottom is ready
    Next part the bottom
  6. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    As darkened said. This is a classic!
    It will help a lot if u post your ideas so we could discuss. What about an scketch and some starting lines?
    I am sure you will come with a great mod!
    ooo...
    And welcome to Bit-tech :)
  7. Nolimited
    12 May 2008
    Thanks Yemerich all help are welcome and ideas also :thumb:
    i am busy with Sketshup to set my ideas but is not easy and my day are to short :wallbash:
  8. Nolimited
    12 May 2008
    small update
    New parts receive today
    First Metal plate from 100 x 50 for the top of the case.
    I have pickup theys parts yesterday by Elak (Brussels)
    Power pushbutton with blue led
    Male Jack and Jack chassis
    Blue leds for the bottom and top
    I have also receive today Blue fans and CPU cooler
    120mm sharkoon blue fan and 120mm silent fan for the CPU cooler
    next is a 80mm fan from sharkoon also with blue leds
    next the realy great :lol: Thermalright Extreme 120 CPU cooler apparently the best :D
    What a change that i have a big tower :D
    I have already soldering the wires to the pushbuttons and test it and works fine
    [​IMG][​IMG]
    next update soon and all comment are welcome :D
  9. Nolimited
    12 May 2008
    Project: Blue flames update 01-06-08
    Sorry for the slow update i have only the weekend :waah: to work on the case and this weekend i had a wedding :D in my familly but here a small update.
    i start cut the metal on the size for the top off the case
    I cut also the blue plexi same a previous part and place it on the top off the case.
    Side view from the top with all mounted
    on the top of the case a new fan grill will be installed but i orded this last week by Mnpctech
    http://www.mnpctech.com/BilletgrillWb2.gif and i waiting to have this part to start and cut the top plates
  10. Nolimited
    12 May 2008
    After a long week work i will finish some work.
    First finish the power button.
    I find some black flexsleeve at my work this are use on servers very nice.
    the only problem is that all sleeve are to short :duh: i need to put 2 flexsleeve :D
    I have start the cable with the leds for the bottom not easy but find follow tool to hold the cable and then solder them.
    The cable are 50% finish
    and yes the lights works :hehe:
    Today i pickup some pieces 2 harddisk from 80Gb and 1 from 250GB :D
    1 Ide for the data and 2 sata for the boot and OS
    I also receive this week my 80mm billet fan grill from Mnpctech and i am happy :thumb:
    it will be nice on the top of the case :D
    and nice with the sharkoon fan :thumb:
    Thanks Bill for the this nice piece :thumb:
    tomorrow i will make the hole and fix the fan grill on the case.
    Stay tune :p
  11. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    You've got some sweet gear together, I love the top panel.
  12. Aceanuu
    Aceanuu Will-Mod-for-Food
    27 Mar 2008
    Very nice additions. I especially like the blue bottom... even though I doubt you'll see much of it, heheh.
  13. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    looking good my friend :D
    Keep up the good work. Sorry for late welcome but ... Welcome to Bit-Tech :D
  14. Nolimited
    12 May 2008
    Thanks for your comment they all welcome
    I start cutting the top panel from metal and the plexi to insert the fan and the Fan grill
    after 1 hour cut and test i have finish and i am happy it fit good :D
    view from inside with the fan
    Next i will make the DVD and the writer stealth
    There for i use the grill from the front of the stacker.
    I need to cut the two side to let the opening easy.
    i also use part of the stacker to fix the grill on the DVD and two screws
    The view off the DVD with the front grill fixed.
    Closed view
    1/2 open
    full open
    I need paint the front of the card reader in black to have it the same color as the grill :naughty:
    Finish for today the next time i will cut the white plexi the fixed inside the case.
    Stay tune :thumb:
  15. wbdog206
    wbdog206 not me
    15 Jan 2007
    very nice. I really like the stealth job on the dvd drive.
  16. Nolimited
    12 May 2008
    Paint and Button update
    Start paint the card reader :D in black
    First layer finish and tomorow i need the apply a second layer
    Next start to make a hole in the front to placed the button
    Remove the side where i need to make the hole it is easy :hehe:
    After 30 min first part ready
    on the case i need also make a hole to let the cables go to the inside off the case but not easy because there a reinforcements.
    I now not beauty :( full but all cables and button are good in place
    The finish touch
    That's all for today and thanks for reading :thumb:
  17. airchie
    airchie What's a Dremel?
    22 Mar 2005
    I miss my old stacker case.
    They really are the sizz. :)
  18. Nolimited
    12 May 2008
    Update
    I have apply the second layer but i am not happy with it :miffed:
    Some picture from the front off the case with the stealth DVD and the Card reader paint not so bat.
    Zoom from the front
    Next start the inside off the case.
    All comment welcome ;)
  19. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Very nice start, I've got a Stacker too, best cases :D
  20. Nolimited
    12 May 2008
    today i start cutting the white plexi in tree parts for the inside off the case
    This is the first and the other will have the same size i hope ;)
    Finish the cutting
    First test the left side it will hidden the tray bracket :naughty:
    the same at the right side.
    The inside will close and hidden the hd and dvd :naughty:
    An other view
    now i need to findout how fixed all :idea:
    but this is for the next update
    See you at the next update :read:
