Scratch Build – In Progress Project: Blue Horizon - "MOTY" Nominee
Discussion in 'Project Logs' started by riekmaharg2, 8 Jul 2010.
  1. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Oh my frikking word. That is b..e..a..uuutiful! Perfect, and that PSU cover/shell looks insane! And that pump! :jawdrop:
    Well done. You deserve some sexy time now.
  2. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Cable Management on the back - Check
    Amazing custom fittings - Check
    Unbelievably beautiful PSU cover - Check
    This is just too damn awesome! :rock:
  3. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    :clap: Stunningly clean work. Some of those shots look like renders they're so neat!
  4. Sarakon
    Sarakon The German
    11 Feb 2011
    OMG OMG OMG!!! :eeek:
    It looks so sweet and it all just fits together and flows...and that PSU cover does look way better than the concept drawings.
    The acid green coolant is just too cool!! +rep :thumb:
  5. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Thanks Nutman :thumb:, yeah I have to say it looks even better than I imagined :)
    Cheers secretreeve, yeah I think thats because this GPU is quite old its bent under the load over the years, however I'll be getting a new one in the next month or so as its only a HD3850.
    Thanks Fuganter :thumb:
    Yeah me too it turn out great :), it was a bit of a pain to make as all the curves had to be precise but I think it was worth it. Cheers :thumb:
    Cheers Mosquito :thumb:
    lol :) , cheers Razer :thumb:
    Cheers Angel OD, phenoptix, & Sarakon :thumb:
    I forgot to say in terms noise the pump is the loudest part (and its only running at 7.5V) while the rad fan is on low, then when its on full its little quieter than a PS3 when playing a game.
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Sounds wonderful :D & it's easy to say it looks very wonderful. :D:rock:
    Awesome masterpiece. :rock:
  7. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Looking good!
  8. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Great Work! Clean and Beautiful!
  9. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    OMG!!! This is soooo beautiful. Love the psu cover, glad u used the new design. Everything else, just stunning aswell :thumb::thumb::thumb:
  10. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    MOTY 2012! :thumb:
    Absolutely amazing dude, cannot wait for the final shots!
  11. bguilleminot
    bguilleminot What's a Dremel?
    11 Aug 2011
    Impressive design of the PSU, looks AWESOME. And nice mod in the pump, can't wait to see the final pics
  12. peteski
    peteski long live the pc
    8 Jun 2011
    :jawdrop::jawdrop: riekmaharg2 thats the sort of update we have all been waiting for and that psu cover is the tits mate all of it is cant wait for the finle shots :jawdrop:
    :rock: :rock: :rock:
  13. avolla
    avolla Mini Water Modder
    26 May 2010
    Stunning work on the PSU and the build in general. I wish i had the type of experience that you have shown in this build.
  14. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    :jawdrop::jawdrop: That psu cover ... so glad you were open to our comments ... look at it now, it's spectacular.
    The rest of the update as well of course. This is a fantastic result. Two, no, ten thumbs up! :thumb: x 10!
    Five stars added since I seem to have forgotten that up till now.
  15. morbid_looney
    morbid_looney What's a Dremel?
    27 Apr 2010
    first i was a bit "mhe" when i saw the bubbles in the fans plexi, but i must say that they come out awesome with the leds on!!
    overall its pretty damn awesome!!
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Definitely up there with the best of them. :rock::clap:
  17. riekmaharg2
    22 Feb 2009
    Wow thanks everyone :thumb: glad here you all like my work :)
    As Cheapskate said on an earlier post that the small vent on the PSU cover does indeed make the fan noisier, but it takes hours to build up heat which is why I didn't pick it sooner. So I think I will mill some vent holes into it, I've also discovered that my akasa fan controller can power the pump when I've modded the mosfets with a heatsink. And after discovering that I've also found that there is a specific range of speed where the pump goes almost inaudible, so now the entire PC is almost completely silent while idle(browsing internet, word processing e.t.c).
    I'm currently designing a new set of drive bay covers and a way to make the curve in the rad cover I want. And once thoughs parts are made i'll get the final high res pics uploaded.
  18. Mark_Skeldon
    Mark_Skeldon What's a Dremel?
    5 Feb 2012
    Looks awesome! :D
    Sometimes after polishing the acrylic (t-pieces you made) a few quick flashes with a blow torch flattens off the top layer to give the crystal clear luck. Don't do it for too long though or they'll bubble!
    Same with the edges of the PSU cover top plate. Just an option :)
  19. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Wow :D Just The psu cover looks just so great I like how did you sleev the main power cable.
    The water cooling just great job. But how loud is the fan waht are u using???
  20. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    The whole thing just screams thought, design, patience and detail. top notch system, i like the mix of blue and green, works suprisingly well. !!
