Project:FileAnywhere - COMPLETE
Discussion in 'Project Logs' started by ouija, 9 Jan 2003.
  1. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Where did you order the motherboard standoffs from ?
  3. Altron
    Altron Minimodder
    12 Dec 2002
    It's in a tiny alumiinum box.
    I said "Wow are you sure you need such a big box?"
  4. ouija
    10 Nov 2002
    Lol Altron, I get it. I was just :eyebrow:-ing :D
    You can get the standoffs from almost anywhere. I got 6mm nylon hex standoffs from maplin/cpc
  5. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I'll bee needed some too.
    You got a Mappers code for those nylon stand off's?
  6. ouija
    10 Nov 2002
    6mm: QT85G
    Other lengths are available
  7. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Am I the only one to notice this? You've put the switch on the NEUTRAL side of the incoming mains. Something you should NEVER do. All the internals of the PSU will remain live even if the switch is off, posing a serious safety hazard. You need to change the switch to the live immediately...
  8. ouija
    10 Nov 2002
    Please remove the images from your quote, I need the bandwidth :)
    Thanks for noticing that, I thought you were commenting on the incorrect wire colour. It's already been sorted though :p
  9. Xarthan
    Xarthan What's a Dremel?
    14 Sep 2003
    what has happened with this case? did it get finished? If so where are the piiics? :naughty:
  10. ouija
    10 Nov 2002
    It's not finished. I haven't been working on it, or any projects recently. I will be at some point, but not for a month or two. I will probably begin this project from scratch in the same method of the other boxes I've built for people. Since starting this project, I've refined the standoff mountings and so on. Time will tell.
  11. bsodmike
    bsodmike Banned
    11 Oct 2002
    I like how you are using an oversized maplin project box...interesting.
    Lol 'arse end' what a thing to call the i/o ports !!.... Mod on dude, the force is strong with this one! :rock:
  12. Xarthan
    14 Sep 2003
    Where did u buy the box?
  13. bsodmike
    bsodmike Banned
    11 Oct 2002
    Any bet its a maplin project box?
    EDIT:
    [01:46] <DrMike|SB2> got the code for it?
    [01:46] <ouija> kr57m
    PC26 398 (155/8in.) 253 (10in.) 51 (2in.)
    thats the L W H according to maplins
  14. ouija
    10 Nov 2002
  15. Xarthan
    14 Sep 2003
    where can i pick one of those up?
  16. ouija
    10 Nov 2002
    Lol, Maplin
  17. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    Xarthan, Maplin is an electronics store in the UK. Basically, you can check at some place like Jameco or maybe Radio Shack in the US....but I'm sure you will find one there, at least not that big. Try doing a google for metal project box or something like that. ;)
  18. Hyjnx
    Hyjnx What's a Dremel?
    16 Sep 2003
    more picturrres!...im really getting into this!
  19. ouija
    10 Nov 2002
    I haven't even touched it for months!
  20. Hyjnx
    16 Sep 2003
    well go touch it!
