I think polergarn is polishing wool or something like that. Once again: nice work, the inside looks very clean and "stilrent"(sry don't know the english word )
Back from paris!! Hi y'all it will take quite a lot of time to finish it, because I have my best friends here
ok I wanyt some new pics ..... tomorrow i say tomorrow ..... ( new pics ) modd hard .... good project .. realy good dont go lazy
I'm pretty sure i just saw you on a Counter-Strike server ac][dburn or something like that Look forward to the next update matey
hehe tomorrow there might come some pics to please y'all I'm affraid I have grown a bit lazy during my visit to norway but I will definately come back strong now hehe I call myself "Hidden Dragon" and I only play on norwegian servers (frensh and belgian servers are too sucky... and I play with a lot of friends in norway ) Thanks for the replies guys
Small update Hi guys! I promized an update a few days ago.. But to be honest I haven't had time to do much.. I have only started drilling the holes in the dragon dor and cut some pipes for the water cooling of the hdd's. pic's: The hole in the middle is finished. the two holes on the sides have to be cut larger.. I'll use my dremel do file them biger.. I have just cut the pipes so they will fit. I split the water pipes so the discs will recieve the same temerature on the water.. I found out that with noise dampening mats, the blocks won't fit.. so I'll just use the mats underneath and on top of the discs.. I lost the picture of the psu when it was sleeved and outside the case.. so I just took a picture of the case I'm using now.. that's all for tonight.. but tomorrow my friends leave, so Then I'll have lots of time to mod To get the psu out of the case without taking off the cpu fan, I had to "Modify" the case a bit
DvD burner bought Today I bought a dvd burner since I shorted my dvd when I sleeved the psu. It doesn't look good with my second hdd either... bios can find it. but I can't make it work in windows... strange I have changed the jumper on it so it is slave, and I have set it as second boot device in bios. well.. here's the new burner I've grown lazy But I'll go out and frost the side window now...
Stupid question, but the second drive IS formatted from windows, right? Right-click my computer, manage, disk management... see if it's there I like that hard drive block... too bad it doesn't really go with the sleeving
Hey, that PSU is looking pretty damn green! I'm really gonna have to sleeve mine, on the other hand i think I need a new one, mine's damn noisy and stays at about 40 degrees all the time, even when the computer is off, grrr Keep going man, this is going to be a bloody good mod when it's all done. (oh, yeah, a freind of mine has a case like your old one, I had to 'modify' it to get a hd out when he stripped the threads on one of the screws. Also, he really needs to learn what a cable tie is for, it's a mess)
hey! It found my drive!!! But I still can't see it under "my computer"... is sais it is enabled... and nothing is wrong in the device mannager...
hehehe I'm looking at the chaos of cables inside my case now.. I'll do my best to hide them in my mod
Heh! I keep meaning to sit down and really tidy my case properly, but every time i'm like, well, 'I might get a new PSU(or DVDR, or fan etc.) soon, so it's not worth doing too much coz it'll just be more hassle later'. Ahh, the problems of being a modder, you just never know when to stop
hehe Yeah. well: "a great mod is never finished". Firehed or someone else the "volume" tab in "properties" on the disc sais nothing at all... that can't be right.. do you know what I should do?
Yeah it sounds like it may not be formatted. Right click my computer, click manage. Then goto the disk management area. Find that disk. Right click it and click format. NTFS format most likely, unless it's some tiny drive. Of course that's really just assuming it's a new drive.
but the drive has lots of films and music on it... is it possible to "restore" the disc without formating it?
Oh... In that case try it on a different computer, it's possible it's something odd with the controller. Or maybe the jumper settings. Or maybe your chipset drivers (which would cover the ATA controllers) are out of whack.
I have installed s-ata drivers... maybe it will work if I delete them.. here's a pic of the computer management.. I sais the second disc is Dynamic, but the disc that's working is Basic... one button sais convert to basic.. will the data on the disc be lost if I convert it?
