Project: Hard Lined - update 6-18-2006
Discussion in 'Project Logs' started by jaguarking11, 29 Sep 2005.
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Looks good dude. I had that pump too, and its noise made me change. Now running a Ehiem 1250, and I'm not complaining. No noise tbh, and uber flow. :)
    How is yours now?
  2. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    The flow is good on this thing. It actualy pushes about 3L/m so the flow isnt bad but it resonates through the case creating more noise than necesary.
    The cone is from some sort of old table. It was a part of 4 cones I found in my junk drawer. It had some surface rust but some quick sanding cleaned it rite up.
  3. jaguarking11
    10 Dec 2003
    Dejavue (sp?)
    Im guessing the logs and discussion threads have been remerged?
    Im glad things are back this way. Way to go bit. :rock:
  4. Stuntman
    Stuntman Minimodder
    22 Oct 2004
    Yes... This is the way it should be. ^.^
    You have a great log here! The PC is really turning out to be awesome x 3!
  5. jaguarking11
    10 Dec 2003
    Well I started with this old heatsink.
    After bending it back and fourth I managed to snap a fin off.
    I then proceded to put the fin on the stove and let it heat up. For two reasons really. It makes removing the clear coating off it easy and the second reason is that it makes the copper more flexible and workable.
    After puting the very hot copper foil under water for a fiew seconds I then sanded the old crud off it.
    This is the second part of the block.
    Its actualy a copper cap for a 1inch tube.
    I then took the copper sheet and put it over the copper cap but on the hollow end. The scope is to turn the sheet into a cap for the cap and seal the block. So some hammering took place.
    Now we need some way of fabricating something to fascen the block on. I bought a copper strap that is meant for a one inch tube.
    Some cutting.
    Notice the part left over ontop. Im not throwing that out just yet.
    That part comes in handy so I can hamer a curve into the copper pice. I hamered a curve ontop of a 1inch black cast iron pipe.
    After adding a cuple of cupplers and some pipe I did the soldering. THis is it now.
    Ofcourse its very dirty from the smoke and the oxides created by the torch when soldering.
    Next up is some sanding and polishing. You may also have noticed I did not put anything inside the block for turbulance. And that is simply because it wont need it. Chipsets produce very little heat and just water in the chamber design should take care of it. In fact the new acetal chipset block from swiftech is just a chamber design with no fins whatsoever.
    Your thoughts?
  6. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    interesting idea, i wait to see how it turns out :)
  7. jaguarking11
    10 Dec 2003
    OK update time.
    I have decided to replace my heater core with a triple 120mm swiftech radiator. It finally arrived.
    Here she is
    Here is another shot to show the finish on this thing. The finish on it is awesome.
    The fans above are the icing on the cake. These are the quietest fans I have ever owned. I put 12v on 10 of these babies and they are still quieter than my psu fan. Thats 10fans making less noise than 1 on my stinken psu. They push about 47cfm acording to manufacturer.
    Well the folks over at craig davis were kind enough to sponsor me a pump.
    This thing is awesome. Its quieter than my swiftech pump and it can run @ 5v providing 1.5L/min. @ 12v it puts out ~3L/m. The kicker is that this thing runs cooler than my previous swiftech making it more ideal to run it insulated for noise.
    Here it is compared to my older swiftech unit.
    And the pump compared to an undressed swiftech pump.
    Original pump mounting. Where the new pump will go in.
    Now I want to mount the triple rad down flush with the case. So I need more airflow. I built this front plate to go on top of the case. (I may paint the bezel of it black to match the case). I also put on a sponge on it to make sure dust stays out of the case.
    I added an air filter on the front as well. But something was missing. I decided to put a couple of red ccfls in the front to light up the sponge. It looks funky and weird.
    And the pic of my favorite new toy. I love the tube amp.
    I am putting sound dampening all over the case as well. I bought some spire sound mats.
    And some thicker dampening material.
    Thats it for this update. Sometime next week I am hoping to update again.
  8. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    dude i just found this Im also making my own watercooling simular to urs im watching closy mint work.
    :D
  9. Bluefan
    Bluefan test 123
    25 Feb 2005
    Some cool modding there mate ! :thumb:
  10. SlappKnutts
    SlappKnutts What's a Dremel?
    28 Jan 2007
    Nice stuff! I like the copper tubing. And the pantyhose fan filters are a neat trick, gonna remember that!
  11. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
  12. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Look like yate loon 12dsl fans to me. Good pick, I've got 5 of then in my case and they're incredibly quiet.
  13. jaguarking11
    10 Dec 2003
    Your spot on. Those yates are the best fans I have ever owned.
  14. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    What's the model name/number on that craig davis pump?
  15. jaguarking11
    10 Dec 2003
  16. jaguarking11
    10 Dec 2003
    I have finished her. I finished the case for a lan party in rode island about 3 or 4 months ago. I did not take pics tonight. I apologize to those who were reading my measly thread.
    So here she is.
    I used my flowmeter as jet, its performing two jobs, it protects my pc and improves block performance.
    Another shot
    The top plate I built. It also houses switches that control my pump flow (5v & 12v) lights, and the front musketeer.
    Front.
    Another Shot
  17. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    I have never seen someone use standard copper piping for WCing before, looks good.
    H.B.
  18. jegerjon
    10 Jan 2007
    Very interesting. Looks so clean with those pipes instead of tubbing. But bet it's a hell when you got to change component :hehe:
    Nice work :thumb:
  19. jaguarking11
    10 Dec 2003
    I have an x1950 pro waiting to be put in. Its going to be a direct bolt on with little more than 30min assembly time. After adding the chipset block its actually easy as pie to assemble and disassembles my loop now.
  20. culley
    culley What's a Dremel?
    12 Jul 2006
    Nice build, looks wicked. Is there any type of clear gloss you could get to put on the copper, as the copper just gets dirty after time.
