Case Mod - In Progress Project: HeckaFresh Apple G5 Mod
Discussion in 'Project Logs' started by numps, 30 Apr 2009.
  1. numps
    numps Noob G5 Modder
    30 Apr 2009
    Hey Doodsies,
    First time poster, long time snooper...I'm currently attempting my own Apple G5 Case Mod and my goal is to attempt to put a bunch of I7 Parts into it WITHOUT butchering the backside. I will then attempt to try to recreate as much of the original G5 Placements making it look all neat and pretty inside. There won't be any water cooling as I don't have the budget to fit it in, and I don't know how to do it, so double blamo.
    Here is my parts list:
    Apple G5 Case
    GIGABYTE GA-EX58-UD5
    I7 920
    Corsair 750 Watt PSU
    6 gb of OCZ ram
    Noctua-NHU12P CPU Fan
    nvidia 8800 gt (borrowed from a friend until I have money to buy gtx 275, edit: nvm, can't borrow it anymore :( i'm sad)
    I think that's it so far...But so far, I don't have any of the parts yet, just some old parts i'm using to measure things. Anyhow, here is my progress so far, I hope you like what I've done!!
    Internal shot of the motherboard laid perfectly into position
    My homemade motherboard tray made of Plexiglass and normal motherboard standoffs
    Standoffs on both sides allow for perfect height from the case to the height of PCI Slots
    Fits perfectly into place, where the underside standoffs are measured to exactly where the original logic board standoffs would go
    Next Task: Work on the back panel!!
  2. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Whow, nice solution :) Gonna follow this.
  3. coldfusion1313
    coldfusion1313 What's a Dremel?
    21 Mar 2009
    you should get this
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=3387
    it has been used in many g5 mods before
    http://www.performance-pcs.com/cata...e=product_info&cPath=130_210&products_id=2150
    you might need that because sometimes the old front panel conn do not work
    look around that site for stuff for the mod
    then take the tray and trace the the back on the back of the g5
    then take your dremel and start cutting
    it will not be perfect but there will not be a big ass hole in the back
    :thumb::rock::thumb::rock::thumb::rock:
  4. numps
    30 Apr 2009
    Thanks for your replies guys.
    @Coldfusion1313: I was looking into that, but I do not want to cut the back of the case. I think it's beautiful the way it is, and I will have to work around it. I know what I need to do, it will be hard, but I think it's very doable. Hopefully I can work on it more and show you my idea. It will be awesome...according to the idea I have in my head...might not come out the way I want it, but I'mma try...hopefully you will like it too.
  5. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    Good start,i've got a G5 case that I was planning to mod some time in the future so i'll be watching this closely,subd.
  6. coldfusion1313
    21 Mar 2009
    are you going to paint or polish the case
  7. jhanlon303
    7 Sep 2006
    Welcome to the Bit-Tech "G5 Case Appreciation Society"!!!! [​IMG]
    You put our ranks at about 5 or 6 + Cheapskate wants one.
    I have seen on the internet somewhere a mod that does NOT cut the back side. It involves rewiring and building a new board to recreate the 'weird' Apple layout.
    I have 2 and 1/4 G5 cases. They are cool but a total pain to fit non-Apple stuff in.
    Mod on, I watch
    john
    /Edit
    How much of the G5 case did you get? Clear Plexi air deflector? Fans and HDD mounts and tray?
  8. numps
    30 Apr 2009
    @coldfusion1313: I'm going to be sanding and painting the whole case cuz there are a bunch of ugly scratches. :(
    @jhanlon303: I've been looking for a cool case for a while, and I thought to myself, hey, I like the mac pro look, so decided I can try modding a g5 case, cuz everyone's doing it, why not? I got the air deflector, and some fans on top near the hard drives and the hdd mounts and trays. Other than that, it was pretty empty.
  9. stonedsurd
    11 Mar 2009
    Is that a recurring problem? I haven't been able to find one in good condition yet, too lazy (plus no access to tools here) to redo the entire exterior. :(
    Great project, though and great idea with retaining the stock look :thumb:
    *subbed*
  10. numps
    30 Apr 2009
    Seems like it's an aluminum problem, since it's such a soft metal, it's very prone to scratches. If you accident bump it into something, it'll scratch. Like mac book pro's, or ipods(though not aluminum) are prone to scratches. There was one on ebay really good condition, but very $$$$, though, once u get one, you gotta be careful. Though, it's not too bad.
    stonedsurd likes this.
  11. subset7
    31 Aug 2008
    I must have been lucky,mine isn't marked at all apart from a 1/4" scratch near the bottom.
  12. B4TM4N
    B4TM4N Ninja
    11 Aug 2008
    Lucky bum with a G5 :p
    Hopefully this log is promising!!
  13. Cheapskate
    13 May 2007
    ^What John said. AngelOD's G5 log involves rewiring all the I/O connectors if I remember right. That whole log is pure porn.
  14. numps
    30 Apr 2009
    Oooh, I will have a look. I was thinking of a way I can integrate those back ports, though I have an idea, I'll check it out! Thanks! COol!
    Edit: Cool, just checked it out, it would've been nice to have the original logic boards to use it's i/o ports, but I don't :( But I have a solution to this pollution!! I'll show you when I've built it!
  15. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    And exactly what is wrong with butchering the backside of a G5? :D
    Snug fit with the mobo and look forward to seeing what your idea is for the back.
    Any thoughts on the colour of the case?
    Cyp.
  16. numps
    30 Apr 2009
    What's wrong with butchering the backside? Just take a look at your mod...:D haha, jk, you did a pretty good job, I was impressed. I guess I just like the simplicity route that apple took. I wish the motherboard would've fit without having to tamper with the dvd drive/hdd plate, but I had to remove it and will probably have to cut it a lil bit. As for the color, I am thinking a matte dark gray though I might change my mind later, but that's what I got for now.
  17. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Add me to the Wants a Powermac G5 / Mac Pro Case, but i want one with a mac inside! :p
  18. numps
    30 Apr 2009
    That's nothing $3k can't fix :p
  19. Digitalize-
    23 Apr 2009
    Yup, £4000 to have one of the most powerful PC's made :D
    Maybe when i go to Uni.....
  20. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    i got me a g5 waiting to go, so I'll be watching this too!!!
