project: i-spider |stacker mod | 11-4: up and running (again)
Discussion in 'Project Logs' started by _ferry_, 19 Aug 2004.
  1. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    I really like this mod, very-very detailed. Keep up the good work.
  2. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    I'will do so :)
    BTW, lot of reply's from dutch people in this thread ;)
  3. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    nice job keep on going
  4. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Dude, that's some of the best cable management ever!
  5. _ferry_
    22 Apr 2004
    update
    I received the stuff from coolermaster today, it could have been here friday, but i missed the mail guy.
    Some day ago i've made 2 strips witch will be mounted between the 2 cases. It took me about a day to cut it and sand it down perfect straight.
    some CCFL's without the plexi tube around it. i've only broken 1 of 5, and i need 4 of them, so that's no problem.
    The perfectly follow the dimensions of the case.
    [insert own comment]
    The 2'nd case will be cutted down to 4-5 bay's in height. And it will be equipped with my watercooling stuff (2 waterloops), the fanbus, lcd, and other electronics. The total height will be around 80cm, a bit more than the height of my desk :(
  6. Pitbull
    20 Mar 2005
    look large but are you going to connect them so you can`t look threw pc 1 and pc 2 ??
    but i like it :rock: :rock:
  7. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    I hope for the sake of all who use that computer, that it doesnt fall over :thumb:
    excellent mod keep it up :D
  8. _ferry_
    22 Apr 2004
    The top of the pc, and the bottom of the watercooling will be closed (actually it's open, but the hole is covered with mesh.
    It won't ;) and the height will be reduced to +/- 80cm, so that's high, but not dangerous ;)
  9. _ferry_
    22 Apr 2004
    update
    warning:
    The following pictures could cause permanent illness or damage for people who ae scared of modding there stacker 8)
    the PSU cage will be removed, i needed it to keep the frame strong enough while cutting and welding.
    Nice detail is the bezel between the 2 cases to make it look like 1 case. It took some time to find out the exact dimension i would need to cut of the case, i had to remove 28,5cm of the case, and as you can see i was right.
    Next to do is fixing it permanent on the lower case, cut the sidepanels and aluminium profiles. And mounting the plexiglass strips between the cases.
  10. Sanatarium
    Sanatarium The Artist Formerly ATi_Loyalist
    22 Feb 2005
    Damn thats hardcore.
    Nice work sir. I believe you just made your own shuttle/hydrocool. wow
  11. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    dude, that should be a sin or something. you've got some balls to be doing that. j/k great work, did you weld it? basically it's a midget stacker.
  12. _ferry_
    22 Apr 2004
    Thanks,
    A barebone would fit 2 times in it i guess, anyway, it should be big enough for the cooling and some electronics :)
  13. Pitbull
    20 Mar 2005
    damn nice damn big:|
    (lekker bezig jong:p) :rock: :rock:
  14. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    nooooo :waah: :waah: that is murder poor stacker looks nice but kill an stacker to make one bigger is just insane...
  15. ginx
    ginx What's a Dremel?
    1 Sep 2004
    That's a bad ass big motha ... Its a HUGE rig, can't wait to see this thing finished. :rock: :rock: :rock:
  16. Sub-Zero
    Sub-Zero What's a Dremel?
    6 Feb 2005
    mhh, where you got the idea from. :naughty:
    it´s looking like my stacker. :D
  17. _ferry_
    22 Apr 2004
    Hmm, i was hoping to be original with adding a 2nd one :p
    Have any pics of it???
    ah, this one:
    http://forums.bit-tech.net/showthread.php?t=87193
    but you mounted it below, and it isn't made of a 2nd stacker, but it looks very good too :dremel:
  18. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Man thats SICK! Very cool, is it now like 90cm long? Or even METER?
  19. _ferry_
    22 Apr 2004
    85cm, with the wheels included. 80cm whitout the wheels.
    And my desk starts at 74cm :dremel: :hehe:
  20. Soul__Assasin
    Soul__Assasin What's a Dremel?
    21 Oct 2004
    You are mentally disabled....
    wrecking a stacker for a mod
    YOU ARE MY GOD
    echt lekker dude doe zo verder
