Project: MAXcube
Discussion in 'Project Logs' started by mr.X, 21 Apr 2005.
  1. -Erik-
    -Erik- Guest
    Green neon plexi, damn, my favorite! Cant wait for new updates. (Subscribed!)
  2. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    Maybe I'll do that. I'm not sure. I first want to see how it looks without the dye.
    No.. I just took the drives apart and tried to copie the original drives
    And another small update
    It isn't going as fast as I expected :eyebrow: I've been filing and sanding for the past days and the result is that I've completed 24 of the "connection-corners".
    First drill some holes after the sanding was done:
    After the drilling, I had to bend the plates:
    It's time to put it all together with nice bolts:
    Next I'm planning is to make the drive-bay.
    Untill next update.. :dremel:
  3. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Woah... Looks amazing. That neon green shows up really well.
  4. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Are you going to drop some UV cold Cathodes in that bad boy for yours???
  5. mr.X
    15 Mar 2005
    Perhaps I'm putting two small (10cm) ccfl's at the bottom but I'm not sure yet.
  6. ginx
    ginx What's a Dremel?
    1 Sep 2004
    I LOVE the custom CD-ROM/FDD housings, super nice. That's the only thing I don't like much about clear cases, is the CD-ROM and/or the FDD, because of the housings. This is definatly nice, that's a cool color you used too, is it UV reactive?
  7. mr.X
    15 Mar 2005
    disappointment
    As I wanted to mount the drives, I saw that they weren't that straight as I thought they were :sigh: Then the DVD-ROM drive fell out of my hands and broke. :duh:
    Because I had to make a new DVD-ROM drive, I'm also making the other drives again. A minor setback but now all the drives are gonna be straight (I hope :eek: )
    see you at the next update
  8. mr.X
    15 Mar 2005
    little update
    After I'd broken the DVD-ROM drive, I made me a new one. I also made a new drive for the FDD and the fancontroller. This time I didn't bend them but put them together with glue. Here are the results:
    Housing FDD:
    Housing DVD-ROM:
    Housing fancontroller:
    All together now :D
    Now the frontpanel is the next victim. I've allready put some holes in it for the fancontroller:
    The rest of the holes etc. you'll see at the next update..
  9. Guest-6374
    Guest-6374 Guest
    I can't believe I didn't realize it before, but that design doesn't have 3 cubes. It has two cubes and a triangular cylinder in the middle. All you need is three equal-sized panels for it and the top cube will drop right in.
  10. DR_K13
    DR_K13 What's a Dremel?
    5 Jul 2004
    I like where this is going.
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Skills. Nice to see.
    :~subscribed.
  12. toand
    toand What's a Dremel?
    17 Feb 2004
    Really nice work, makes me want to try working more with acrylic :D
    -subscribed-
  13. mr.X
    15 Mar 2005
    Although you could be right, I will be using a cube in the middle. The top plate of that cube will have a triangle cut out. In that I'll place the upper cube. :dremel:
  14. mr.X
    15 Mar 2005
    quick update
    I had a little extra time and made some icecubes :naughty: They are attached at the bottom and will be the feet of the case.
    Of course I want to have lights in them, so I drilled some holes for the leds.
    For the wiring I copied the idea from Defyant (all credits to him :clap: ) and sleeved them UV green.
    Next time I hope the bottom cube is finnished. Untill next time :dremel:
  15. mr.X
    15 Mar 2005
    bottom cube almost finished
    :clap: I realized that I didn't show the sleeved cables the last update :duh:
    So here they are :hip:
    I assembled most of the bottom cube so it's almost finished now :clap: I only need to attach the UV green roundcables for the FDD and DVD and of course the powercables. But firts I'm gonna start on the middle cube.
    Here some results of the bottom cube..
    With the lights on (I also placed two small ccfl's):
    Until the next update. :dremel:
  16. keir
    keir S p i t F i r e
    5 Oct 2003
    wow thats looking great so far.
    if it ends up as tidy as it is so far it'll look fantastic! :rock:
  17. bjones247
    bjones247 What's a Dremel?
    30 May 2004
    Nice. Sometimes plexi can be overdone, but I think your design is original and more like "art" than we normally see here. Nice concept. Subscribed... :D
  18. Hal
    Hal What's a Dremel?
    1 Feb 2005
    wow... just wow. looks so clean. you clearly took time and effort to do this! rock
  19. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
    nice - are you going to make a top for the controller or jus leave it like that ?
  20. mr.X
    15 Mar 2005
    thanks for the nice comments.
    I'm gonna leave the controller as it is. I like it this way. It's nice tot see the black coolribs.
    I just had the lights on in the dark and it's NICE!! :clap: I'll post a pic soon but atm my camera is away for a short moment..
    :dremel:
