Scratch Build – In Progress Project Neophyte .: UPDATE 25 !!!!!! : 21.03.10 :.
Discussion in 'Project Logs' started by Dark~3nergy, 25 Mar 2008.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Looks amazing D~E! Every time I hop in here to take a look at your progress, I always leave impressed... but always wanting a little more!
    I do have a quick question for you however. Would you mind measuring up the dimensions of that Koolance radiator for me, including the mounting holes? I'm not concerned with the fan shroud, but just the radiator itself. If you can find the time, I would surely appreciate it! Thanks!
  2. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    thanks :D
    I'm working as fast I can.
    I'll pm you some dimensions later, just have some homework to do first.
  3. talladega
    talladega I'm Squidward
    18 Aug 2007
    I looked at www.koolance.com and they have this
    http://www.koolance.com/support/files/inx-720,ehx-1000_hole_stencil.gif
    A stencil of the mounting for the radiator to scale.
  4. craigbru
    28 Feb 2008
    Excellent. I appreciate your time!
    I actually did come across this. However, I'm looking to separate the radiator from it's mounting/fan shroud. I've got no interest in mounting fans directly against it, so the shroud isn't needed. Since they are sold together, I can't find any dimensions except for the whole assembly. I know I'm being difficult... :D
  5. renba
    renba hooch is crazy
    2 Oct 2008
    HI Dark
    I'm going to look for an O-ring.:p
  6. Dark~3nergy
    14 Jan 2007
  7. renba
    2 Oct 2008
    Hey Dark
    Can you send me the measurements, I'm not sure but I found one
    if you still need one.
  8. Dark~3nergy
    14 Jan 2007
    ohhhhh that would be very nice of you :)
    I'd need one that is at least 2.5mm thick and that have a circumference of 256mm(~40mm of radius I think).
    And I FINALY ordered my laser cut plexi glass, had a hard time to find 5mm red plexiglass.
  9. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Looking great!
  10. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    I love the ram cooler it will be nice in the case :clap:
  11. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    AAAWWWHHHHH!!!
    this mod looks like its straight from hell >=]!
    soo dark and red, my favorite colors.
  12. Dark~3nergy
    14 Jan 2007
  13. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    The cpu block would have been nicer if the acrylic part would have fit inside the copper part imho, but still, you are giving birth to one hell of a case!:rock: (damn that sounds cheecky:duh:)
  14. renba
    2 Oct 2008
    Hi Dark
    http://www.angst-pfister.com/fr/DesktopDefault.aspx/tabid-1/
    Succursale Suisse romande
    Angst + Pfister SA
    Route du Bois-des-Frères 52
    Case postale 18
    CH - 1219 Genève-Le Lignon
    I have no idea but maybe you live in the near.
    there is also this one but its too big.
    http://paddlershop.ch/catalog/produ....html&XTCsid=1179e51520322407a7fd4617ca77099f
    Or you can ask them
    http://www.geberit.ch/geberit/inet/ch/wcmschf.nsf/pages/index
    http://tel.search.ch/?was=Geberit
    I dont know where you exactly live but there are some stores in the french part of switzerland
    edit: what about that?
    https://shop.maagtechnic.ch/ishop/app
    These shops/stores are all in Switzerland
  15. Dark~3nergy
    14 Jan 2007
    thanks, I'm going to contact some of them to see what they have.
    btw. I live in Sion.
    thanks a lot :D
  16. renba
    2 Oct 2008
    sion plays against st. gallen in the quarterfinal :o:D
  17. camera man
    camera man What's a Dremel?
    3 Nov 2008
    looks great man jst looked right the way through the log cant wait to see it finished where did you get the insperation of this project?
  18. Dark~3nergy
    14 Jan 2007
    Go sion !! :D
    camera man, thanks :D, inspiration... hard to tell, listening to good music maybe ?
  19. Dark~3nergy
    14 Jan 2007
    I ordered some stuffs from performance- pcs :D
    hopefully they'll arrive on monday or thursday.
    I'm also going to pick up some 5mm plexi in Geneva on monday so there will be a big update on the evening ;)
    cya
  20. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    I seen some one else here on the forums use these x-rings. There like o rings but protect from 4 angles. http://www.satoriseal.com/x-rings_(quad_rings).htm I hope this helps and maybe you can find them over there some where. Sweet case BTW. I just spent my lunch hour at work reading the entire thread.
