Case Mod - In Progress "Project NEXT"
Discussion in 'Project Logs' started by Brian E. Hanson, 12 Jan 2009.
  1. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    you could always paint he founts of the drives
  2. skullen
    skullen Minimodder
    31 Oct 2007
    Very very nice,it does look the part :thumb:
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I was talking to Brian about painting the top of the CM V8 cpu cooler to look more "ferrari-like" I really like the silver and red intake manifold on the 599
  4. Degenerate83
    Degenerate83 What's a Dremel?
    4 Nov 2008
    Thats a fab idea!!!!! really looking forward to seeing how this whole project turns out now!!!! especially as was looking at this cooler if i couldnt afford water cooling lol. but the ferrari red does look the part
  5. The boy 4rm oz
    10 Apr 2008
    Yeah a really good idea, that would look sweet.
  6. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    The air cooler must get painted... that would look amazing in this case. In fact, I'd venture to say that it would look better than watercooling. :thumb:
  7. The boy 4rm oz
    10 Apr 2008
    I think you are right there Craig.
  8. Degenerate83
    4 Nov 2008
    indeed i may have to agree!!!
  9. mnpctech
    21 Apr 2003
    Video of the case, along with other videos from my facebook page
  10. The boy 4rm oz
    10 Apr 2008
    Nice vid Bill. I really gotta start getting some stuff from you ;).
  11. mnpctech
    21 Apr 2003
    Cool! just contact me direct anytime, pcbuilderATmnpctech.com
  12. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Nice of you to include the video in this thread. I hate facebook.......
  13. mnpctech
    21 Apr 2003
    No problem.. I understand.
    I'm awaiting the arrival of the CM V8 cpu cooler from Brian. I wanna see just how big it is in person :naughty:
  14. The boy 4rm oz
    10 Apr 2008
    I'm sure CM would send you one Bill if you really wanted it lol ;).
  15. Brian E. Hanson
    Brian E. Hanson What's a Dremel?
    12 Jan 2009
    I hope it fits inside the case!!! Also, I was thinking on my way to work today, I'll have to install it on the side rather then upright. The two 92mm fans in the rear are meant to pull in cool air, send it through the heat sink / processor area and, up to the top two 120mm fans and out. That being that, If the heat sink is installed upright, the fan on the sink would be blowing against the wind, so to speak. On it's side, it'd be blowing up and out as it should be in this case. Hmm, I hope it can fit that way. Also, this might be a consideration as to how it gets painted on the sink? I don't know... All I know is, as soon as I saw this sink when it first came out, I knew it was the one. It has great performance from what I've read.
  16. mnpctech
    21 Apr 2003
    Theres a box looking at me, I'm heading over to the shop this afternoon and will crack it open
    Yea, we can paint a bio-mechanical theme instead for you :naughty:
  17. mnpctech
    21 Apr 2003
    Dissection of Coolermaster's new "V8" CPU Cooler
    Model RR-UV8-XBU1-GP
    CPU Socket Intel Socket LGA1366
    Intel Socket LGA775
    AMD Socket (Socket 940/AM2/AM2+)
    CPU Support Intel: Core i7, Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium Extreme Ed., Pentium Dual-Core, Pentium D, Pentium 4 Extreme Ed., Pentium 4 HT, Pentium 4, Celeron Dual-Core, Celeron D
    AMD:phenom, Athlon 64 X2, Athlon X2, Sempron
    Fan Control PWM + VR Controller
    Rated Voltage 12V
    Start Voltage 7V
    Operating Voltage 10.38V - 13.2V
    Rated Current 0.12A
    Input Power 1.44W
    Dimension 120 x 128 x 161.1mm
    Heat Sink Material Copper Base / Aluminum Fins / 8 Heat Pipes
    Heat Pipes Dimensions 6mm
    Fan Dimension (W / H / D) 120 x 120 x 25mm
    Fan Speed 800 - 1800RPM
    Fan Airflow 69.69CFM
    Air pressure (mmH2O) 2.94mm H2O
    Bearing Type Rifle Bearing
    Fan Life Expectancy 40,000hrs
    Fan Noise Level (dB-A) 17 - 21dBA
    Fan Speed Adjustment Install on PCI Slot
    Connector 4-pin
  18. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Hey Bill
    Me and my colleague Tom Portsmouth actually had a bit of design input into those coolers last year.
    I remember an embarrassing moment for CM when they were actually going to call one a V7 but it was pointed out that engines don't actually come in a V7 format :nono:
    Needless to say, they dropped that idea :D
    To our relief they turned out to perform well and look good which was the main criteria :cooldude:
  19. Brian E. Hanson
    12 Jan 2009
    No, no, the engine idea is better for this.:thumb:
  20. jhanlon303
    7 Sep 2006
    Excellent pictures and every bit of information a man or woman could want EXCEPT.......
    What does it weigh. I'm still betting it weighs more than H20-C7
    john
