Project: nut case
Discussion in 'Project Logs' started by zachjowi, 7 May 2006.
  1. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Its looking good man, Nice to see someone use wood, and its crazy that you have a slide out motherboard tray.
    Hope to see another update soon!
    cheers, WarriorRocker
  2. Jipa
    5 Feb 2004
    The design looks nice as there's mobo-tray and sidepanels are curved BUT. Imo wooden cases + windows = no match. The dvd-drive also looks terrible atm, I really hope you'll figure out a way to hide it!
    Keep it coming.
  3. weaselx
    weaselx What's a Dremel?
    30 May 2006
    why not just remove the bezwl for the cd drive and use a vinel that matches the colour of the wood and sticking it on the bezel should prove quite effective.
  4. zachjowi
    zachjowi What's a Dremel?
    15 Jan 2005
    on the front center there is a piece of plexi that is frosted and has blue LEds behind it. When I get time I will mill a cool design on it so that it'll light up. there are two LEd holders and the power and reset switches. the switches have a piece of tiger wood covering them.
  5. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    Ah, thanks for clearing that up. But what about that dvd drive?
  6. zachjowi
    15 Jan 2005
    I will maybe stealth it.
  7. scifi3018
    6 Feb 2005
    and there was much rejoicing...
  8. forester joe
    forester joe shhh. can you hear your PC?
    24 Oct 2005
    love it.
    the frame, the mass, the size.
    love it.
    (maybe a little more brightness on the photos)
  9. zachjowi
    15 Jan 2005
    how much do you think I could sell this computer for when I am done? any rough ideas?
    also do you think I could sell some custom made cooling blocks? and how much?
  10. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    is that block aluminum?
  11. zachjowi
    15 Jan 2005
    yes it is I milled it on my CNC mill
  12. eltinio
    eltinio What's a Dremel?
    18 Jun 2004
    Hmm that block looks like a real flow killer, and i mean really dead :p.
    And why didn't you use copper?
  13. scifi3018
    6 Feb 2005
    copper = expensive...
    and if the flow is slow, thats more time for the water to absorb heat, no?
  14. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    a block of copper is like 5 bucks...
  15. eltinio
    18 Jun 2004
    Have you already tested the block? checking how big of an flow killer it is.
  16. zachjowi
    15 Jan 2005
    I have tried it and it works great :D
  17. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    i beg to differ on that, that block is a flow killer, the idea is to asborb heat and remove heat quickly, the water in a block heats up very quickly!! that why if your pump fails the CPU will go pop!
  18. zachjowi
    15 Jan 2005
    if the idea is to flow water through quickly why do the commercial blocks have pillars to slow down water flow?
  19. Eufouria
    Eufouria What's a Dremel?
    20 Feb 2006
    im not sure if im correct but i think those are to dissipate the heat into the water, not slow it down, sort of like an underwater heatsink
  20. scifi3018
    6 Feb 2005
    No, those pillars are to create turbulence, which makes the water swirls around in the block longer.
    Besides, dont look at the block and say it sucks, the man has used it and says that it works.
