Project Purity & Simplicity Chrome and Black (Project on hold for a little)
Discussion in 'Project Logs' started by Robster, 1 Feb 2004.
  1. Kingston
    Kingston What's a Dremel?
    28 Apr 2004
    The front really is amazing. Can't wait to see it finished
  2. Chrizzle
    Chrizzle What's a Dremel?
    6 May 2004
    If you have trouble getting fluff like that off, whipe it down with a wet rag to get rid of the particles, and then dry it with a lint-free cloth, like a shimmie. This is a great mod BTW. I like the ducts a lot.
  3. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    i like the "smoothness" of the ducting looks absoluty fantastic, i would compare the curves on that to like a 69 Camaro or a 67 Mustang, so nice :thumb: .......keep it up :clap:
  4. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    DOGNABIT :jawdrop:
    now i need to empty my fitfh droolbucket :wallbash:
    those darn pictures :eeek:
    (great work pal :thumb: , keep up tha outstanding work so i can empty more droolbuckets)
  5. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Need....chrome....now.... :hip: :eeek: :hip: :eeek: :hip:
  6. Robster
    Robster What's a Dremel?
    11 Dec 2003
    Talked to the chrome shop today and will have all the parts back by the 4th of July so will have more updates on this one then but going to be cutting it close for the show on the 14th will have about 10 days to finish up all the rest that needs to be done. :worried: will have to do all the :dremel: work quick
  7. coil
    coil What's a Dremel?
    25 May 2004
    I don't frequently feel I have a reason to use the "jawdrop" smiley... but I saw that front panel, and my jaw literally fell open. That thing is *gorgeous*.
  8. Robster
    11 Dec 2003
    Yah real happy with the way it came out was lots of work once i get the fans mounted and lighting done this should look real good.
    but stuck waiting on the chrome shop for now but soon
  9. gLoopy
    gLoopy What's a Dremel?
    17 Jun 2004
    Clean looking, so very nice, keep up the good work.
  10. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    This is going to look so nice when it's done! :eeek: :jawdrop:
  11. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    i have to say again how much i love this case its amazing
  12. Protius-X
    Protius-X What's a Dremel?
    31 May 2004
    Hurry up and finish it! I love the paint and chrome work its so... so.. WOW!
  13. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    i must i'm getting very nervous waiting for an update, i know fragapolooza is over so, if i could ask, Where is the updates?? (seems like everyone is slaking right now)
  14. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Justa question, I may have missed this, but why did you get the front painted without trimming the ducts? Aren't they sticking out too far behind the front panel? :confused:
  15. Robster
    11 Dec 2003
    yes they are sticking out a bit to far i cut them down already just wasn't to sure on the measurement of how much i need sticking out of the back because the interior for the case was at the chrome shop when i decided to do the ducting so figured why cut them.
    But have cut them now and getting things put together as for the post just a little earlier yah fragapalooza is over and i am going to be start back up on the mods but after 4 days of 24hr gaming and showing off the comps :rock: i decided i would take a break from it all. :wallbash: :yawn:
    so there will be more on everything going on around here just needed a break was all
    oh yah and we took 2nd place with all the mods guess we overwhelmed them with the comps won 2nd place for 3 of the mods they wouldn't give me 2nd 3rd and 4th gues they figured it wouldn't be fair.
    lol
  16. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    More pics?
  17. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    agreed, we would like more pics (please :waah: )
  18. Robster
    11 Dec 2003
    fair enough i will get some up tommorow as my camera is still down and out but might be able to borrow one tommorow so will update with some pics soon
    Actually not only on this one but all the mods on the go as well
  19. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    What kind of paint did you use for the front bezel?
  20. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    maybee you should invest in a new digi camera, if not then just "Malfoleo" to take some, and about the paint it's probly close to automotive qality paint cause he gets it done at a shop so i'll be soem expesive crap
