Project PX03 Darkcrystal wOOdcase FINAL PICS
Discussion in 'Project Logs' started by piloux, 12 Nov 2003.
  1. Fusel Wusel
    Fusel Wusel What's a Dremel?
    15 Nov 2002
    Wow! Really nice, man!! Love this....
    btw. Dein Englisch ist doch gar nicht sooo schlecht ;)
    Hmm, wieviele hier sprechen wohl deutsch? :D
  2. piloux
    piloux What's a Dremel?
    12 Nov 2003
    well , today is a BAD DAY for me :wallbash: I broke the painting by screwing a wrong screw in the top panel and at another side by fixing the psu :wallbash: ... well I have to repare this and re-paint the entire case to get (for the last time i hope) a very good finish...
    I work on it a lot today to place every internal pieces and to finish the wiring of the case and without thinking about this fuc**** screw I m very satisfied with the internal design and lightning :D
    here are the pics guys
    here is the crack coming by fixing the psu
    abd here by using the wrong screw (too much long screw) in the top inside panel
  3. piloux
    12 Nov 2003
    the rear side
    pioneer dvd slot-in
    led for hard drives activity
    and 3 shots by night :thumb:
  4. BLaZEjjp
    BLaZEjjp What's a Dremel?
    21 Oct 2003
    Sweet ass mod man, Sorry to hear about the cracks but I bet they are barely noticeable.
    Very impressive.
  5. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    O dear, tough luck on those cracks m8, but the overall look is GREAT !
  6. piloux
    12 Nov 2003
    thanks guys :) , I thought that the sanding was finish but here I go again :duh:
  7. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Looks great man, but i'd use the rear fan as an exhaust - there's no air escaping that case, minus the PSU slot.
  8. SweMOD
    SweMOD What's a Dremel?
    16 Nov 2003
    ooooooooooooooo :D
    it looks so freaking good!!
    to sad tho about the cracks... but...
    I guess you had girls on your mind or something??
    they ALWAYS screw boys mind up ;)
  9. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    remember... it is only a minor setback... it will work out okay... the case looks awesome as it is.. but I can tell that you are a man of perfection... and I know that you won't let the cracks stay...
    Excelent work so far!
  10. piloux
    12 Nov 2003
    that s right ;) I ll have to change this I was tired when I fix it :duh:
  11. piloux
    12 Nov 2003
    it must be the reason :D
    yes of course :) :dremel:
  12. Tigris
    Tigris What's a Dremel?
    29 Dec 2003
    Salut Piloux !!
    Bravo pour ton mod !!! Tro bôôô !! :D
    Tu représentes bien le modding francophone !!!
    Je savais pas qu'on pouvais faire aussi beau avec du bois !!
    Bon aller a plus , faut qu'jaille faire un tours dans les bois ... :hehe:
  13. haggisathome
    haggisathome What's a Dremel?
    1 Oct 2003
    wooooooooh after looking at all the pics and all the hard work you put in to that i feel humble to be in your presence :thumb: .
    i am soo sorry to see the damage :duh: but looking at what you have made i think you will repare it fast and to the same high standard as you have been working to..........................
    one more time
    well done and dam fine job there
    scott :rock: :rock: :rock: :rock:
  14. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Didn't think it would turn out THIS good. Compliments! :clap:
  15. piloux
    12 Nov 2003
    hi everybody :) thank you for these great comments :D happy that you follow my work of near :D today no more work on it but I have done some buying :)
    new motherboard abit nf7 v2.0
    black round cables and black spiral wiring
    and a screws kit, with every screws needed to fix everything in a pc
    :thumb:
  16. Tulatin
    16 Oct 2003
    sweet dude! Hopefully that screw kit won't end up resulting in more cracks...
  17. piloux
    12 Nov 2003
    I hope so :D
  18. naelq
    naelq What's a Dremel?
    14 Oct 2003
    tres bien mon ami, c'est magnific !
  19. piloux
    12 Nov 2003
    update :)
    that s the dust filters I made for the blowholes, I used aquarium filters to made it
    here it is after cut it right
    and with the lightning
    I asked myself some questions about the filter color, may be I ll paint it black or grey... or let it blue like this :confused:
  20. piloux
    12 Nov 2003
    then I fixed the mobo into the case and I had to cut the rear lexan panel to screw pci cards because of the lexan structure in front of it with the pci fan
    I painted the HDD rack with black paint too
    :dremel:
