Project R2D2 PC (w/Phase Change Cooling)
Discussion in 'Project Logs' started by TheGreatSatan, 7 Aug 2005.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Hi guys. I just joined the site and hope to visit often. I've been modding for about 4 years now. I'm building a life size R2D2 from scratch with a built in phase change cooling system. I've been hard at it for about a month or so and I still have lots to do. To catch up, check out my website's work log. I'll be posting the updates here too.
    www.tgsmods.com
  2. huren
    huren What's a Dremel?
    14 Aug 2004
    ive been watchign the progress o this case and its wicked.
    wd man =D
  3. mondriaan
    mondriaan What's a Dremel?
    20 Aug 2004
    I'm a big star wars fan. Super
    I'll be watchin this thread closely :thumb:
  4. Jipa
    5 Feb 2004
    That's cool. When I first saw only that pic, I thought it was model you can buy somewhere :D not DIY at all..
  5. PirateTheMeep
    PirateTheMeep What's a Dremel?
    7 Aug 2004
    Very cool, hard to belive it's DIY
  6. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    Should be awesome, makes me really want to get more work done on my case.
  7. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    are you gonna use a abit ic7 max-3 as mobo?
  8. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    i love it so far!!!
  9. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    i saw this on another forum. that is truely great work! welcome to bit-tech!
  10. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    Welcome... To City sevent.... ehh to Bit Tech!
    Wery nice work, I was amazed that you managed to find good dome for his head. And it looks awesome. I was wondering if you will put a webcam into his head. THat would be cool especially when displaying your mod in future shows.
  11. JamesM
    JamesM What's a Dremel?
    8 May 2005
    Been watching this over on WizD, looking really good too :D
  12. TheGreatSatan
    5 Aug 2005
    Yes I am!! Take a look...
    I started working on the Vapochill/Motherboard installation. I'd like to give a big THANK YOU to the Vapochill forums for the installation process.
    First I removed the heatsink brackett on my motherboard.
    Next I installed the back plate with the heating element and the guide rods.
    I pulled my proc off the board and applied the silicone compound to the entire underside (as instructed)
    The socket 478 requires a little piece of insulation to go in the socket.
    I put the proc back in and closed the clamp.
    Next up I slid the insulation for the socket over the guide rails. I'll hook it up to the cooling element after I deal with my CD drives.
    I finished the installation of my LCD.
  13. TheGreatSatan
    5 Aug 2005
    Alright, I'm having a bit of a problem mounting the CD drive in the dome. There's just not a lot of place within the head to secure it to. I'm still gonna try to do it, but I'm also, gonna have to prepare to mount it in the body, if necessary. Here's a pic of R2:
    Draw where on this pic that you think I should put the drive. Remember that the drive is a slot loader and can go horizontal or vertical.
  14. Hindaine
    Hindaine What's a Dremel?
    23 Oct 2001
    My suggestion, if you have watched the recent movies, he has a little arm that comes out where those blue things are about 1/4 of the way down from the top of the body, make one of them pop open to show the slot?
  15. megaglowz
    megaglowz What's a Dremel?
    10 Oct 2003
    Hey man.
    Glad your here!!
    Keep up the good work!
  16. quantum-modder
    quantum-modder What's a Dremel?
    4 Aug 2005
    good work where in illinois you live man pm me back
  17. TheGreatSatan
    5 Aug 2005
    300 miles south of you
  18. gebrek
    gebrek What's a Dremel?
    11 Apr 2005
    great to see you here TGS. Now I can stop visiting twisted...
  19. TheGreatSatan
    5 Aug 2005
    I cut the hole on the opposite side for the floppy. Then I shined a flashlight through.
    Next, I cut the hole out of the front.
    Fixed the pin stiping.
    And here it is from the inside. As you can see, I'll be avoiding the use of drive bays to keep the clutter to a minimum.
    I was going through some of my supplies when I found a box of handles!
    Also, here's the power switch I want to use. Any idea on where I should mount it?
  20. TheGreatSatan
    5 Aug 2005
    I plugged my lower two intake, upper two intake fans, and floppy drive into the PSU and tidy up the wires.
    And I finished mounting the floppy drive.
