Project R2D2 PC (w/Phase Change Cooling)
Discussion in 'Project Logs' started by TheGreatSatan, 7 Aug 2005.
  1. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    gigabytes have never been great overclockers
  2. X_VADER_X
    X_VADER_X What's a Dremel?
    7 Sep 2005
    Beutifal... O_O
    A Huge R2-D2...
  3. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Dress up in a C3PO costume and go to a LAN with that beast in tow!
    Good job so far!
  4. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    I bought the Abit IC7-G. Hopefully it'll be here by next Wednesday.
  5. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Asus Motherboard P4P800-E Deluxe
    I ve these one:) no prob..
    just do it(nike style)
  6. Jipa
    5 Feb 2004
    To be honest I have no clue which AGP-mobos are good, so I think I'll just STFU. I just love 64bits and AMD [/offtopic]
    That looks sick awesome ;) It's huge and I like it!
  7. TheGreatSatan
    5 Aug 2005
    My new mobo arrived. It's the Abit IC7-G.
    And after the vapochill got down to -10 the system booted just fine.
    Here's some pics with all the fans working. I don't think I'll be adding any cathodes.
    Here's my CPU temp in the BIOS.
    And my current OC of 3.61Ghz from 3.2. I will do more, I just need to do some testing to see how stable it currently is. Then I'll need to probably play around with the memory and CPU ratio's and CPU voltage. I want to get it up to 4Ghz stable.
  8. TheGreatSatan
    5 Aug 2005
    Today I added the DVD drive to the front of R2. I decided against Stealthing it.
    Next, I added the motherboard shroud.
    And attahced the Duct sucking cool air from the outside and blowing it on the motherboard.
    The whole inside shot. I think I have everything I need inside.
  9. TheGreatSatan
    5 Aug 2005
    Today I worked on finishing my temperature LCD. Originally it was too short to reach the processor, so I added 9 inches (23 cm) to it.
    Here's room temp.
    And after 1 mintute of the system (Vapochill) running.
    And after 5 minutes, and where it stopped since. :D
    Here's a couple of images from the inside while running.
    And my working Orbital Matrix (still needs to be remounted)
    And lastly my desktop.
  10. TheGreatSatan
    5 Aug 2005
    I've been doing some testing on R2. First I tested the front USB ports then the CD drive.
    Then I found a problem. My temp LCD is blinking the letter "L" ????????????
    I raised my clock speed to 3.71Ghz from 3.2, and I changed my CPU to DRAM ratio to 3:2.
    Then I changed my voltage from 1.38V to 1.41V.
    It's running smooth so far, but I'll still need to test.
    What changes should I set to get to 4Ghz?
  11. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looking great tgs :D
  12. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Is your Matrix Orbital connected through a RS 242 interface, or USB?
  13. TheGreatSatan
    5 Aug 2005
    Internal USB to 1394
  14. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Nice work, Im pretty sure the temp monitor is flashing L because the temp is too low for it to measure, it have seen similar ones do that around -40ish.
  15. TheGreatSatan
    5 Aug 2005
    I heard it' because there's a bad connection in the temperature wires.
    R2-D2 is nearly completed. I still have to remount the Matrix Orbital and try to fix the temp LCD. I've already prepared my office for him and have taken back my 19 inch LCD from my daughter.
  16. TheGreatSatan
    5 Aug 2005
    R2D2 is finished
  17. TheGreatSatan
    5 Aug 2005
    Here goes R2D2's GRAND worklog reopening!
    I made one huge mistake with this project, I installed the Vapochill. Ever since it went in I've had problems, so it's coming out. Sure, there will be nothing to replace my -42 Celcius, but anything is better than a 100lbs paperweight.
    I'll have to remove the Vapochill and the shroud around the motherboard. I'll also have to find the plastic bracket to hold my new heatsink on the processor. Once I get the 38lb Vapochill out I'll have a lot of space from where it was serving no purpose. What to use it for?
  18. phuzz
    phuzz This is a title
    28 May 2004
    A big fat RAID maybe?
  19. TheGreatSatan
    5 Aug 2005
    I have a 120GB HD that I'm only using 9% of. I don't know what you people use your huge drives for.
  20. phuzz
    28 May 2004
    Pr0n?
    personally it's mainly films/tv (100Gb) and music (30Gb)...
